New LS Sub-Compact
/ New LS Sub-Compact #121
I see that RCO tractor lists the MT122H for sale now. It is not even on the LS tractor corporate website yet. It looks to be the same tractor with just lower HP.
/ New LS Sub-Compact #122
I note that the loader lift at pins on the LS MT125 is 1007 while it is listed at 886 lbs at the pins on the new LS MT122H. Same LL1100 loader, so that tells me that the displayed info is possibly not correct or it can be possible that the hydraulic pressures are being reduced to cause more of a separation between the 122H and the 125H with a $1,000 price disparity?
Copied from the RCO website for the LS MT122H:
Specifications
21.5 HP 3-cylinder, Indirect-injection, Water-cooled Yanmar 3TNV76F
PTO HP: 15.0
Rated Speed (RPM): 3,000
Fuel Tank Capacity (gal): 6.6
Transmission: Hydrostatic Drive
No. of Speeds: 2 Ranges
Brakes: Wet, Multi-Disc
Independent PTO
Mid PTO: Standard (2500 rpm)
Rear PTO: Standard (540 rpm)
Category, 3 pt hitch: CAT 1
Hitch Lift capacity (lb.): 970
Overall length with 3pt (in.): 97
Wheelbase (in.): 56
Min. overall width with IND tires (in.): 47
Height to top of ROPS (in.): 87
Weight (Tractor & Loader): 2,353 lbs
Loader Specifications
LL1100 Quick Attach, Front End Loader with Grill Guard & 50 Bucket
Maximum Lift Height (@ Pivot Pin) (in.): 72
Clearance with Attachment Dump (in.): 50
Reach at Maximum Height (in.): 26.5
Maximum Rollback Angle (deg.): 45
Maximum Rollback Angle (deg.): 28
Digging Depth (in.): 4.7
Overall Height in Carry Position (in.): 41.5
Lift Capacity (@ Pivot Pin) (lbs.): 886
Backhoe Specifications
LB1107 6 Quick Attach Backhoe with available 9? 12 & 16 Bucket
​ Digging Depth (in.): 77.8
Reach from Centerline of Swing Pivot (in.): 144.9
Loading Height (in.): 59.6
Swing Arc (deg.): 140
Transport Height (in.): 74.7
Bucket Rotating (deg.): 169.4
Stabilizer Spread (Down Position) (in.): 78.6
Stabilizer Spread (Up Position) (in.): 53.2
Bucket Digging Force (lbs.): 2,097
Shipping Weight (lbs.): 873
Mid-Mount Mower Specifications
LM1160 60 Quick Attach Mid-Mount Mower
Cutting Width (in.): 60
Overall Width (in.): 75.6
Cutting Height Range (in.): 75.6
Deck Shell Thickness (in.): 0.126
Spindle Speed at 3000 RPM: 2,786
Blade Tip Speed (ft./min.): 14.932
Number of Blades: 3
Blade Length (in.): 20.5
Blade Width (in.): 2.48
Blade Thickness (in.): 0.236
Shipping Weight of Base 60 Deck (lbs.): 284.4
Additional Options Available
Draw Bar
Rear Remote Valve - 1 Set
Work Light
Detent
LS specs coming soon.
* Prices & specifications subject to change without notice. Call for latest details.
* Special order models are subject to a small freight surcharge. Call for details.
/ New LS Sub-Compact #123
LS has published two different numbers for the MT125 loader lift capacity (886lbs on the website and 1,005lbs in the loader manual, brochure, and elsewhere on website). So I am not sure how much to trust any loader lift numbers.
/ New LS Sub-Compact #124
I too, have not been able to get a precise number from LS. However, I just used the loader yesterday to lift a bunch of bagged concrete. I had 14 - 80# bags (1120 lbs) in the bucket and had no problem lifting the bucket up 3-4 ft. The front tires were screaming (I first thought I had a flat), they looked very very low. I was getting lazy after moving my first load of 8 bags, and just wanted to be done with the task, hence loading it up with the 14 bags. Would I constantly load it heavy like that? Probably not. I was also only operating the tractor at about 2000 rpm when lifting the heavy load.
As for the MT 122, they don't list the hydraulic pump output. I think that may play in "de-rating" the loader if the output is less. I was suddenly shocked when I looked at the RCO site this morning before reading your post.... I saw the price first and had a near fainting episode thinking they lowered the price on the 125 !!. Then I saw it was a 122... Able to breath now.
/ New LS Sub-Compact #126
Hi guys, I wanted to help reduce the confusion, but I guess I'm really just going to wallow around in it with you for a minute. The original draft of brochures we got on the MT series said loader lift cap. was 886 lbs and that's what we published on our site. Once the tractors started arriving and we got the final glossy brochures the rated capacity had been up'd to 1,007... so we updated our numbers accordingly. They have those brochures printed in big quantities and sometimes numbers get updated but the old brochures are still floating around confusing people... so generally we view the LS website as the most up to date specs. I just discovered the same thing that ThirdMan did... they have conflicting numbers on their site. I suspect that the series page just didn't get updated to match the new spec, but that's an educated guess. We have not had a chance to do a real world lift capacity test on these models, but that's on our mile-long to do list. Every LS loader we've ever tested out-performed their claimed numbers (and every competitor's numbers....nanny nanny boo boo!). So, based on past experience I have every reason to believe that the 1007# number is the right one, but I'm not betting my left arm on it until I have a chance to actually test it. I know LS is working on more web improvements so hopefully we'll see these inconsistencies ironed out soon.
