RSKY
Elite Member
- Joined
- Oct 5, 2003
- Messages
- 2,903
- Tractor
- Kioti CK20S
Mowing the CRP land this week. Only 24 acres but it can only be mowed, in 50-60' wide strips, every other year. B-I-L did it last year while I was down with a knee replacement. Either he missed some or the saplings popped back up after the 1086's wide tires passed over them because there were some trees bigger around than my arm. This year I'm mowing with the 4600 Ford. The lesson I relearned is that a sapling that big can pop back up after the front axle pushes it over. This happens when you make the second pass and have the twelve to twenty foot high trunk cut down to half size. First one got me on the right thumb which was resting on the fender. A limb on the second one took off my hat, glasses, and earplugs. That one HURT. Hat and glasses both landed on the mower deck which was good because it would have ticked me off greatly to have to buy new glasses.
Second lesson is that a thick growth of honeysuckle and blackberry vines on a slight slope can turn a 6-8000 pound tractor downhill even if it is being steered uphill. That was scary because I wasn't expecting it and was in low 4th gear moving pretty fast. I always keep my foot on the downhill brake so the tractor can be spun if it starts to go over. Yes, I had that happen once when much younger and much dumber. So I couldn't get on the other brake quick enough to keep it straight. Just made a big circle and took off again.
Yep, I'm using a 41-year old Ford tractor and a 45-year old Ford mower once again. The old mower has been welded, bolted, chained, sledge-hammered, and cussed for years but it still chews up anything the tractor can push over. The top decking is nearly rusted thru in places and I'm going to replace that next year before it throws a chunk thru the deck and up onto the driver's seat. Those old mowers bring a good price still because they are so tough.
Because this is the sixth year of a ten year signup I've got to get the disk out, hasn't been used in three years, and disk the fields in 50-60' wide strips. I should have been able to get this all done in two days but gonna take me three because I broke a brace on top of the mower and had to repair it.
Tractors are FUN!!
RSKY
Tractors are FUN!!
RSKY
