Using backhoe as grapple ...
/ Using backhoe as grapple ... #1
CincyFlyer
West Chester
Mahindra 2540
Whilst I save up some bucks for a lightweight EA grapple, I had some brush that needed moving. I've been doing a lot of it by hand, or pushing it with the bucket, or on the forks, but I was destumping the creek bank, and thus had the backhoe attached ... and did a few loads like this.
It worked quite well, as long as I grabbed enough stuff to keep it compressed against the stick. No hoses were endangered. At the point I'm gonna have to get a thumb, so I can have a mini-grapple all the time.
I'm sure everyone has done this, I have no idea why it took me so long to figure it out.
/ Using backhoe as grapple ... #2
My backhoe has hoses exposed under the boom so I try to never crowd stuff against that area like you have done in the photo. I did install a mechanical thumb and it has proved invaluable for moving stuff. Not nearly as handy as a grapple would be. I have tried a couple different clamp on forks but the 8000 lb loader on my machine makes short work out of trashing them.
Yeah, my hoses run on the top, except where they cross the joint. This is not the way I plan to handle brush in the future! It was just a quick and dirty way. My tractor is a toy compared to yours (with 4x the lifting power!)
/ Using backhoe as grapple ... #4
I use my backhoe like that to carry big stumps and trees when they are too big to put in the FEL. Works great as long as you don't have to go between trees. All my oil lines are well out of the way.
/ Using backhoe as grapple ... #5
Any backhoe I've ever seen has the hoses inside the boom. I don't think any damage is likely to result. Even then if a hose was all I tore up I'd be happy.
On most smaller backhoes, the hoses are on the outside (see my picture, above.) I don't know why any would run on the underside of the thing, but apparently some do.
/ Using backhoe as grapple ... #7
Yup, did the same before I got an EA grapple, now its much easier to pluck and place rocks (don't have a thumb on the hoe).
/ Using backhoe as grapple ... #8
I suppose that can work, but a mechanical thumb is cheap, and far superior.
I had one custom built, but inexpensive aftermarket thumbs are readily available.
/ Using backhoe as grapple ... #9
/ Using backhoe as grapple ... #11
I thought of going with a thumb, and my tractor is actually set up for one (no welding!), but Mahindra values it dearly (over a grand!) At that point, I'm halfway to an EA grapple.
You can buy an aftermarket manual/mechanical thumb for under $500.
Yeah, but then I'd have to weld the brackets. Mine has them ... for a Mahindra (TYM, most likely) thumb.
/ Using backhoe as grapple ... #13
There are several bolt on type units available also.
/ Using backhoe as grapple ... #15
My backhoe thumb got used quite a bit. I liked it better than my grapple for cutting firewood. IMG_9374.JPG
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
2012 Chevrolet Silverado 1500 Pickup Truck (A61573)
2012 Chevrolet...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
INTERNATIONAL 720 - 6 BOTTOM PLOW (A63291)
INTERNATIONAL 720...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
