Another new GT48DXLS owner - Thanks to TBN
/ Another new GT48DXLS owner - Thanks to TBN #41
Good Morning Teachu2...about 6 hours on my GT48DXLS and as you have reported it continues to impress. Very strong...I have mowed 18"+ tall, thick green weeds and while the motor feels a bit labored it quickly clears itself and handles the weeds well. Occasionally leaves an odd standing tall stalk but with what I am mowing that is understandable. I also do not discriminate against small brush and it handles that well also.
SO far I have been stuck 4 times :) Twice in wet clay as the tires "loaded up" with clay and were like "slicks". Had to pull it out...locked diff no help when traction in rear tires is near zero and terrain is uneven. The other two times I was stuck on dryer ground and the locked diff quickly supplied relief. Wet clay is terrible.
Couple of questions...
1) I have operated last two lawn tractors for over 25 years with rear wheel weights and chains...never removed either. Only stuck once during that whole time...hung up on the deck trying to cross a small stream :) Dealer is brand new but thinks he "heard" you could not add chains...due to tire clearance??? It does look tight.
Are you aware of anyone who has added chains? Is there such a thing as a low profile chain?
What about better traction tires? Maybe HDAP like JD 5xx series has??
I have pretty much used in each of my mowing areas and the traction is my biggest problem...I knew that but had hoped the diff lock would be a solution. Either need chains/wheel weights or perhaps better traction tires. However, I think the wet clay would nullify other traction tires also?
2) With my use I have learned that blades/spindles and belts are often the "breaking" point as I use my mower as a quasi brush mower. I think I need to add a front end mower lift as this deck is likely too heavy for me to deal with...particularly for blade sharpening/change which I need to deal with pretty often. As long as I use blocks to support frame for safety I assume I can reach under and remove the blades for maintenance?
3) I see you changed to Oregon mulch blades. I do not bag but have no strong reason to mulch. The new mower is a monster at blowing the clippings...and does not seem to clog up at all. My concern is blade strength, holding an edge and high lift for blowing out. I know I will dull...both on heavy weeds and sticks as well as glancing off rocks, small residual stumps and dirt. I like the performance so far of the stock blades but wonder if there is a stronger version that would perform the same but maybe last longer between sharpening and other damage...ie heavier duty blades (that still throw the clippings as well).
BTW...I am actually a little nervous and watchful as I think some may have issues with damage from stuff thrown out the chute. Most of what I do has nothing to damage from thrown debris and I usually am out alone. I LOVE the power of the dispersal of clippings, small rocks, twigs etc but would not surprise me if they modify the chute in the future to deflect a bit more...or other solution.
4) Soon will be looking to do the 8 hours oil/filter change...looks like straight weight 30 will be my choice as we rarely see 90F+. No synthetic oil for straight weight I don't believe? Would not a multi weight xx/30 or 40 be a good choice? Any problems with oil filter change out? Do you have the filter number handy?...I don't see it in the Kawa manual.
I view the problems I have had with the mower...primarily getting stuck...as my usage issues. I suppose it is possible I may need to "pay up" and get either an x590 or perhaps an x7xx (with all wheel drive)...or other and mower. Perhaps I need to stay away from my clay areas...that and this has been a VERY wet year here in Northern Minnesota. Time will tell...I now know what it won't do :)
Appreciate reading your inputs...TMR
BTW...I have learned that even when coated with mud it cleans up pretty good with a quick hose washing and then mowing all my rough surface terrain...now clean as new (well almost)
I don't have a GT48DXLS, but I do have a GTH26V52LS, 2wd non-locking differential. Traction problems were eliminated with the tire swap like I mentioned in msg. 39 above, and with 50# rear wheel weights. Mud and wet grass are no long and issue :)
1) I have no experience with chains or clay mud, and my 275lbs on the seat seems to work as wheel weight.
2) I use a mower jack with no issues, but only to pull/change the blades.
3) The Oregon G5 Gator blades are a big step up from the originals. They also propelled the discharge out the chute with authority. I changed to the mulch plug and gained a) lower noise level, b) contained discharge- no more covering the road with cut grass, and c) substantially decreased width since I removed the chute. Makes it easier to clear obstructions, rocks, trees, etc. Strictly a personal choice - and I may pull the plug for the first mowing of the season. Either way, the G5 blades are GREAT!
4) Open your hood. On the right side inside the hood is a sticker - I took a phone picture of mine, so I can refer back to it any time. Has blades, belts, filters, spark plug, and oil all listed. Husqvarna recommends 10W30, Kawasaki seconds that to 86 degrees, then says straight 40. Kawi also cautions that multiweight oils will be consumed at higher weights.
