Oil & Fuel 1538 filter part numbers.
/ 1538 filter part numbers. #1
dickfoster
Elite Member
Nevada City, CA
Mahindra 1538TLB
Since I'm doing my 50 hour I needed filters and of course neither the owners manual or service manual had the part numbers for the filters so I had to drive to Yuba City to buy them. I thought I'd share the part numbers here. I have a 1538 gear or shuttle so the hydraulic filter may be different for the HST tractors, I don't know.
The hydraulic filter is really a Mitsubishi made filter the part number is 19642509000. I stopped by my local NAPA store and the NAPA equivalent is 7118. I paid $38.14 at the Mahindra dealer, I think this is cheaper than what NAPA wants for theirs.
The fuel filter elements of which there are two is part number 001081778R93. The NAPA equivalent part number is 3993. I paid $11.43 each and they look like they are worth maybe 50 cents if that. The Mahindra filter is very poorly and shoddily made of cheap materials. I'll be replacing that with an equivalent from NAPA next time for sure.
The engine oil filter is 006000789B91. I couldn't come up with an equivalent for that because of the oddball thread pitch used. I paid $14.71 for it so no biggie. Outside of the odd ball thread pitch, it's a nothing special filter with no anti drain back valve etc.
My guess would be that the 1538 and 1533s use the same filters as they have the same engine.
BTW when I first called the NAPA store, their computer didn't recognize any Mahindra 1500 series models so without these numbers they won't be able to help you.
/ 1538 filter part numbers. #2
I wanted to revive this thread to see if anyone had any additional info. It looks like a later post shows the tractor uses two different fuel filters. This is what I have found for my 1538 HST so far-
Mahindra Filters
Oil- 006000789B91 , Wix 51324
Fuel 1 - 001081778R93 , Napa 3993 , Wix 33393
Fuel 2 - E006018618D1 , Bosch F 002 H22 025
Hyd 1 - 19642509000 , Napa 7118 , Wix 57118
Hyd/HST 2 - 19682581000
Air Outer - 10560411400
Air Inner - 19480413500
The first part numbers are factory numbers. From the pictures I've seen online it appears the hydraulic filters are Mitsubishi filters. And as stated the "main" fuel filter is a Bosch.
/ 1538 filter part numbers. #3
I would advise running OEM filters at least while the tractor is within the warranty period. After that, it is up to you which filters to run. But for warranty purposes, OEM is always best.
Just so you know Mahindra doesn't make filters, nor does Toyota or any other tractor or car maker that I know of. While they may have their label on them it's just paint or ink. Many of the filters on my tractor were made by Bosch while some others are of Asian origin I think like the cheap paper 1st fuel filter element for example although I think the filter housing is likely a Bosch part too.
/ 1538 filter part numbers. #5
It should also be noted Mahindra has no provisions requiring OEM filters for warranty purposes.
/ 1538 filter part numbers. #6
You are 100% correct. The fact remains that if Mahindra (or Deere, Kubota, etc.) calls for a certain filter, it would be wise to use that filter while the machine is under the manufacturer's warranty. Say a hydro unit fails because of dirt ingestion or contamination, and the tractor has always been serviced with Mahindra oil and filter. That works to your advantage because the manufacturer can't say "you used an aftermarket filter with a different micron rating which could have allowed contamination, and therefore this is not covered or is only partially covered."
The way I see it, if Mahindra is going to authorize and pay for a warranty, it pays to use the parts they recommend. At least while the tractor is under warranty.
/ 1538 filter part numbers. #7
I found that the OEM filters are so close in price to the off the shelf brands, it's not worth worrying about the xref numbers for them.
/ 1538 filter part numbers. #8
I understand that OEM is an option. I was hoping to provide a resource for folks. You never know what could happen- particularly Murphy's Law some evening or weekend! A good reason to have extras with the tractor for sure.
As a side note my dealer thinks, though not 100%, that the air filters are common Donaldson parts. If I get that cross reference I'll post it here.
He also stated that he has never found a HST filter that was aftermarket. Because they are special high pressure filters unique the each model he only uses OEM for that filter. He had zero issue with quality aftermarket for the rest.
I don't know about your hydraulics but on my gear tractor the hydraulic filter is low pressure as it's in the pump return line. The most pressure you could possibly ever get in a return line is one atmosphere or about 15 PSI tops. Even that would take some doing and it would be vacuum or crushing not pressure outwards.
/ 1538 filter part numbers. #10
RNeumann;4620385As a side note my dealer thinks said:
Quite possible, Donaldson is an OEM for many OPE engines.
/ 1538 filter part numbers. #11
You are correct. The gear drive uses one hydraulic filter and is the part number you found above. The HSTs have a second filter that is the special high pressure one.
