Except that the all thread is SAE and the bolts on the chain bar are metric.
I'm an idiot, I use my bar. Just make marks with the chainsaw.
Usually only buck a little at a time.
I'm an idiot too. I scribe a line 16" & 14" (for one customer liking shorter lengths) back from the tip on both sides of the bar and brush bright red paint over the scribe marks with a thin brush. When the paint wears off the bar's surface I have a crisp thin red line down each side of the bar at 16" & 14".
Your thread tiltle reminds me of this bit:
Do you know the occupation of the Three Wise Men?
Firemen, they had come from a far.
I do too. I turn the saw as I move up the log. Line my "16 inch place" on the bar with the end of the wood and look where the tip is as I step into final position. Turn the saw on its tip and get after it.
This is exactly how I do it as well. The .5 seconds it takes doesn't bother me at all.I'm an idiot AND lazy. I just hold the bar sideways for a second and eyeball where the tip is. If I get tired I just go and ride around on my tractor for awhile to refresh myself.
As well, my fireplace is quite wide, so the length of the logs doesn't need to be very precise.
"Ho Man you are hard to please! I live out in the boonies."
PMS, we're not that different, altho 15 miles to the nearest town is probably closer than YOU are - if I wanted something hanging off my saws I'd most likely do it your way too, I was just pointing out possible options related to this thread - I have mig, tig, stick, plasma and O/A so if I want something done BAD enough it's usually gonna happen.
In my case, SOME of my saws are old and cranky (like me :laughingso those nuts might be USS - never had occasion to find out, and probably STILL won't... Steve
I think anything you attach to the saw is too Rube Goldberg.
If bucking a long log, I have a loggers tape measure and attach the hook to one end of the log, then, with the tape attached to my belt, walk to the other end of the log streaming the tape out behind me. I will either use a hatchet to make a mark on the log every 16", or use a scrench (screwdriver-wrench tool for chainsaws) to scratch a mark every 16". Easy and quick, and then I walk back down the log in the other direction with my saw making cuts, reeling the tape back in.
If I am working on shorter logs or don't want to use the tape measure, I have a 16" stick of wood that I painted the ends with bright green marking paint (what I had around at the time) to make it very visible. I will use that to pace out 16" chunks and mark the log with hatchet or scrench.
For firewood you don't have to be perfect -- shoot for 16" and eyeball it. When cutting saw logs, I am a little more careful.
I have my 8 cord of wood stacked in tree length, I put short forks on my FEL, scoop up 2-4 trees, swing them around to other side of wood yard, leave loader at waist high-ish and start cutting, if by my self I start on the heavy end till that seems light then go to the other side till I end up with 6' left on bucket, tip that off an finish, it's a lot faster when my son comes over than we're at both ends of the tree. When all said and done the tree lengh is at 0 and the cut up wood is in a pile ready for getting and splitting, this was supposed to be a short post what happened.................
Yep exactly what I do,bar is 16. I couldn't think how to word it.I do too. I turn the saw as I move up the log. Line my "16 inch place" on the bar with the end of the wood and look where the tip is as I step into final position. Turn the saw on its tip and get after it.
That's how I do mine with my forks. I can fit quite a few on 4' forks which I like. Just back and forth on the pile on the forks till it gets 5-6' wide then I dump them on a 8' wide saw buck with legs about 18" apart. Then all the cuttings will be 18" give or take an inch or so.
After I dump the 6' logs onto the sawbuck I run the tractor and grab another stack of half a dozen 10-15' logs. Then I do everything on the forks and the buck at the same time so I only have to start the saw 1 time for the whole cycle. Then repeat. Everything is cut at waist high unless I drop one somehow.
I hire a surveying company to precisely mark my logs![]()
