Anyone want to re-sharpen drill bits again......
/ Anyone want to re-sharpen drill bits again...... #1
Oldpath05
Super Member
none
I have the smaller Drill Doctor for up to 3/8 bits, works good for those, but my bigger drill bits up to 1/2" are getting dull and they are cobalt and I have some HSS. I use to have the bigger DD but I found that the $30.00 wheel wore out too quick on those bigger drill bits, like after two dozen sharpenings I wasn't getting that nice chisel point , I think the wheel is too small for bigger bits.
I watched several youtube videos and they all have one thing in common. They go> "first let's talk about the first thing first,>>the rake, geometry, cutting edge, relief and good grief, bla bla bla. For just once I like to see a video on sharpening drill bits and say, the first thing first is the GRINDING WHEEL, what type, what grit, what size, what color and why..........for the average 6" bench grinder, now I'll go watch some more ytube and look for an education on grinding wheels and deals.
/ Anyone want to re-sharpen drill bits again...... #2
I'm with you. I would love to know more about grinding wheel materials and what to use for what.
/ Anyone want to re-sharpen drill bits again...... #3
With the youtube videos, if they have there rubber gloves on don't waste your time watching.
/ Anyone want to re-sharpen drill bits again...... #4
It's probably not mentioned because geometry of the bit matters way more than what the grinding wheel is made of. I use whatever is available. Never tried a drill doctor personally. I do use the side or the wheel rather than the edge because it's usually flatter.
/ Anyone want to re-sharpen drill bits again...... #5
I sharpen drills all the time with a simple grinder that is fitted with a fine stone using my eyes as my guide.
I simply duplicate the existing angles and always cool the bit by soaking in water.
Heat is the enemy.
The handiest gadget I have is a diamond dresser so that my stones are always flat and true.
The dresser was actually very inexpensive.
Anything below 1/8" is a throw away however but then there are tons of 'deals' out there for assortments of small bits.
/ Anyone want to re-sharpen drill bits again...... #6
... Never tried a drill doctor personally. I do use the side or the wheel rather than the edge because it's usually flatter.
This is dangerous. (Not the DD - They're awesome!) I mean the use of the side of the grinding wheel.
Rotating grinding wheels are covered by an Act of Parliament in my country and in the UK. Similar legislation in USA exists and comes under your OSHA.
Don't scoff - People have died and been injured horribly by grinding wheels 'exploding'. A major cause of grinding wheel failure is "Side-Loading" by applying work to the 'flat' side of an abrasive wheel.
Grinder wheels are only designed to have the work applied radially. That is: from the front of the machine towards the axle shaft. Not from the side.
Some Do's & Don'ts:
Safety Information
Grinding Wheels are Safe Use but Don't Abuse
Do
Do always Handle and Store wheels in a careful manner
Do Visually Inspect all the wheels before mounting for possible damage
Do Make Sure Operating Speed of machine Does Not Exceed speed marked on wheel, its blotter or container
Do Check Mounting Flanges for equal size, relieved as required & correct diameter
Do Use Mounting Blotters when supplied with wheels
Do be sure Work Rest is properly Adjusted on bench pedestal, and floor stand grinders
Do always Use Safety Guard that covers a minimum of one-half the grinding wheel
Do allow Newly Mounted Wheels to run at operating speed, with guard in place, for at least one minute before grinding
Do always Wear Safety Glasses or some type of approved eye protection while grinding
Do Turn Off Coolant before stopping wheel to avoid creating an out-of-balance condition
Don't
Don't use a wheel that has been Dropped or appears to have been abused
Don't Force a wheel onto a machine Or Alter the size of the mounting hole If a wheel won't fit the machine, get one that will
Don't ever Exceed Maximum Operating Speed established for the wheel
Don't use mounting flanges on which the bearing surfaces Are Not Clean, Flat And Smooth
Don't Tighten the mounting nut Excessively
Don't grind on the Side of conventional, straight or Type 1 wheels
Don't Start the machine Until the Safety Guard is properly and securely In Place
Don't Jam work into the wheel
Don't Stand Directly In Front of a grinding wheel whenever a grinder is started
Don't grind material for which the Wheel Is Not Designed
Source: "Grinding Wheel Institute"
Got Grinders? Get Safeguarding - Machine Safety Blog
There is much info on your OSHA site:
"A Partial List of Accidents Involving Grinders"
including 7 fatalities on the first page alone:
Safety and Health Topics | Machine Guarding - A Partial List of Accidents Involving Grinders | Occupational Safety and Health Administration
/ Anyone want to re-sharpen drill bits again...... #7
Spanner is not blowing smoke, he is spot on with his warning, please...please listen.
