3 point plastic mulch layer
/ 3 point plastic mulch layer #1
weavertg14543
Member
rush,ny
john Deere gator 6x4 ferris pro cut s 61 inch 67 cub cadet Kubota ls3130
Has any one built one?
Does any one use one? If so how well does it work?
Would it be worth 2 grand to buy new?
Any idea on where I could find one used?.
I really want one to cut down on our wedding but spending that much money for a new one kinda defeats the purpose of doing a garden to me all together. We do a lot and it super hard to keep up on weeding. Any thoughts or help would be great.
/ 3 point plastic mulch layer #2
We've spread five tons by hand in one summer (three tons wood mulch, two tons rubber mulch.) Be sure to lay down cloth first. If your garden already exists (plantings are done) it's not going to be easy (or possible) to use any sort of spreader. Most of the times I've seen it done by machine it's been dumped by a loader, and raked into place by humans.
/ 3 point plastic mulch layer #3
Sounds like an interesting wedding if there is a plastic mulch layer involved!
I had to look up a picture of one, looks interesting.
Stupid spell check weeding
/ 3 point plastic mulch layer #5
It's not lose mulch, or rubber mulch he is wanting to put down. A plastic mulch layer uses rolled plastic and makes a raised bed of dirt with the plastic laid down over it to produce a row, then you cut holes to plant your transplants. I've been debating on buying or building one also, a used one is hard to find at least around here, if you do a google search and use the images you will find all types of home built designs from simple to very elaborate ones. Here is a pic of one.
/ 3 point plastic mulch layer #6
Ah, that's interesting. Does someone offer that service? You'd need quite a bit of garden to make that worth while.
Yeah was hoping some one had done it and maybe had plans or at least some pictures. Heck even a good idea on where to track down some stuff needed to build it
/ 3 point plastic mulch layer #8
Might I ask why you want to do that? What are you willing to plant in it?
Whe always have about 1000m a year for agricultural use, but i wouldnt love to see that in my garden..
Mathias
Oh I have what I would like to call a big garden. It's almost an acre big. And next year my wife has told me she wants to plant 100 broccoli plants 100 cauliflower plants, in addition to all the other stuff we do.
/ 3 point plastic mulch layer #10
We plant 3 beds of veggies under poly mulch every year. Each bed is 36"x235' long. It's not the most beautiful stuff, but it looks a lot better than a weedy garden. We lay the mulch by hand, pushing the roll along and burying the edges with a shovel. A mulch layer would be real nice, but we're farming on a slope and around a curve, so I'm not sure it'd work real well for us.
I guess my point is that doing it by hand isn't impossible, if it comes down to it.
Right would be difficult, props to you and how diligent you are with that
/ 3 point plastic mulch layer #12
You can build a simple mulch layer and get the covering discs from an ag store on line. Agrisupply comes to mind. Just find a picture of a simple one and duplicate it. You'll spend $40 each for the covering discs and $50 each for the wheels and shanks. I've owned a few and they all were simple machines.
At auction they are sometimes hard to sell and generally don't bring a lot of money so keep an eye out. BTW, I've got a four ft wide roll of plastic for sale cheap since we sold our mulch layer as we got older.
/ 3 point plastic mulch layer #13
Also make sure the distance between 2 beds is big enough so you can use a tractor in between. Or put some ground cover like strow..
Otherwise you'll have lots of work weeding between the beds by hand.. unless you spray..
The one that is used on our farm is built like follow :
- 2 potato hill disks
- 1 roll with plastic
- 1 roll irrigation tape
- 1 roll for the bed shape and guidance of plastic
- 2 wheels to hold the plastic under the dirt
- another set of potato hill disks to cover the plastic under the wheels.
Simple principle but once more.. you'll have to keep up the maintenance between the beds or you're even in a deeper mess :D
/ 3 point plastic mulch layer #14
All the NRD's in Nebraska offer the service for tree planting. They have one of those and a machine that plants the trees right behind it. Used on shelter belts and wind breaks where long rows of trees are wanted. Some will rent them as well. Might check with your local county extension office.
/ 3 point plastic mulch layer #16
A buddy of mine bought a used one off of Craigslist I found for him, in very good condition, for like $600 4-5 years ago. It did a very nice job of laying the mulch. His two biggest problems after the first year, was Deer punching holes though the plastic, and weeds popping up through those holes. The other problem was removing, and then disposing of it, when it outlived it's usefulness. He has a lot of weed pressure, and still had weeds coming up, close around the plants, in the holes they punched in, to plant through.
Personally, I use leaves to mulch with. I have a small town nearby that gathers leaves up in town, and they have a huge pile of leaves, free for the taking. I now have a neighbor with a lawn service, that provides leaf pickup in upscale neighborhoods in Columbus. He will bring them to me, saving him from hauling them half way around town, to a mulch facility. They work very well, and not all that hard to put down.13612133_10209858181430658_7121113114590846888_n.jpg If put down 5-6 inches thick, they make a very good weed barrier. After a few rains, they settle, and compact down to a couple inches thick, making a nice tight mulch. You're able to walk out in the garden, within minutes of a good rain, and not problems sinking in the mud. It also adds a lot of organic matter to the garden. It's pretty well broken down into fine compost the following Spring, and plows down well.
I also use 2-wheeled David Bradley walk behind garden tractors to cultivate, whatever I don't mulch. I plant in 30 inch rows, increasing the amount of crops, in a given space. I have 4 tractors set up with different cultivator shovels & sweeps, for different plant sizes, as the progress. Most, I have around $100 in apiece, so not a lot of overhead.
I've been trying to get my buddy who does the market garden, to try it for 5 years, and pretty well scoffed at the idea. I found a page on Facebook, called "Gardening for Market", that folks are now scaling back on equipment size, with narrow rows like I have, and getting more crop per acre. It is gaining popularity very fast..!! Some of them are farming 5-6 acres with smaller tractors than I have. So now, it has pretty well become the new rage in small farming. Sent the link to my buddy for that page to show him what can be done. Several are even modifying their small cultivators with what is called finger weeders, which are wheels with steel & rubber fingers, set nearly close enough to mesh, set at an angle, and make weeding of root crops such as carrots, etc. totally weed free., running the cultivator through every 4-5 days. A bit pricey for me, for the amount I grow of those vegetables, being they run near $500, for a set of them.
This may not be your cup of tea, but the leaf mulch has worked well for me, for the past 5 years. And we've been gardening with the 2-wheelers since the mid 50's, as far as cultivating. Old hat gardening for me, a whole new frontier for others.
I'll attach a few more pics of my setups. They aren't trailer queens, but run like sewing machines. They earn their keep here.Hilling Corn 003.jpgDSC01790.JPG
/ 3 point plastic mulch layer #17
I know this is dated but I built one a few years back. Much better than weeding. My parents quit gardening after about 2 years of use. Guess I aight to sell it.
Well how much?
/ 3 point plastic mulch layer #19
Mulch isn't that hard to spread. Seems like a waste of money unless you're spreading hundreds of tons a year.
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
Mini sweeper attachment (A61567)
Mini sweeper...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A60352)
2018 Sundowner...
