which portable generators do people have
/ which portable generators do people have #81
I bought a 3.5 Kw generator from Princess Auto going on to three decades ago I've yet to use it and I haven't even put gas in it. 8 hp B&S engine on it. It was dirt cheap at the time (slight damage to the frame around it) but by the time I had heard about a generator losing it's ability to generate if left sitting too long, it was already too long! I knew it had to be reflashed but since I didn't have one of these it never got done!
Flash it yourself you don't need a tool to do it.. Iv done it several times to an old Honda I had...
/ which portable generators do people have #82
3500w Generac {20amp} for the irrigation pump {Intermittant use in pump house}
5500w Snapper (30amp} for home use
1000w 2cycle Chinese genny for random use out and about on the farm in the back of the Ranger
(Electric Pole Saw, Angle Grinder, Radial Saw, Air Compressor}
We've suffered through many a hurricane wth this set up.
/ which portable generators do people have #83
And the Briggs QuietPower actual DB rating is?
Stay tuned, pick it up next week. Going to run it compared to my EU2000i (btw the EU3000iS was quieter still).
Don稚 plan to measure sound at the exhaust: that will be pointed away from the house and will be at least 100 from the nearest house. I値l orient them both the same, and use a smartphone app, which I understand aren稚 super accurate.
If it痴 too noisy we can build a box using material from Soundown, a local company who makes sound deadening for boat engine compartments.
/ which portable generators do people have #84
I'm pretty invested in the Dewalt cordless ecosystem, so something like the $250 DEWALT DCB1800B Portable Power Station might actually make more sense for me.
A friend lives in NY on the Hudson. They lose power regularly, but usually for fairly short periods of time. He works at home and this was a PITA.
He bought a data-Center sized UPS (Uninterruptible Power Supply) with bad batteries and replaced them. Now he runs his internet, computers, heat circulation pump and a light or two through the UPS. If he loses power he can keep working (with heat) for 6-8 hours and everything comes back on automatically. Believe he spent less than $1,000.
/ which portable generators do people have #85
I bought a Electron LDG 6000S, diesel generator,, made in china but that's no problem for me parts are close ..lol I'm in the Philippines now..
/ which portable generators do people have #86
What kind of batteries did he use?
/ which portable generators do people have #87
5 or 6 years ago, we had a power outage that lasted several days and I didn't have a generator. We heat with wood and it was cold enough that the fridge and freezer in the garage never thawed out. After that, I bought an ETQ 6500 diesel generator and the power hasn't been off more than a few minutes since. I've used it for a couple of building projects away from the house and it does fine. It's noisy, but sips fuel and it doesn't go bad like the ethanol crap we get.
/ which portable generators do people have #88
That is the way it is. At the old house we lost power every other month it seems. Wired the house and bought portable gen set. Power was fine after that.
When we bought our farm one of the first things we did is wire for generator. Power is fine. If I never have to use the generator for its intended purpose then it has done its job.
I have moved it about the farm for portable power for certain jobs.
/ which portable generators do people have #89
I have a red one! The fuel tank is black plastic, But the frame and handle are red.
It has a Honda engine. I often wish it was a C50, then I could ride it around instead of just having it sit in the corner taking up space. ;-)
/ which portable generators do people have #90
Dont know exactly, nor how many.
Most UPS痴 use multiple 12V deep cycle batteries. The compact ones are motorcycle size but this thing was more the size of a small fridge.
Just learned of flywheel UPS痴. Cool.
/ which portable generators do people have #91
I'll throw the Troy Bilt generator I have out there. 7,500 watts, about 12 years old now with probably less than 200 hours on it. Purchased after Charley/Frances/Jean left us w/o power for a few days. Came in quite handy this year after Irma left us in the dark again, ran the fridges/freezers, well, microwave, phone chargers, a few lights, and portable AC without issue. It's a very basic unit, no hour meter, no voltage gauge, no time left to run on fuel calculator. But one of the things I really like about it is that it has the same B&S motor as our riding mower so I only have 1 set of spare parts to keep track of.
