Maintenance Questions
/ Maintenance Questions #11
My loader manual says grease every 10 hours. I generally grease once a month.
/ Maintenance Questions #12
As long as you clock in 10 hours per month, you're good.
Remember the bouncing across a field = loader work hours = Pin Wear. Those pins are under pressure as you drive and bounce around. There's no cushioning, so if it's metal on metal, there will be wear.
/ Maintenance Questions #17
Lock and lube tip was a real game changer especially for the zerks in hard to reach places. I keep a grease rag near the grease gun to wipe off the zerks before greasing and to clean up if I get too enthusiastic.
A grease gun is a must if you own a tractor!
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
Quick Attach 72'' Brush Cutter (A60462)
Quick Attach 72''...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
