New LS Sub-Compact
/ New LS Sub-Compact #81
What's the procedure for mounting/removing the belly mower? Jack the tractor up with the FEL and slide it under? It does not appear to be a drive-over.
/ New LS Sub-Compact #82
You turn and pin all the wheels in the sideways position. Drop it to the ground and unpin two pins on the back and one on the front subframe. Disconnect the PTO. And the mower rolls away to the side. It is not drive over.
/ New LS Sub-Compact #83
Remember grease gun nozzles are adjustable:. Loosen it a bit.
If you still have questions: please read this thread.
http://www.tractorbynet.com/forums/...ase-gun-screwdriver.html?highlight=grease+gun
Thank you! I read some of that thread. Looked at the two nozzles I had (different brands) and was still stumped. I showed my wife and we got a vise grip and wrench. After mangling the nozzle some more I finally got it to turn. I don't know why they tighten it so much, but it is ridiculous! Now I can grease the recessed zerks.
/ New LS Sub-Compact #84
I had 4 tons of rock delivered. The MT 125 was able to scoop up a full bucket of the 1 inch clean. We only did that twice, most of the time we were taking about 3/4 full loads. Not lifting to full height except to settle the rock even in the bucket. Still getting used to the loader and trying to reduce the jerkiness when making adjustments. I move or release the stick and the whole tractor jerks. The backhoe seems to be adequate ballast for this work.
/ New LS Sub-Compact #85
Nice looking shovel and wheelbarrow. Sure beats doing it by hand. Looks a lot like my XJ2025 with smaller sneakers....
/ New LS Sub-Compact #86
image.jpegimage.jpegimage.jpegimage.jpegimage.jpegHere's a few photos of my current project: doing a septic system for the new house I'm going to build. So far have the 1000 gal tank in place (the hole was 8' wide, 12' long, and 6' deep), the cross trench, and 1 run of the leach field ( need 2-56' long and 5' deep)dug. There's a pile of 38 tons of 1-2" rock that will go into the trenches. This little tractor does not cease to amaze me! Have 36 hours on it already and ordered all the filters for the 50 hour service.
/ New LS Sub-Compact #87
Holy Toledo, you're working that thing like a rented mule! :eek: Nice work so far.
/ New LS Sub-Compact #88
Looking good! That is some extensive work! Have you used that tooth bar you bought? I was considering it for helping dig out bush honeysuckle and other light digging.
/ New LS Sub-Compact #89
The tooth bar made a dramatic difference in digging / grading the dirt. I was able to take off the surface grass and topsoil w/o too much effort. It really made a difference breaking into the hard clay / dirt. Well woth the $199. For picking up the stone, I took it off.
/ New LS Sub-Compact #90
The HST pedals seem to have gotten sloppy. When taking my foot off a pedal they don't return to a side by side position. I also think my travel speed is reduced. It does come to a stop when the pedal is released. I am looking at page 5-13 of the manual about adjusting the HST control linkage.
/ New LS Sub-Compact #91
Yes I had to adjust mine too. I have 49 hours on it and the forward pedal almost returned but not quite. It made it difficult to shift between the high and low range until the pedals were equal. After the adjustment, no problems. I'm still working the heck out of it and no other problems. Make sure you grease everything, when I did the first grease service, one of the loader pivots took a lot before it squished out and I mean a LOT. I'm going to do the first 50hr service tomorrow, I'll post how it goes. I wasn't too happy that it cost me $112 for the filters (I did get 2 oil filters). There are no cross references because it's so new. I did find out that the HST filter is the same as the J2020.
/ New LS Sub-Compact #92
See my post under "operating" , what a PIA to change the oil!
/ New LS Sub-Compact #93
I need to look at these! Just did some research today, really impressed with the spec's, and have a dealer about 50 miles away. My short list is the Kubota BX2380, JD 1023E, and now the M125. Seems like a lot of tractor for the price, compared to the others on my list. I have the JD priced at $13065 w/FEL, the BX at $14225 w/FEL, and the M125 at $12600 w/FEL.