As mentioned, wheel dressers are cheap, buy one and use it.
David from jax
/ Anyone want to re-sharpen drill bits again...... #8
Point taken, but if you put enough pressure on a drill bit to cause side loading on the wheel you'll overheat it as well. Just barely kiss it.
/ Anyone want to re-sharpen drill bits again...... #9
If you don't like wheel dressers, there are diamond dressers and dressing sticks (stones). My tool rest doesn't work well with a wheel dresser, so I got a dressing stick and have been much happier, since now I actually use it.
Amazon.com: Grinding Wheel Dressing Stick: Home & Kitchen
/ Anyone want to re-sharpen drill bits again...... #10
I do the same as Piloon. Replace smaller bits with new and hand sharpen larger bits on a fine wheel stone. Use a diamond dresser to keep stone flat. Tried a Drill Doctor several times but never had any luck getting a sharp bit.
/ Anyone want to re-sharpen drill bits again...... #11
I've had VERY good results with my drill doctor, it took a small learning curve, and after that, I've been able to make my drill bits as good as new again...
SR
/ Anyone want to re-sharpen drill bits again...... #12
My fil, a machinist always did his by eye. He showed me his approach and it made sense but I am not great at it. I don't worry about it. I break a lot of bits and resharpen often.
Everywhere I go and ask at work, the same thing, a grinding wheel is a grinding wheel, but my 6" Ryobi 60 &36 grit grinding wheels say different, the ones I have now dont seem to work good on my cobalt bits, just a couple swipes on the wheel and a groove is starting on the grinding wheel, kind of hard to sharpen a drill bit when the wheel is uneven, that's why I need to find out if there's better wheels for cobalt bits. Now I have to get a stone dresser, wheels are starting to get out of balance and it might be throwing the earth rotation off too, making the summer go by too fast......
I heard the wheel dressers with the wheel thingies work better than those diamond stone dressers, maybe I need to read a few hundred more reviews......
/ Anyone want to re-sharpen drill bits again...... #14
I've been sharpening drill bits, off and on, for the last 50+ years and have done it by hand as well as with drill bit sharpeners costing in the thousands.
Retired now and bought a 3/4" Drill Doctor a couple years ago. I like the web thinning capability but as far as sharpening the drill bit it, well, sucks.
I've tried every approach in the book and some not in the book but it simply will not sharpen a drill bit accurately.
/ Anyone want to re-sharpen drill bits again...... #16
I've watched a number of videos and read articles on drill bit sharpening and attempt to sharpen my dull bits accordingly. They seldom, if ever cut as well as they did when new but usually cut better than they did before I tried to sharpen them. I sharpen the bits on the fine grit stone of an 8 inch HF grinder and dress the wheels with a wheel dressing stick. Thanks to that stick the grinding wheels are now more like 5 inches. Before getting the drill press I made most of my large holes with a cutting torch. I'm awful with a cutting torch.:mad:
Ditto, If I didn't know better, I would've thought I wrote this :thumbsup:...........
/ Anyone want to re-sharpen drill bits again...... #19
Maybe 20 years ago I had a very simple bit sharpener tool that read simple. Had round piece of metal bent near a L just not to a full 90%. There was short piece of metal that bolted to the grinder and the rod slide into and you raised and lowered the rod with bit in holder on it. It would handle a big range of bit sizes and did a good job. Did use stick dresser on the grinding rod. Used common grinding wheel, fine grit. Sadly loss the round rod with a move. Do have drill doctor and it does a decent job but have not sharpened a drill bit in a couple of years and need to really do some catch up.
/ Anyone want to re-sharpen drill bits again...... #20
You could buy something like what is listed below. It's supposed to get the right angle and back edge relief. I just do it on my tabletop grinder by eye. Get the angle right and spin it while gently pushing against the wheel to get a good edge. Keep it cool. Watch the videos for technique on that part which is really all you need to know. I use the finer side of my grinder but it has never been dressed in 30 plus years of use and the bits still come out sharp.
Original” Drill Grinding Attachment 825
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
Electric Oven (A60352)
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2012 PETERBILT 367 (A60736)
2012 PETERBILT 367...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
