Banjo bolt
/ Banjo bolt #1
tarheel96
Member
Tn
Yanmar
I need some help finding the location of some banjo bolts in a Yanmar 2TR17 engine. They should be two for the oil line and two for the fuel line but I dont know which ones go to what? I have two bolts with the small holes and two with the bigger holes. I didn't take the motor apart but I am the one putting it back together so I am doing my research before reassembly. thanks
/ Banjo bolt
Thanks kirkawilson for the link. I will check it out now.
/ Banjo bolt
I know the bolts go into one of two locations. The first locations is the lines that run from the fuel tank neck to the motor...called the fuel return hose. Or the second location is the oil line connections that are located at the manifold with 8mm banjos. I think the two bigger hole banjo bolts are oil and the two smaller hole banjo bolts are fuel..?
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
1999 FONTAINE FLT-7-35HBTW LOWBOY (A62613)
1999 FONTAINE...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