/ Another new GT48DXLS owner - Thanks to TBN #45
hehehe - yep, those tires will definitely give Teachu2 more traction! All the traction one would ever want. But they will definitely chew up the turf. If it's only pasture land he's cutting, those are the answer. In my case I needed something more multi-use, i.e. traction on dam banks but smooth enough on the lawn to not damage it. Teachu2 now has choices for Mild to Wild :)
/ Another new GT48DXLS owner - Thanks to TBN #46
What tires did you change to? TMR
/ Another new GT48DXLS owner - Thanks to TBN #47
Same tread pattern as my picture on the above msg #39. Several brands out there and all about $100 each. Wheel weights, 50# each side, helped the turfs, but the turfs just didn't have enough grab. The all terrain's don't tear up the lawn portion of my mowing, but have no traction problem at all on my 25 degree pond banks.
I tried filling the tires with water, but that was a bummer. Filled fronts caused VERY hard steering, so I dumped the water idea altogether. Wheel weights 'helped' but did nothing for me in muddy and/or wet areas. My combo is fronts factory turfs, no nothing. Rear 50# weights and ATV's.
/ Another new GT48DXLS owner - Thanks to TBN #48
/ Another new GT48DXLS owner - Thanks to TBN #49
Do you have the number for the plug kit? My dealer is lost for parts...thanx the dealer has 965894003 which has additional baffles for $180..I can mulch now with a plugged bagger chute and hi-lft blades....trying to do it better
Its a 2017
Its a 2017
correct part number is 965894003. That part is $64.99.
/ Another new GT48DXLS owner - Thanks to TBN #51
965894003 is $180 with plug baffles blades
582559901 is$65 with plug no baffles and 3 blades......this is the one Husky recommends even though it says z248f is the fit.
I'm looking at this forum for what fits as these guys have installed it
/ Another new GT48DXLS owner - Thanks to TBN #52
Is anyone having issues with the 58255901 mulching kit on a gt48dxls blowing clippings out the front right side?????
/ Another new GT48DXLS owner - Thanks to TBN #54
the kit is on back order from the factory
UPDATE, 3.5 years later
I consider myself fortunate to have purchased a GT48DXLS when they were available. I changed out the rear tires for ags and installed the mulching plug. It is a BEAST! With the new tires, it will mow up hills steep enough to raise the front end off the ground. The locker is superb, and it's great to be able to easily turn that on and off. I'm a XXL guy, 6'3", 275lb. It hauls me up the mountain with authority. The Kawasaki is perfect. When the ground is dry, I have to blow out the air filter every couple of hours - it's doing it's job. The wife loves driving it. We run Oregon Gator G5 blades, which are much more durable. The mower deck has taken a beating from rocks and trees, and has held up fine. We have enough rough stuff to knock the deck off the front hanger once or twice a year, but it's an easy fix in the field, no tools required. We're still running the original belt.
We pull a drag harrow with it on the back lawn area. For the native areas, I use a Rhino. I don't snow blow, I haven't added a bucket, and I don't tow a trailer with it. I have a Rhino and a CUT, but they don't mow up and down the mountain nearly as well as this mower does. It's been an outstanding tool for the job.
/ Another new GT48DXLS owner - Thanks to TBN #56
Good to hear. I have 140 hours on mine. Everything is working great. Mostly just mow grass with it. I have the 3 bagger system. I pull an airerator and fertilizer spreader too. It was a great. Buy!
/ Another new GT48DXLS owner - Thanks to TBN #57
Glad it’s worked out but I’m not surprised after having 3 different used Husqvarna mowers now. All were good
I remember when the GT48DXLS came out, I read a lot of the posts about it and commented a few times.
What’s the difference between the GT48DXLS and the GT52XLSi?
Last fall I picked up another GT52XLS but this time with the push button locker so it’s the “i” model.
The GT52XLSi has the push button locker which is great, 52in fabricated deck and mine has the 24hp B&S engine, the other GT52XLS I sold had the Kawasaki 24hp which I actually didn’t like as much as the Briggs.
Cons: smart switch on the “i” model, don’t care for that one bit.
For my use, the 48" deck is better. I have lots of trees and rocks, and the 48 barely fits through some of the gaps.
/ Another new GT48DXLS owner - Thanks to TBN #59
What plug did you use on the 48". baffles?
No baffles needed. I also replaced the included handles with nylock nuts. IIRC, the front one wouldn't clear the wheel bracket. Mine stays on all the time. The chute throws clippings a looong way, and makes the deck wider. Both those things are negatives for my use. My dealer had ordered the other kit originally, but it didn't fit the deck.
Husqvarna OEM 58255991 - Kit Mulch 48 Clearcut Rz Trctr
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
500BBL WHEELED...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
