Brand advise, hydraulic dump trailers
/ Brand advise, hydraulic dump trailers
Had three dealers on my visit list yesterday morning, the first stop was a mom and pop place that had recently been bought out by Big Tex Trailer World (Trailer World). From what they told me, Big Tex is setting up their own retail channel with a plan to go public. Anyways, I spotted a Big Tex 14GL-16 foot dump in goose neck.
Back at the office, they gave me pricing on both the bumper-pull (14LX 16) and the goose neck. Goose neck was more mola but went for it for the obvious reasons.
So it has everything expected, it is a stock build (7K axles) but I'm OK with that given my usage. It has the popular features mentioned in this thread, scissor lift, 5" hydraulic cylinder, NOT power coated :), power down dump, LED lighting all around, three-way tailgate, etc.
Thanks again for the advice.
/ Brand advise, hydraulic dump trailers #23
Nice. Very nice. I was thinking about going to a 16' w gooseneck. Now go get some dirt on everything. Have fun.
/ Brand advise, hydraulic dump trailers #24
My experience with 25 years of trailers is powder coat is a chip leads to rust which leads to it coming off in sheets. That leads to a full disassembly, sand blast, and paint.
I prefer enamel that is easily repaired with a rattle can of Rust Olem Paint.
There are a couple of really nice things about powder coat:
  1. When it fails (everything fails), it usually allows rust to get in behind it, where it can work its way along and also go deep, with the nice shiny powder coat hiding all that damage from your prying eyes, often until the item is structurally compromised.
  2. If you do catch it in time to avoid structural damage, you can't really spot-repair it.
There is no doubt it's tougher than paint. I still won't have it on anything I own.
/ Brand advise, hydraulic dump trailers #25
I have been happpy with my PJ Gooseneck Dump...haul gravel to the farm and wood to the city power plant and manure to the composting operation...:)
/ Brand advise, hydraulic dump trailers #26
I see you have already made your decision.
But I'll add my :2cents: in case anyone else sees this thread and is considering.
Paint vs Powder coat......
I didnt give much thought to this. More important things I wanted to concern myself with. Power coat and paint can BOTH be done properly and last for many many years. OR they can both be done poorly. Yes, I would have had a slight preference to paint, but WAY too many "good" brands are doing powder coat. It would have narrowed my choices way too much, and made me drive quite a ways to get a decent trailer.
I think from my research that Diamond C has the best coating going right now on a trailer. They actually use a good hard urethane based paint. So automotive quality.
Going that sized trailer, be it bumper pull or GN, you really only have about 3 hydraulic options. Telescoping, scissor, or dual cylinder. Just compare the specs. Make sure the cylinder size and stroke are similar to what just about everyone else is doing and it should be fine.
I have a gooseneck equipment trailer, but wanted the dump to be bumper pull for the single reason of towing behind my tractor. Moving dirt, firewood, logs, etc around the property is alot nicer with the tractor than the truck. I took the cylinder hoses off the 12v pump unit and re-attached them with quick connects. Then I had some hoses made up to go from there to the remotes on the tractor. So in about 15 seconds I can swap from 12v pump to tractor remotes. Which is nice. Faster and never have to leave the seat.
I saw alot of ads for big tex, but no one I could find actually had any of their trailers around here.
Appalachian and kauffman were another two I looked at. But really only economically feesable if you live near them.
Yep, I did. To tell you the truth, of all the trailers I looked at, the differences between them wasn't obvious. They all had scissor lifts using 5" cylinders, 7K Dexter axles, Interstate battery, Sand Blasted, Acid Washed, Powder Coated steel, material cover, LED lighting, ect., about the only difference was the decals, they were even priced competitivly.
Of the dozens of manufacturers of 16-foot dump trailers I discovered on Internet searches, I found that when I went to the "locate a dealer" option on their web site, nothing showed up around me, and I mean around me was 200 plus miles. The brands available to me were limited to a few with BigTex and PJ being the most reconizable. I think brand availablilty is dependent on what part of the coutry one is located.
The one feature that did stand out from the other brands was BigTex's three-way tailgate, they were the only brand available here that offered the three-way which I found valuable to my usage.
/ Brand advise, hydraulic dump trailers #29
Looking for advice regarding the various brands of hydraulic dump trailers, specifically a 16-foot low profile in either bumper pull or goose neck. I'll be pulling with a one-ton diesel pickup.
Brands to stay away from, brands you would recommend?
Lots of folks seem to like PJ. Lots of folks hate PJ.
Don't know if there are multiple manufacturing sites and that makes a difference but out here they are not liked very much.
I know when I was looking for my dump (which is also multi purposed as an equipment, thus the length) I found that PJ could not compare in quality, features or price.
May not be common in your neck of the US but Great Northern built in Oregon is a great trailer whether dump, equipment or anything else.
I have two - one flatbed, one dump and would not own anything else until you get up to the real big boys with 24K axles and the like.
I can easily overload mine due to the length but it allows me to have a dump while having the weight capability to support one specific piece of equipment. It is easy to calculate what you can carry and put that amount in and no more.
/ Brand advise, hydraulic dump trailers #30
Another thing I forgot to mention.....is that I have heard to stay away from torsion axles on a dump. Torsion axles dont take kindly to a static overload condition. Which is exactly what happens when you dump....you overload the rear axle.
I guess you will have to give me an education....what is a 3-way gate.
Mine is the 2-way.......barn doors and spreader that hinges at the top, opens at the bottom. What could possibly be a 3rd way to open and what would be the benefit?
/ Brand advise, hydraulic dump trailers #31
Same here, maybe I'm missing something...
-R
/ Brand advise, hydraulic dump trailers #32
Those of you who use the dump trailer with slide in ramps to haul equipment - when you roll off the back onto the ramps how do you support the back of the trailer to keep from lifting the truck off the ground? Do you put a jack stand under it or??
/ Brand advise, hydraulic dump trailers #33
The third way is you leave the lower latch hooked and the two hinge pins at the top that can be removed after the hitch pin clips are pulled and it drops down like a regular pickup tailgate.
David
/ Brand advise, hydraulic dump trailers #34
I had PJ install the rear support stands. Remember to not lower them to the ground, as after loading the weight of load will prevent them from being able to retract. Also, you need to watch them when dumping, and moving trailer, as the clearance when bed is raised is minimal.
/ Brand advise, hydraulic dump trailers #35
If I could do it over I would have saved the dough, and just carry a couple of wooded blocks cut to size needed.
/ Brand advise, hydraulic dump trailers #36
Dropping like a tailgate is what I was wondering. I cannot think of any instance where that would benefit me. Does it allow full dump when in tailgate position? Cause as mine is now, with barn doors open and full dump, if a "tailgate" we're more than about 6" it would be binding on the ground.
I got slide in ramps. But have no intention of hauling heavy equipment that would warrant support. I have the gooseneck for that. But it looks kinda dorky hauling a atv or zeroturn or garden tractor on a 25' 24k gooseneck. And didn't want to buy a utility AND a dump. So a 7x12 dump with ramps does both
While there may be more than one benefit of the trailer's tailgate dropping like a pick-up truck, for me, the feature has value when I have to haul lengths greater than the dump bed length. I have several acers of wooded land to clean which includes fallen trees greater than 16 foot long.
My sides are 24 inches with a deck height of 28 inches so I would say no, can't make a full tilt without the tailgate hitting. I can't see a reason why to dump with the tailgate down when there are two other options available except to dump out the debris collected from the woods and then, it tilts high enough to empty.
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
