New Machine For Hillside Mowing
/ New Machine For Hillside Mowing #1
MetroHick
Petaluma
John Deere D160
Currently mowing with a JD D160. Tranny gone after 70 hours. Typical ZTR won't work as hills are too steep. need to be able to control the front tires. Does anyone have any experience or opinions on the Cub Cadet PRO Z 148S?
Link to machine - CubCadet - PRO Z 148S EFI
See picture of areas I need to mow below. Do you think this machine will handle it?
/ New Machine For Hillside Mowing #3
Man that is a lot of land to be mowing with a 48" mower. I would have 2 mowers the 48 for trim and a larger one for the rest.
/ New Machine For Hillside Mowing #4
I would look at what the commercial guys are using . They run their machines every day . Exmark seems to be very popular
/ New Machine For Hillside Mowing #6
Typical ZTR won't work as hills are too steep. need to be able to control the front tires. ]
What sort of control over the front tires do you think that cubby is going to have? It is just a "typical ZTR"...
From the manual:
If the slope is greater than 20 degrees/35
percent as shown on the slope gauge, do not operate this
machine on that area or serious injury could result.
Do not use a grass catcher on slopes steeper than 15
degrees.
Mow across slopes, not up and down. Exercise extreme
caution when changing direction on slopes.
/ New Machine For Hillside Mowing #7
Advance to about 1:11 in this video if you want to see a fun ride down a hill....
/ New Machine For Hillside Mowing #8
From the pictures it looks intimidating.
Our 2550 cuts safely across a steep road side, only because I can sit on the fender. The newer tractors, with protruding fender controls, wont let you do that.
Friends with zero turns love the performance except on hills.
I'd either ask for a dealer recommendation or a zero turn owner that has chains on the drive wheels to see if that will overcome the hill issue.
And don't forget to report back with us if you find a solution.
/ New Machine For Hillside Mowing #9
To cut safely on slopes you need to look at serious commercial mowers to avoid getting badly hurt or killed. You are lucky if your machine slides down the hill and comes to a stop. Have one rear wheel dig into a hole and now you are rolling and being rolled by your machine. The transition from being upright and rolling is so fast you can do nothing about it.
If you have a roll bar use it and wear the seat belt.
Ventrac Slope Mowing
There are also remote control units for the really steep grades. They use these industrial remotes to control locomotives in switching yards. It is not a RC car remote.
Taking the 200# operator off the seat immediately lowers the center of gravity making the machine more stable.
REMOTE CONTROL MOWERS FOR STEEP HILLS - YouTube
SPIDER - slope mowers, slope mower, spider mini, ild �1, ild �2
Dave M7040
/ New Machine For Hillside Mowing #10
My father in law mows his hillside that "appears" to be steeper than what is shown in that video with an exmark with duals. He has two, an older single wheel and a newer dual wheel that he said also has slower Center of gravity. They cut around 10 acres and he's demoed a John Deere and something else, husky? And he swears by the exmark.
/ New Machine For Hillside Mowing #11
Dave M7040
Interesting, does the mower know enough not to run over the operator?
/ New Machine For Hillside Mowing #12
Been there, done that (twice, once on a Bolens 1050 and once on a Cub Cadet LT1050) and have no interest in repeating the experience...
Aaron Z
/ New Machine For Hillside Mowing #16
We don't mow near the volume the Metro does. Nonetheless, we have hills and I'm tired of getting our Simplicity standard lawn tractor stuck on them so we're considering the HUSQVARNA R 322T AWD mower. I test drove and mowed with a couple zero steer models and now shy away for them.
/ New Machine For Hillside Mowing #17
My wife used to keep score on the "big hill" that I have to mow (and spray occasionally). The Gravely rider had good traction for 2WD but could not make it up the last 20' at crest of hill reliably. I came in one time with tires tracks down my back... yes, it happens fast and generally nothing you can do about it (Gravely was near 1000lbs and it certainly left its mark when it went over you. I knew it would be a challenge when I had the sickle mower on the front and going down the hill to start mowing, it pretty much was a semi controlled skid. I cut the field and then tried to get back up. I ended up dropping the mower at the bottom and just bringing the tractor home to get help.
Kubota handles hill fine in 4WD, Gravely machines are just collectors now..
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
90in. Work Bench (A65640)
90in. Work Bench...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
