3320 Hydraulics driving me crazy!
/ 3320 Hydraulics driving me crazy! #1
Justjake450
Louisburg, ks
Hello all new here looks like a great forum to be a part of here! I hope i'm in the correct section for this and really hope someone can help me out! I have a 2012 3320 with just short of 400 hours on it, love the tractor but its always has had what seems like an issue with the hydraulics. the loader, 3point, and rear remote sound like they have air in the system some times. and will chatter and shake. everything else works great. machine has no leaks at, i have changed the fluid and filters didn't see any issues in there. system pressure is within spec at 2450PSI and charge pressure is around 250PSI. its interesting because with a gauge hooked to charge pressure i can see the needle drop a little every time the system will chatter. dealer says this is normal and act like they don't really want to chase this down! Maybe i'm just being picky but this cant be normal or good on components any help or leads would be greatly appreciated!
/ 3320 Hydraulics driving me crazy! #2
Ok there was an issue about the pump outlet line chattering because it wasn’t clamped good. Heard pretty clear in cab and was mistaken for pump chatter. Check your hard lines to and from pump and where they are clamped. Maybe that’s the issue.
Report back!!
/ 3320 Hydraulics driving me crazy! #3
Another thing. You are using low-viscosity hy-gard correct? Check hose clamps at pump as well make sure they are not sucking air.
You can see the loader shake when it does it so i think its more than just a sound actually but I can see how those could be mistaken!
There was a crack in the inlet manifold boot to the charge and what I think is steering pump. replaced it and installed new clamps with and it didn't seem to help any! all hard lines also seem to be tight i've gone over every fitting I can find or get to I am using Lo-vis fluid but it seemed to act the same with the factory break in oil.
Thank you guys for the input! I'm open to try anything
/ 3320 Hydraulics driving me crazy! #5
The loader hydraulics on my 2008 3320 will "chatter" for a few seconds after I first start it up for the day but after that I haven't really noticed it. Just assumed a little bit of air gets in the pump after it sits all night. Haven't felt it in the 3pt or rear hydraulics.
sounds similar, you can definitely notice it most at first startup after sitting! maybe its not just me still wouldn't think its normal
/ 3320 Hydraulics driving me crazy! #7
I think all my tractors will shake- shudder @ the hydraulics upon startup. It is very pronounced if you're aggressive with the controls - full joystick back, etc. Much less noticeable if you gradually ease into raising the loader or a 3pt. Implement.
No problems after startup or use during the day.
Sounds like you know exactly what I'm talking about. If you ease into it, much less noticeable but it continues through the working day and after start up
/ 3320 Hydraulics driving me crazy! #9
Well... that's a different situation - if you continue to have hydraulic performance issues after the tractor is warmed up and working.
There could be something else going on with your tractor.
When you changed out your hydraulic oil and filter, did you clean the sump filter? It could affect hydraulic performance if it's partially blocked.
I replaced the main filter in bottom of machine and cleaned the inline screen. I didn't think it had another filter! where is sump filter located on a 3320? Is it worth checking even though i didn't find any debris in the other filters?
/ 3320 Hydraulics driving me crazy! #11
My JD 3520 Operator's Manual has no mention of a sump filter. Not sure if it exists on the 3000 series.
OMLVU17926_J7
/ 3320 Hydraulics driving me crazy! #12
Sump filter and screen are one in the same. I have a 4710 that shows some chatter now and again weather its the backhoe, grapple or just using the loader. always done it since new, no rhyme or reason and don't matter hot or cold. may go weeks with nothing then feel a couple hits and all good again for quite a while ........???????
I hate to just deal with something that could be causing damage but that might be my only option!
/ 3320 Hydraulics driving me crazy! #14
After a tour on JDParts, the 3320 does not have a sump screen. Based on your earlier post, you have changed both of the hyd filters. So, that leads to another search for the solution to the problem.
Hydraulic oil frothy or foamy? If you have an air leak or water entrainment in your hyd oil - you'll see that on the dipstick.
When the main hyd pump died on my tractor, it failed in progressive stages. Not an immediate crash. Intermittent loader glitches - loader would not lift off the ground. After ramping up the engine RPM's, the loader would finally lift.
Reverser transmission wouldn't shift F or R quickly. Long pause before trans would engage.
3pt would not consistently lift up or down. Similar to loader symptoms. Usually would finally lift after running the engine throttle up - alot!
Finally, after about 2 weeks or so of glitchy hydraulic performance problems; loader, transmission, 3pt hitch, the steering began to fail!
Now... When a problem of this kind develops - you will see metal particles - in your filters, eventually you could find them collecting in the hyd oil at the drain plug site in the transaxle housing.
All this aside...I don't think you have this type of problem with your 3320. At least, from what I've read in your posts.
/ 3320 Hydraulics driving me crazy! #15
---If-- your tractor is doing the same thing as my 03 4710 which is a light split second glitch, Mine has done it since day one and now has a sliver less than 1500 hrs on it. it's not at all bad in my opinion and is a seldom occurrence. oil is always clean and never foamed. I change the oil, filters and clean the screen every 400 hrs. with Deere filters and low visc. hyguard. always the same and has never changed nor gotten worse.
No foamy fluid, and will seem to do it just about every time I lift the 3 point if I have something heavy on there. but it doesn't seem to have changed any within the 250 hours or so I have put on it. I thank you all for your input!
/ 3320 Hydraulics driving me crazy! #17
Here is a link to some info on the hydro fluids, and mention of tranny chatter.. with what seems like a Deere product to modify friction.
PMB Product:
Not sure if it may help.
/ 3320 Hydraulics driving me crazy! #18
The product that addresses chatter is for brake chatter. It will not affect hydraulic chatter.
could the priority valve be causing this. from what i understand its directly fed by the charge pump and since i can see charge pressure drop with the chatter..not sure if it could be just doing its job or have an issue
/ 3320 Hydraulics driving me crazy! #20
Was this ever resolved? I'm having similar issues
