The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
That's definitely a test for your grapple! It demonstrates the well thought out design and materials selection!
That is one of the many reasons why I bought from Everything Attachments!
No doubt! There's not much concern with the lifting of material, but the twist and pushing power of a tracked machine far exceeds what a tractor can dish out.
The tree hanging out of the side of it like that is cringe worthy for sure! :eek:
Glad it survived to grapple many more days!! :D
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,252
Small hiccup. Made a burn pile out of several smaller piles of various downed limbs, on the way back to the barn, I noticed my lid won't close completely....
I've looked at every edge and weld and nothing seems askew.
Left side is straight.
Right side is straight.
Middle is straight and secure.
The back is straight, secure, and has all the proper clearances.
From my limited examination, I can find nothing bent or broken. It simply seems the cylinder simply isn't extending fully. I plan on pulling the pin out one of the end of the cylinder and seeing if it is what is limiting the lid tomorrow. Does anyone happen to know what the measurement from the pin centers are when the cylinder is fully extended/lid fully closed?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,253
I recall people needing to adjust the cylinder sometimes. Just unscrew the shackle at the end till it closes the way you want. At least that's what I've read, I'm pretty sure.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,254
No, if the grapple closed properly when new, adjustment of cylinder should not be needed? Look elsewhere.
Are you greasing pivot points on a regular basis?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,255
Yep, just pull the pin, loosen the clamp and unscrew as needed.
It has happened before.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,256
Why? If it worked originally, why would re-adjustment be needed?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,257
I've put almost 30 hours on the tractor since getting the grapple, most of that doing simple mowing. I've made a couple burn piles and removed a few stones in that time, but I'd be shocked if I've opened and closed the lid more than 100 times. I greased it as soon as it came off the pallet, I've greased it three times since, and consider it to need grease again after today's work (which I'll be doing tomorrow morning and inspecting it further).
I agree that will likely be the "fix". But it concerns me that a threaded mounting point such as that may have "slipped" and messed up the threads. With it being pretty much new, I'd like to rule everything else out before messing with things.
Agreed.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,258
You might check your hydraulic fluid level?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,259
What are you using for your 3rd function to open / close your grapple? WR Long kit?
Dead center, fully closed is 20 1/8". My guess is the clevis may have skipped a couple of threads. It has happened before, but not very often. I would extend the cylinder clevis and loctite the clevis keeper nut.
Travis
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A55315)
2020 John Deere...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