So on a HST it's one regular hydraulic filter and one special HST filter.
/ 1538 filter part numbers. #12
/ 1538 filter part numbers. #13
Mahindra Filters
Yes, this is an old thread. If necessary, I'll start a new one. But, first, what seems to be an error needs to be corrected here.
The Wix number (33393) appears to be a typo - I believe the correct number for the Wix filter, that is shown as a cross for Fuel 1 above, is 33993.
Now, for the better news and "free" shipping:
Fuel 1 is available in a 2 pack for $13.50 delivered. See:
FUEL FILTERS SECONDARY SET = (2 Secondary filters) - Reubicon International Inc.
And, these do appear to be OEM Mahindra parts in factory boxes based on the photo.
In addition, after you place an order with Reubicon, you should receive an offer for an automatic 7% discount on your next order placed within 60 days. However, you should wait until you receive the "Welcome" email and use the included link to create a password, THEN place the second order.
I placed a second order for Fuel 2:
MAHINDRA TRACTOR FUEL FILTER - Reubicon International Inc.
At 7% off, Fuel 2 works out to be $43.71 delivered.
This also appears to be the same filter Mahindra supplies ACCORDING to web reports. I have not verified this directly.
As a bonus, the discount allowed me to avoid doing business with this same company via the ubiquitous jungle website run by that alt-left, Washington Post guy. If any of you wish to do business there, be my guest but I only use them as the last resort of last resorts. Plus, ordering direct from Reubicon saves you a bit if its your second order. AND, there's no sales tax involved unlike with the jungle company. At least, that's my experience.
Anyone find better pricing or have a different experience?
/ 1538 filter part numbers. #14
Thx for the update! No need to start a new thread.
/ 1538 filter part numbers. #15
I'm still in process of checking if 1538 filters fit 1533. We'll see soon I'm gathering stuff now to do complete change at 300hrs. Cross fingers.
/ 1538 filter part numbers. #16
It seems to me that you could get more than 1 bar in a return line (whether it's merely the discharge from cylinders, a relief valve, or the end of the open-center circuit. Certainly the suction or feed line has that limitation. It seems to me you could get a couple thousand PSI, if the filter was blocked. Of course, the filter won't be blocked, because it could potentially have high pressure to push oil through (unless something coagulated the oil.)
/ 1538 filter part numbers. #17
As an update on the filter order from Reubicon - I got a Priority Mail shipping notice this morning for the orders I placed last night.
So, they seem to be on the ball. Their communication is very good, by the way. They also have some parts for other Mahindras if you have a different model.
It would have to be on h e l l of a blockage. That much pressure on a regular filter would likely blow the guts out of the filter and into the return tank.
/ 1538 filter part numbers. #19
Fuel Filter --> 1533 HST & 1533 Gear, do Indeed take the same as ALL the 1538 Gear, 1538 HST & 1538 HST Cabin.
/ 1538 filter part numbers. #20
The filters from Reubicon are Bosch filters. At least, they are in Bosch boxes with Made in India labels. That should satisfy the purist among us! They arrived today. So, less than 3 days from order to delivery.
Interestingly, Fuel 1 - the paper filter, came to me as a Bosch 9 451 037 407 from Reubicon. And, that filter, according to a web search, has been around for decades - Like 1960s and 1970s Mercedes in addition to Deutz, Dodge, Daewoo, IHC, Komatsu, Volvo products and even LAMBORGHINI tractors.
All of the above is dependent, of course, on the Fuel 1 filters I received being appropriate for our tractors. They appear to be identical to the web site photo but in Bosch (India) boxes and not the Mahindra boxes pictured on the web site.
This filter crosses to a Wix 33167.
http://www.wixfilters.com/Lookup/Competitor.aspx?PartNo=9451037407
If you click on the 33167 link on that page, you can then click on the All Applications link on the second page in order to see the dozens of engines this filter has been used on.
The Fuel 2 filter looks just like all of the other Bosch F 002 H22 025 filters I've seen elsewhere. And, why shouldn't it - That's what it is. The part number on the box has a suffix of 8F8. No idea what that means. However, that suffix seems to be fairly common on Bosch filters based on a web search. The boxes on both types indicate they were made in 2015.
OK, this swamp is officially drained - I'm outta wudder . . . A little Philly/Unabomber lingo fer ya!
Reichardts Green Fit Kit for C Series RoGator (A63117)
Reichardts Green...
2006 GMC C5500 4X2 BUCKET TRUCK (A59912)
2006 GMC C5500 4X2...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
UNUSED WOLVERINE QUICK COUPLER 1 (A64281)
UNUSED WOLVERINE...
2025 JMR Tree Spade Mini Skid Steer Attachment (A61572)
2025 JMR Tree...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
