Built me a log splitter.
/ Built me a log splitter. #41
I plan to move to North Georgia in a couple years and build a house there. I have lots of white and red oak on the >7 acres i purchased. I have been wondering what size splitter that I would need to split that. I have never operated one before. Most trees are in the 12 - 18 inch range with a few up to 28 inch. ...
Keep in mind that you'll need a way to get those big rounds onto the splitter ... a 24" long round of red or white oak 28 inches in diameter will weigh between 486 - 561 pounds.
/ Built me a log splitter. #42
That seems a little on the heavy side?...I usually figure about 45#'s cubic foot for oak...
/ Built me a log splitter. #43
I'd say green oak is heavier than 45 a cubic foot. Water is 62 pounds a cubic foot. Oak floats but not by a lot. I get around 470 pounds for that size piece assuming it's 55 pounds per cubic foot. But then I'd have cut wood that size 16" long which comes to about 313 pounds.
/ Built me a log splitter. #44
This is not typical but one that I had on my property that needed to be removed. 6 tree down.JPG
most will be smaller.
/ Built me a log splitter. #45
This is not typical but one that I had on my property that needed to be removed. View attachment 524711
Shame to cut that into firewood...
Roger that...I see some charts that have it (white oak) at 63#/CF wet/green...I normally cut wind blown, downed trees that have been down 6 to 18 months...there seems to be a never ending supply as a big oak usually takes down several others in it's path...the harder they are to get to the longer they lay...
/ Built me a log splitter. #46
This is not typical but one that I had on my property that needed to be removed. most will be smaller.
We had two high wind storms this Spring/Summer. I'm harvesting 19 large trees out of my timber. Mother Nature's way of "survival of the fittest".
/ Built me a log splitter. #47
That is a big tree, could get some nice planks out of that, but the background does not look like Florida to me, looks like North East, like my back yard, guess red oak grows everywhere.
/ Built me a log splitter. #48
Store bought 24 t is likely a 4" cylinder. It stands to reason a pair of 3" cylinders would out preform
Splitting force is proportional to the square of the radius of the cylinder. Therefore, at the same pressure, a 4" cylinder will have almost 1.8 times the splitting power of two 3" cylinders.
[Oops. I was comparing to a single 3" cylinder. Calculation corrected for two of them a couple of posts below. Thanks, LD1 for catching me]
/ Built me a log splitter. #49
ovrszd;4890393 For clarity said:
I disagree if you're burning in a tight stove. Small pieces dry better and you can fit more wood in the stove because they stack tighter. My stove will damper down enough to kill flames so I can make the burn time last as long as big wood.
My former business partner was a wood combustion guru (designed control systems for commercial wood boilers, designed a high efficiency, clean-burning residential-scale cordwood boiler, sole heat in his super-insulated home is a small wood stove in which he burns 1 cord per year - keeping his 1700 sq ft home at 70+˚ through a Vermont winter). According to him (and he had the scientific data and studies to back it up), burning smaller splits is more efficient than burning large logs - even if they are at equal moisture content.
Of course, efficiency is not always someone's primary goal. Some are more interested in saving labor splitting, or in getting a burn that will last through the night (easier with bigger pieces, which tend to slow the burn rate).
Choking down a fire (starving it for oxygen) to make it last may get you through the night, but it will drop your efficiency to ****, since the gaseous products of combustion will not ignite. A whole lot of BTUs will simply go up the chimney, unburned (or deposit on the walls of your flue as creosote).
/ Built me a log splitter. #50
Better double check your math.
Show your work if that helps;)
/ Built me a log splitter. #51
Yep - I blew that one. I compared a 4" cylinder to a SINGLE 3" cylinder. In that case, a 4" is 1.777 time what a 3" would be.
TWO 3" cylinders would be 12.5% more force than a single 4"
/ Built me a log splitter. #52
A handy log weight calculator, courtesy of the Forestry Forum. (calculates weight of green logs of various species)
/ Built me a log splitter. #53
Glad you figured it out. I figured that's what you did. Was hoping I wouldn't have to explain it
/ Built me a log splitter. #54
I agree. I stoke the shop stove at 5 p.m.-ish. Don't go back out until 7 a.m.ish next morning. Large rounds are still putting out heat. Small pieces are done. In the end a person should use what best serves them.
/ Built me a log splitter. #55
That downed tree was just an example. It and another were cut into lengths. I had a portable BSM cut it up.
/ Built me a log splitter. #56
Isn't it amazing how these conversations drift.
Sorry to the OP.
/ Built me a log splitter. #57
Sorry to the OP.
It's either let them drift or dry up.....................I couldn't give jack flip if my threaded post drifted, if I start a thread about chainsaws, you can talk about toaster for I care..................................
/ Built me a log splitter. #58
That's exactly right. Otherwise we'd have been out of stuff to say on the first page.
/ Built me a log splitter. #59
I can "at least" stay on subject! lol
We cut those "big ones" over an old wagon,
Then, it's pretty easy to roll them off the wagon right onto the splitters beam! (Read NO LIFTING!)
AND if you have a decent splitter with a strong 4-way wedge, it can push EVERYTHING through the 4-way,
No matter how big or tough it is,
and you end up with a nice pie of splits,
SR
/ Built me a log splitter. #60
Rob, why do you let your splits fall to the ground and then have to pick them up and haul to the wood shed?
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A61568)
2017 Autocar...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2019 F-550 Bucket Truck (A63118)
2019 F-550 Bucket...
CASE TV380 SKID STEER (A62129)
CASE TV380 SKID...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2001 Sea Ray 180 (A61569)
2001 Sea Ray 180...
