Oil & Fuel B21 oil level rising?
/ B21 oil level rising? #1
joea99
Marbletown NY
Kubota B21, JD 240GT
Went to start B21 this morning. Engine oil was over the full mark by about half the distance from "full to add". Seems I recall last time I ran it it was a bit above also.
I recall on Peugeot 504 diesels, at least with the non bosch fuel pump, this meant the front seal was leaking fuel down into the crankcase. Wondering if the same may be possible here?
I am going to drain and refill, as I don't want to chance running it on diluted oil, then see what happens from there. I don't run it that often, so may well forget that plan. I know on the Peugeot, I ran for quite a while, thinking how fortunate I was it had stopped using oil. Ah, what bliss is ignorance . . . When it began "gaining" oil, I became concerned.
/ B21 oil level rising? #2
Do you tend to stop and start it often, running it only for short durations so that it never comes up to temp?
Varies with what I am doing. As far as it "getting up to temp" goes, it never really seems to get hot according to the gage and I've been told that's normal. I have changed the thermostat with a Kubota item.
/ B21 oil level rising? #4
Gaining oil in the engine crankcase can come from the injection pump or the hydraulic oil pump either of which can blow the back seal and leak diesel or oil into the engine crankcase. The smell test might be the best way to determine which is leaking.
I don't really smell anything definite. I think an oil and filter change can't hurt, then I will monitor it closely. I doubt I overfilled it last time, but maybe. Delo 400 is on the self locally, so I may use that.
So I ended up doing oil and filter, Rotella 10w 30. The Hydraulic fluid was low, so topped that off. I'll keep an eye on it.
How much of a hassle is pulling the pump?
/ B21 oil level rising? #7
1. Open the bonnet.
2. Disconnect the accelerator rod
3. Remove the fuel cut off solenoid
4. Remove the fuel filter bracket (6) mounting screws.
5. Disconnect the delivery pipes (2) to the flow priority valve and remove the flow priority valve.
6. Disconnect the suction hose (7) and remove the hydraulic pump
1. Open the bonnet.
g'day. That's for the fuel (injector) pump, yes? I was wondering about the pump for the drive and implements. The suggestion is that is what
may be leaking into the crankcase, tho I have yet to prove it out.
/ B21 oil level rising? #9
1. Open the bonnet.
4. Remove the fuel filter bracket mounting screws.
5. Disconnect the delivery pipes to the flow priority valve and remove the flow priority valve.
6. Disconnect the suction hose and remove the hydraulic pump
No, the hydraulic pump
Straight from the manual
/ B21 oil level rising? #10
You need to remove the fuel filter, rod and solenoid to get access for the rest, just have a look at the right side of engine and you will work it out.
1. Open the bonnet.
Thanks. I do have a WS manual, in fact, but somehow did not see that when I browsed before asking. Looks quite simple. Even for me.
/ B21 oil level rising? #12
So I ended up doing oil and filter, Rotella 10w 30. keep an eye on it.
Shell Rimula is closer to the Kubota oil as well as most major manufacturers of tractors factory oil. Rotella is just not as heavy duty.
Oh? I thought it was one of the best, according to a semi driver I know. Anyway it meets specs and Rimula is not available around here to my knowledge. Seems to be only 5 gal pails.
I expect I will be changing it pretty soon anyway, as, if the SUDT is leaking into it I won't want to keep that in there.
PS - It is available in quarts. Nice leg pull there, BTW - at the prices I've seen, no thanks.
/ B21 oil level rising? #14
I'd say ANY diesel oil available would work, why, because Kubota's spec is CC or CD, CE came out in 1985, CF in 1994...................
2026 Kearney 96"x 24' Gooseneck Trailer (A64119)
2026 Kearney 96"x...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2022 Kubota U10-5 Mini Excavator (A61572)
2022 Kubota U10-5...
Caterpillar Service Letters from 1980's (A63117)
Caterpillar...
YALE FORKLIFT (A63291)
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
