Adding a Backhoe to a compact tractor
   / Adding a Backhoe to a compact tractor #11
Regardless what that hoe is on, I don't like the outriggers at all.
Try filling the bucket, then swing to the left or right and extend the boom with that bucket full of material. Or try digging and filling the bucket in that position.
A backhoe of this size puts a tremendous amount of stress on whatever it's attached to. I'm guessing this hoe will drag the splitter around with no hesitation. Will probably do the same to your tractor. Make sure you have some means of locking the wheel brakes on the tractor with it in 4wd. Don't depend on a "park" transmission lock to hold the tractor.
   / Adding a Backhoe to a compact tractor #12
I bought my 1350 hour Ford 3400 TLB (10' hoe) thirty one years ago ( a cemetery machine )
Last year (1850 hrs) I did a complete refurbishment. Looks like new now! Always stored inside!
As you may understand from the low hours, whenever I do use the machine, it is often only for only an hour or so. I have a 12 acre property, in an area where EVERYTHING is VERY expensive!
Conceivably, I might have needed to rent the machine 500 separate times over the past 30 years.
Renting would be VERY inconvenient for me, and VERY costly.
I absolutely love having my little 44HP TLB always readily available.
I don't use just the hoe. I use the loader for the bucket, and for the forks.
I am too old to pick up heavy stuff. I use pallets for everything I think I may need to move again.
My Son and I are discussing going in together on a hoe. Expecting to spend $6-10K. Expecting to use it on average 20hrs a year. Also expecting, like you, to have it for decades. Renting doesn't fit our mold either. :)
Looking at a JD 310 now that's owned by a local farmer. He might use it 2hrs a year. I told him the other day if he sold it to us he could borrow it anytime he needs to. He's a young farmer trying to get started. I expect, with consideration, he will realize he can better use that money in farm equipment. :)
   / Adding a Backhoe to a compact tractor #13
That would appear to be an excellent arrangement for all!
Let us know when/if you are able to get it.
Once it is yours, you will wonder how you ever got along without it.
   / Adding a Backhoe to a compact tractor #14
Certainly will. I stopped by and looked at it today. It's in very good condition. No sign of abuse as in the front bucket is straight, no backhoe boom damage evident. I'm hoping we can make a deal on this old hoe. It's exactly what we need. No cab, no extendable boom, no 4wd. Just a simple machine. Fits us exactly. :)
   / Adding a Backhoe to a compact tractor #15
I bought my 1970 model 1350 hour Ford 3400 TLB (a cemetery machine, with 10' hoe and sub-frame) thirty one years ago.
Last year (1850 hrs) I did a complete refurbishment. Looks like new! Always stored inside! Paid $10,000. Possibly worth more than that now.
As you can understand from the low hours, whenever I do use the machine, it is often only for only an hour or so. I have a 12 acre property, in an area where EVERYTHING is VERY expensive!
At 77 years old, I am likely not that far from the grave, but I want to take my Ford 3400 TLB with me ...... to dig the hole!
Your TLB is a different animal. It's engineered as a package. Nice units, for sure! I contemplated getting one.
The OP is in a different position. The question would be whether the work to attach a non-CUT backhoe would be worth it. How much total work is expected to be accomplished? 1 1/2 acres isn't that large of an area. If that backhoe was sold how much would it fetch? How many equipment hours (using a superior tool) would that money buy?
Convenience has its price. The trick is to understand one's requirements and pocketbook.
If a person doesn't care all that much about money and they like the novelty of having a piece of equipment (and, perhaps isn't very good about planning), and just would like to "play," then that's a different story.
As my equipment rental guy says, know what things you need to do before renting: he shakes his head when he says that because many people don't!- he knows that I always have clear plans. I chart out all my projects: even down to the detail of what order based on travel distances. When I have enough to justify renting I rent. With 40 acres I can find many things to put equipment to work on. With the "right" tool I can get a LOT of work done, so the expense is worth it (my time is valuable- I'm not retired). My primary equipment need, however, is a tractor (for all the reasons your TLB is valuable to you, less the backhoe that is); had I bought a backhoe (which wouldn't have been able to dig out most of the stumps I have dug up [some larger than a pickup truck]) I wouldn't have had the money to buy a new (and much needed bigger) tractor.
Sometimes just because someone CAN do something that don't mean that they SHOULD.
   / Adding a Backhoe to a compact tractor #16
See how hard it is to take off the skidsteer quick attach and make up a 4 point mount for the tractor, have a Bradco 408 backhoe that was originally on a skidsteer and was changed over to a Kubota Grand L series and everything just bolted together.
David
   / Adding a Backhoe to a compact tractor #17
Your humor put a smile on my face. Fix up a hoe to dig your own grave! A true perfectionist. :drink:
   / Adding a Backhoe to a compact tractor #18
I see that you are in NE, Pa.
I bought a 1989 model 4x4 Ford 1920 FEL in Ottsville, (NE, Pa.) 3 years ago, 1056 hours.
A sweet little 32HP Shibaura diesel powered tractor.
Had it trucked to my place on Cape Cod.
It looked decent when I bought it,..... but now I have it looking/operating like new.
   / Adding a Backhoe to a compact tractor #19
Hello,
If itエs only for occasional lightweight work, go ahead and adapt the backhoe to your three point hitch however you can. Be gentle and careful with it, though. I broke a 24hp Kubota b7610 in half with a backhoe that was designed for it. Of course, I was abusing it. But it can happen to you! Hope it doesnエt, but keep it in mind.
I put the back feet down and it closed the gaping crack in the center frame. Welded it up and sold it cheap(er) to a friend that knew about it. Used the cash to buy an old deere 310d construction backhoe. That thingエs awesome! but now Iエve got to pay a lot to fix it up cuz itエs been abused too. But if you want to do a lot of digging consider changing out machines
Good luck!
   / Adding a Backhoe to a compact tractor #20
Grandad4 you are right. I did dig a hole with the unit mounted as shown,lots of rocks really pushed it . I did get the job done, but I bent the top link. I have since fabbed a anchor point for those two top mounting points. Now It's plenty strong on the splitter. Not sure If I can figure a way to add those mounting points to the tractor.
Take a look at what Woods sells for their "3point saf-t-lock" kit
Hello,
Good luck!
Could you expand on this tale? I've a B7610 w/ a Woods BH70X w/ subframe.
Midwestern Industries MEV Screen Model MEV 5X10-2 (A55315)
Midwestern...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2014 Ford F150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F150 4x4...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2014 Nissan Rogue Select S SUV (A55853)
2014 Nissan Rogue...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