/ which portable generators do people have #92
After some tornadoes came through here Monday I put my HF/Predator 7KW rated generator to the test. Only needed it for a day and a half. Ran great, used less than 10 gallons. I did the bad thing and shut off the main / back-fed through a 30 amp dryer circuit. 2 freezers, 2 fridges, lights, well pump, coffee maker, etc ran fine. I had a few trees and fences down from the storm but nothing too serious. One area worker died cutting a widowmaker tree on a power line. Utility worker dies clearing storm damage in Alexander County; 1st reported fatality related to Monday's storm | News | hickoryrecord.com
/ which portable generators do people have #93
He installed a Reliance transfer switch. It is very easy and convenient: but requires 240v feed. Those Hondas and most other Inverter generators are 120v only.
No it does not! That electrician was an idiot. I installed a Reliance 220 transfer switch for an Honda EU3000i. Just tied the two hot lines together at the plug for the generator. Of course it limits the power to the house, but you are already limited using smaller generators. You do have to properly size the wire from the switchbox to the generator, of course.
/ which portable generators do people have #94
I had a big box store 6000w generator but it was so noisy we would do without power rather than running it. I gave it to my son.
We had a Honda Eu2000i and it was great until I couldn't get it started. Honda dealer had it for a year and couldn't fix it. I have the pieces out in the barn...
I have a Honda EU3000i and it has been fine but is heavy for moving around. I have it in the garage and wired to a Reliance switch. I miss something small and lightweight for moving around the farm.
/ which portable generators do people have #95
A Walenstien 5000 powered with a Honda . Bought it from a rental company and it looks like it too. Everything works and it starts on the 1st or 2nd pull after turning the gasoline valve on. Holds rock steady output voltage and frequency . A used 4000 Homelite with so many hours that it has 60wt oil in the crankcase to reduce the smoke and oil consumption. Holds rock steady voltage and frequency. Went cheap at an Amish sale, all it needed was a new carb. Splurged on a 5000W Generac that was deeply discounted after Y2K. Thought I had a deal then but have watched the price of that model and generators in general keep dropping to less than half of what I paid for it then. Starts and runs just fine. Holds good frequency control. However the voltage regulation is unacceptable and even dangerous. No load is 146V and full load is 104V. I have a generic external rectifier/regulator from eBay that will be installed one of these days .If it works I値l drag it to the daughters house, she hasn稚 more storage room in her garage than I have in my shop. Kicking around the idea of a large PTO generator or one of those Champion propane-gasoline 8000/10,000watt 459cc units. Model 100297. They loose some engine power with the dual fuel but that isn稚 all bad as now the generator head end is now oversized and more reliable . 8���-Watt Dual Fuel Generator - Champion Power Equipment
/ which portable generators do people have #96
This Craftsman generator came with the house in Mendocino County. No idea when it was made. It has a Generac engine. It always starts with one pull, or actually half a pull, it is very easy. There is a manual transfer switch and input receptacle installed near the garage breaker panel for running circuits in house and garage. I've never used it. The power does go out sometimes, but I can live with that for a day or so, by which time it comes back on. I run the generator every couple months using some power tools for a load, and keep the tank filled using a fuel stabilizer. It seems to be a good generator.
/ which portable generators do people have #97
If you tie the two hots together how do you prevent 220v appliance problems?
I've done it during construction but only after disconnecting/eliminating 220v loads...
/ which portable generators do people have #98
Mine is wired the same way so I can use my 110v generator. In a nutshell, you connect the circuit wire to the transfer switch (removed from the breaker), it goes through the triple throw switch (mine has 6) and then you wire the transfer switch back to the circuit breaker. The switches on the transfer switch isolate everything. When each switch is set to generator it breaks the connection to the breaker box and ties all those 110v lines to your gen, when it's set to "line" it ties them to the original breakers which are isolated. There is also a neutral spot where none are tied. You can connect the two center switches with a band to have 220v output setup but I don't use that.
transfer switch wiring diagram - Google Search
/ which portable generators do people have #99
That looks like my old Generac, re-branded I would guess.
/ which portable generators do people have #100
Missed the transfer switch part... thank you.
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A65563)
2007 International...
2021 John Deere 50G Mini Excavator (A62613)
2021 John Deere...
