2" receiver welded into Mini-Excavator blade
/ 2" receiver welded into Mini-Excavator blade
I would have left the receiver a tad longer to accommodate the plug on the opposite end for storage. Or maybe it could be used as a step somewhere while in storage mode.
Can't do that - that'd be where I lost it to.
Pic of an ATV cargo bench carrying tools for the project.
I KNEW this 2" receiver in the blade was gonna be useful.
attachment.php
/ 2" receiver welded into Mini-Excavator blade #23
Now I want to see a picture of you guiding your boat trailer in the water. That would make the whole project worth it.
At 2.2mph (on the rabbit setting) it would take me 10 hours to get to the nearest lake.
Here's a pic of towing a trailer.
525199d1508396035-2-receiver-welded-into-mini-kx41_trailer-jpg
525201d1508396618-2-receiver-welded-into-mini-kx41_trailer2-jpg
Carrying the trailer uphill.
525200d1508396199-2-receiver-welded-into-mini-kx41_trailer_carry-jpg
It worked so well I'm inspired to build a dedicated trailer. Perhaps deleting the trailer-ball, using a solid drawbar & caster wheels. Drawbar hinged up & down & twisting.
/ 2" receiver welded into Mini-Excavator blade #27
Carrying the trailer... That's just funny for some reason.
Put a pintle hitch on it, would give you lots of articulation, especially if you put a swivel between the hitch & the trailer frame.
Able to carry the trailer is an uncommon luxury, actually. It never occurred to me before.
A tiny utility trailer with a pintle hitch would be truly funny though, worthy of "best of TBN". :thumbsup:
/ 2" receiver welded into Mini-Excavator blade #29
I may just have to steal your idea for my mini. It looks pretty handy.
/ 2" receiver welded into Mini-Excavator blade #30
If you had a hitch on each end, you could tow the trailer into a narrow dead end, unhitch, pick it up, swing it 180 degrees, then set it down ready to tow out.
Bruce
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
Giyi Gy-BS72B QA BoxBroom Sweeper (A60463)
Giyi Gy-BS72B QA...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
