4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,162
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Yea I was wondering how they got 25+ tons outta those box store splitters. Finally put this one to the test on some really nasty logs. Outdid my buddy's store bought 24 ton.
A 5" cylinder with 3600 psi will get you to 35 ton.I was wondering that too. How do they come up with those numbers? I saw one advertised as 35 ton!
My splitter is a 42 ton, 6"x30" cylinder. I'm very spoiled.![]()
What kind of wedge are you pushing? I briefly considered putting a massive cylinder that was like a 10" bore on my splitter, but for a bunch of obvious reasons I didn't.
I plan to move to North Georgia in a couple years and build a house there. I have lots of white and red oak on the >7 acres i purchased. I have been wondering what size splitter that I would need to split that. I have never operated one before. Most trees are in the 12 - 18 inch range with a few up to 28 inch. I see from 15 ton to 37 ton advertized, but just wondering for now.
I push a flat plate. Wedge is at the beam end. Split the wood away from the cylinder. In my simple world that just makes sense. My wedge is a 2-way, 4way hydraulically raised/lowered.
Got her painted all pretty!
I'll bet you, any of the full size better splitters will split it, no problem...Not sure what will happen in a couple years when we retire and need to start splitting wood. Maybe a couple neighbors will suggest something. Or i may rent whatever is available a time or two. again I have no idea of the tonnage needed to split this wood. trial and error I guess.
ovrszd;4890393 For clarity said:I disagree if you're burning in a tight stove. Small pieces dry better and you can fit more wood in the stove because they stack tighter. My stove will damper down enough to kill flames so I can make the burn time last as long as big wood.