Other than the very disappointing oil drain plug situation, seems like everyone is pleased so far. I will take a close look at that when I see some in person next week. Makes wonder what other over sites may exist that we can't see so obviously.
I like the blue, too! :thumbsup:
/ New LS Sub-Compact #94
I don't have much experience to compare it to, but I am loving mine. We have about 20 hours on our so far, and it is getting lots done.
/ New LS Sub-Compact #95
Looking forward to kicking some tires next week!
/ New LS Sub-Compact #96
When I started shopping, went to the green dealer first. Saw and sat on the 1023 and 1025. The fenders were all plastic (not a good thing in the SW). The lift capacities of the fel were less, the BH had less reach, depth and pressure. In order to get the seat w/ armrests, had to get the 1025. The quick attach fel was extra. The green tractor was off the list almost immediately (even the wife was extremely disappointed) went to a Red dealer, (Mah.....) and was just as pricey and the fit and finish was not that great. Checked w/ 3 dealers and none could or would do any better on the price. Went to the orange dealer and left within a few minutes.... They were really proud of the price.... The BH was 20% smaller and the fel bucket was smaller. All of these other tractors were also 22 hp (except the 1025) the LS was 25 hp (same Yanmar that was in the 1025)! Now if you compare the LS has cruise control, tool box, awesome seat w/armrests, grill guard, quick detach fel and BH, and the MMM can be added or removed while BH is attached...Sold me on the LS. I had made a side by side detailed list of all the sizes, specs, hp, etc over 3 days (also included the other orange tractor w/ a K) and they were no comparison to the LS. In one of my previous posts I stated I drove over a 1000mi RT and 22 hrs later to pick up the tractor. I bought it sight unseen after looking at the others. I have not been disappointed! If you look at the project forum, I have pics of a septic system that I dug. My final price was $16,900 for the TLB w/ 12" bucket and post hole digger w/ 9" auger. (Dealer listed $6000 in rebates on the paperwork). My only regret was that I didn't get the mower in the initial deal. It's now gonna cost me $600 more than if I did it w/ the pkg.
/ New LS Sub-Compact #97
Oh, I also liked the "no frills" 6 yr warranty (see LS website)
/ New LS Sub-Compact #98
All valid points, and I've come to a very similar conclusion myself. As far as value, based on paper, the LS is hard to beat. I also appreciate your real world experience thus far.
My concerns are based on lack of product out there for a broad base of problem awareness. Since they are relatively new in the NA market, parts inventory may be an issue, along with dealer support. On the plus side, they've kicked butt in the last two years of mfg'r/dealer surveys, so they must be working hard to do things the right way. That's encouraging.
If I'm satisfied with the "live" product, and the dealer, I'm really leaning this direction. The (perceived) value is hard to walk away from.
Current quotes for my top three are: (all include quick mnt FEL, no MMM, no tax) MT125 - $12,600, JD 1023E - $13,065, & Kubota BX2380 - $14,225
/ New LS Sub-Compact #99
I don't think you would go wrong with any choice. You have very valid points about the support of dealers / parts. I'm a hands on person... Haven't taken a vehicle to a mechanic for 30 yrs.... I'll fix it myself.. I understand that repairs and service aren't for everyone. I have 2 sons, 18 mos apart, one has restored a 74 jeep pickup and even converted it to a military diesel in the driveway w/basic tools. The other doesn't know how to use a screwdriver... Go figure... I looked at the tractors from a totally different perspective. Sit on them, play with the controls, see which one is comfortable for you. It needs to "feel good" to you. Good luck with your choice.... Keep us posted on what you get
/ New LS Sub-Compact #100
Have to wait for the "hands-on" for an honest assessment of the MT125, but I agree that I would probably be happy with any of these. My goal is to pick the best of the best, so to speak.
Like you, I also fix & maintain my own stuff. So, the concern is just getting the parts I might need, and if there were any serious warranty work that would require dealer involvement. I think I'll get a good feel for that once I visit with the dealer for a bit.
Will definitely keep everyone posted as I move along....hoping to decide & make the purchase in the next week or two.
Appreciate the honest feedback!
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
7888SFL (A61567)
7888SFL (A61567)
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
