huskytike
Hi,
I just put new seals in a Danfoss open center, 4 port (2 sided ram) orbital valve for my Long 310c. Seems like a simple enough mechanism, but for some reason when I went to reassemble the Cardan shaft seems to be sitting a little proud and is interfering with the bottom end plate when I go to tighten everything up.
Here's the exploded diagram:
https://www.midweststeering.com/wp-content/uploads/OSPB-C-SVC-MAN-2014.pdf
Mine has a little bearing that sits at the bottom end of the Cardan, which it rides on. That bearing is sitting ~1.5mm above the plane of the gear wheel - worried it will bind up when I torque the bolts. I can not see where I could possibly go wrong in the assembly to create this interference.
Any thoughts or guidance are much appreciated.
Thanks
Thanks
