Loader DYI 3rd function valve on L3301
/ DYI 3rd function valve on L3301 #1
ProjectKing
USA
Kubota L3830 FEL, Kubota L3301 FEL/BH, Ford Golden Jubilee, Honda Foreman 450ES, Polaris Ranger 400, Kubota ZD326, etc, etc
Hello, I'm strongly considering purchasing a grapple for my L3301. Of course I will need to install a 3rd function valve and switch.
Has anyone made their own 3rd function kit? I'm not crazy about how some of the commercial kits mount. It is beyond me why Kubota doesn't offer their own 3 function kit option for the tractors.
If you have made your own, use a Landpride kit or a WL Long kit I'd love to see it. Needing ideas about what I need to buy and fabricate.
Thank you
/ DYI 3rd function valve on L3301 #2
The L3301 is identicle to my old L3200... http://www.tractorbynet.com/forums/showthread.php?t=295816
I'm assuming you mean 3rd function up on the loader where my 3 extra spools went on the rear. You also didn't specify diverter or 2 3rd function. I believe most of the kits you mentioned are diverters. Be VERY careful if you install a diverter on your curl circuit. Read up on Regen & know that your machine has a Regen only dump. Not an issue if you tap the lift circuit
Sorry for lack of details. I want to install an electric over hydraulic 3 position solenoid valve to control a grapple mounted on my front end loader. The valve is plumbed and attached near the front end loader control with an electric mounted switch on end of loader joystick. Valve is not a diverter valve but a true 3rd function valve.
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
96" X 20' 5TH WHEEL HOOKUP TRAILER (A59823)
96" X 20' 5TH...
Mobile Display Rack (A59317)
Mobile Display...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
