Digging potatoes
/ Digging potatoes #1
cmyoung2
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
Dug a few potatoes just before Irma's rain. BCS 850, potato/root crop plow. Spread the wheels out with a 2 1/2" and 6" extension on each side. Used 40lbs of barbell weight each side, tires are foam filled, 25 lbs each, and the 6" extensions are filled with 8 lbs of lead each. Did a great job, but probably needed all the weight, digging deep with a fairly heavy weed load.
/ Digging potatoes #2
my advice is to mow the potatoes and weeds ahead of tie, let it sit a few days, then plow em up. use a flail, if ya got it, then maybe you don't have to wait long or at all to plow.
/ Digging potatoes #3
I like those wheel extensions!
Mowing or flailing the weeds and tops is a good idea. Less trash to sort through.
Mow a week ahead of your harvest date to allow skins to "set". This will minimize bruising and be especially beneficial if you are planning to store them. If storing in a root cellar or otherwise do not wash the dirt off until you plan on selling or cooking them.
Terry
/ Digging potatoes #4
Looks good.
Totally off topic but what do you use the 'quick hitch' on the front for? (if that's what it is).
/ Digging potatoes
I did mow the weeds before I plowed, love the flail mower. But there was still plenty of roots to slow things down.
The quick hitch on front is for a caster wheel to help when moving the tractor with no implement.I'll try to get a picture. I also use it to attach about 30 lbs of barbell weights to offset the double rotary plow.
/ Digging potatoes #6
That's a great idea, I have the same problem especially with the diesel engine.
/ Digging potatoes
IMG_0627.JPG Here is my version of a front caster, copied the idea from some else here. I need to make some corrections,I have too much slop in the connection, the wheel doesn't track like I want, tends to catch on the motor guard. but it really does help transport and hooking up implements. Adjustment will be a winter project. Not real sure why BCS doesn't make it as an accessory, but I would probably try to build it anyway.
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
Ford 8510 (A53317)
Ford 8510 (A53317)