/ New LS Sub-Compact #127
Thank you John, that does help. I have wondered if the lower number was with an SSQA bucket that they decided not to provide. The only time I have run into the limits of the lift capacity was with clamp on pallet forks with weight way out from the pins. Without the backhoe on it is pretty easy to make the rear tires light so I try to only move heavy items with quite a bit of rear weight.
/ New LS Sub-Compact #128
I have lifted many bucket loads of damp almost muddy dirt. The tractor lifted it smoothly. To this point, I love my LS MT125 TLB minus the stupid 3pt hitch setup.
/ New LS Sub-Compact #129
Finally got through all your videos Rider. They are currently the most comprehensive information readily available on the MT1 series. If you ever find yourself in south central Texas, drinks are on me.
I spoke to a dealer today about the 3 point hitch issue and they initially argued with me that there was no such problem, but to their credit they were polite about it and when I didn't relent they dug deeper and confirmed the issue to me, apologized, and apparently the best information they could find at the moment was a fix to be available in the March timeframe.
/ New LS Sub-Compact #130
Thanks you for the drink offer. I my take you up on it. I love Central Texas. I don't think they are pushing the issue hard, because it only affects the MT1's that have the backhoe. I guess March is better than nothing; however, I find it to be a bad business practice to ignore the problem and sell it to unsuspecting customers impling it works just like every other Sub Compact with a backhoe.
I bought mine at a large dealer in AR. They have sold many of the MT1s and was very aware of the problem. They did not tell me anything about the problem when I drove over to pick it up on the day of sale. I called back after I took my backhoe off and the problem presented itself. One of their guys in service told me, I should have done better research. Luckily , I found a new local dealer which is very honest; however that dealer in AR and at a corporate level are not handling the problem as I would. I called and email LS Corporate office and found they were aware of the oversight. They told me the fix was on the way back in Oct 2017. One of the corporate officials told me they hated Tractor by net, because people talked about what they did not understand as if it was the customer's problem to understand corporate issues. ( I still have the Email. He had sent it to another dealer forgetting I was in the email chain) They don't seem to be pointing the problem out to the small local dealers or customers. I find this a very poor business practice. To bad too! The LS MT125 TLB is a diamond minus the three point hitch issue. It is one of the better built Subcompacts on the market with many great refinements. It has a kick butt hydraulic system and has great fit and finish. Again, minus three point hitch issue.
/ New LS Sub-Compact #131
I wasn't sure what you were talking about with the 3 point issue. Now I understand that on the backhoe version, you have to remove the rear wheel to install th3 3 point lift arms, plus a few other kitchy issues. The video below shows that a little better. The corporate response has shown a tin ear.
On a different note, my observations about LS from this forum are:
1. LS owners love them
2. Their website is not up to date, accurate or good.
3. Some excellent dealers are way better about understanding and promoting the product (videos) than corporate marketing.
4. Their response to the TLB 3 point issue has been arrogant
5 If they were smart, TBN is a goldmine about how they could improve the customer experience/improve product/increase sales. They do not seem to be that smart.
6. LS owners do appear to be smart :)
/ New LS Sub-Compact #132
I did some more refinements to my hitch system. I did a total of four videos on the hitch.
/ New LS Sub-Compact #133
The New Holland Workmaster 25S is listed on their website. They don't have a brochure on their website to download yet. Looks very similar, though they have added some lift capacity to the 3-point. Pin on bucket, no ssqa listed.
/ New LS Sub-Compact #134
Those look just like the LS MT125-122s in every way right down to each bolt. LS makes most of NH's smaller tractors, so it stands to reason, they just re-branded the LS MT125. I have very good service out of mine. Tony's Tractor Adventure.
/ New LS Sub-Compact #135
I don't have a tractor yet, but it's going to be the MT125. I just watched a video by Tractor Time with Tim (as well as all of Tony's videos over the past week) and Tim mentioned a "position control on the three point hitch" and that not all tractors have that control. Here is the video, and he talks about it at 11:51 Mowing a Jungle - Brush Hog 21; Prerequisite: Dad 11 (or equivalent) - YouTube .
Does the LS have this control? It probably won't matter for me, but I plan on buying just once and it's good to know.
/ New LS Sub-Compact #137
Thanks for your comment!
Philip’s LS did not have position control. Do you have a decent understanding of what we mean by position control? If not, you could discuss with a Deere dealer, as the 1023e does NOT have it, but the 1025R does have it. They could show you the side by side...or perhaps I should put together a video on this topic?
If you do understand position control, I’m sorry. No intent to be condescending. Just trying to help.
Tim
/ New LS Sub-Compact #138
Tim
Thanks for the reply. I did some research and I now understand what this control does. You said it in the video but I wasn't sure I understood properly having never used a tractor. Another thing I like about the Deere and Kubota is where the loader control is located, it just seems right.
It was the video where you visited Philip that I learned about LS Tractors. There are no LS dealers in my area but when I saw his blue tractor I wondered about it and discovered LS. Thanks for that:)
/ New LS Sub-Compact #140
Yes, thanks for that. The LS is very misleading about this. My very local dealer has one on sale and I was going to look at it, but I really want position control (as my B2620 doesn't have it, if I had known what it was, more importantly, how important for certain tasks, I might have got the B2630 that has it, but it was bigger and I didn't, and still don't a decade later, want or need bigger).
The LS site says the 3 point hitch has position control, but the pictures of the lever and reading the operator's manual indicate, this is not the position control you seek.
2019 K&K Trailer, VIN # 1K9PE2029KA175462 (A65563)
2019 K&K Trailer...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
