Grease Gun and a Screwdriver
/ Grease Gun and a Screwdriver #191
Thanks James, you always have helpful tips!
Your welcome.. I am always pleased to make someones life a little easier.
Oh, by the way I have a bunch of those 1/8 inch Zerks left over is someone wants to drop by and leave with one for free.. I had to buy a whole package..
/ Grease Gun and a Screwdriver #192
But James never did explain whether that screw driver thingy demo was for left hand turns or right hand turns.:confused3:
/ Grease Gun and a Screwdriver #193
Yah, operation of that screwdriver thingy, is really beyond the scope of my knowledge base...:)
/ Grease Gun and a Screwdriver #194
I have to admit, I read the thread only to page 12 and can't resist any longer to comment.
After 6 years after the OP, I still didn't know. I'm 46 right now and won't qualify for 'the oldest'.
I have two grease guns, a two-hand lever action and a pneumatic. I agree on the priming issue a poster mentioned somewhere.
Recently I bought three cheap cartridges of grease and two of them have air pockets locked in. They were a PITA. I never buy them again.
One of the tip started to leak grease out to the side. Depending which gun wasn't affected by the bad cartridges and worked, I changed the tips.
I put a new grease tip on the Financial Minister's shopping list.
When she and the kids came home, they mentioned a difference of three jaws vs four jaws. I didn't know the difference, I wasn't old enough yet.
Now, the new tip IS tight and difficult to get off some zerks.
What I discovered in the past with the side leaking is, that not always pushing the tip on to the zerks and hold it there is the solution. Sometimes I had to release the forward pressure and let the jaws hug the zerks and it would seal and not leak.
By the time I get home I will start my research to confirm your reports. If it proofs to be true, I make sure to tell my 15 year old son about it. He should not life another 30 or even 60 years until he learns this.
I really like this forum and enjoy reading on here. I apreciate the willingness of the experienced members to share their knowledge..... including a nice portion of humor about (their) "density".
/ Grease Gun and a Screwdriver #195
A Lock n Lube tip can make life a bit easier too. I have one.
/ Grease Gun and a Screwdriver #196
I am 70 1/2 and I just learned. I spent several of my teen years working in a service station doing 1$ grease jobs. I grew up in Tennessee where people are naturally smarter.
/ Grease Gun and a Screwdriver #197
James - after 5 years using the Lock n Lube I have to say it works really well and I probably use it 90% of the time. It does make it harder to get at Zerks in corners and other tight spots, though. After 5 years of getting covered with grease every time I had to change the tip, I found one of those mini grease guns that I'd bought & promptly lost, even before I got the Lock n Lube ... much density, I know. Now I keep a right angle tip on the mini & no Zerk I can't deal with - even without a screwdriver!
/ Grease Gun and a Screwdriver #198
Yep, you are fully armed. Cocked, Locked, and Ready to Rock. :thumbsup:
/ Grease Gun and a Screwdriver #199
So I just read this thread about an hour ago. Since then I have been greasing fool! I have replaced several guns because they were a pain to get on and off the fittings. Wow do I feel stupid now!
/ Grease Gun and a Screwdriver #200
No problem, Many an older fellow has went on to his reward without knowing that little piece of info.
73..de K0UA
2014 Ford Explorer AWD SUV (A61569)
2014 Ford Explorer...
Tire Balancer (A61570)
2022 Horizon (A55973)
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
