What is this item?
   / What is this item? #1
John Fitzgerald
Gold Member
Elkins, Arkansas
XJ2025H same as NH Boomer 24
What is this?
It was found in an old woodshed.
   / What is this item? #3
Valve? spring compressor.
I don't think that is right, but it is what popped into my mind. I've seen that tool in several old farm shops, and almost feel I've used one, but it was so long ago I can't remember.
Bruce
   / What is this item? #5
Almost an hour looking with no luck. Very frustrating. My mind recognized the image at once, but lost the caption. :(
One of the "benefits" of getting old. You have to delete memory in order to make room for new downloads.
Bruce
   / What is this item? #8
Bruce
The was my first though also. the hook end hooks onto something and the oval hole is were the valve stem goes to compress the spring to remove the retainers on an OHV engine.
   / What is this item? #9
My guess is it is a chain tensioner like you see on transports, feed the chain through the hole and insert the hook into a link and pull the handle down.
2008 CATERPILLAR D6K LGP PIPE LAYER (A50854)
2008 CATERPILLAR...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
