Time for Chainsaw Chaps
/ Time for Chainsaw Chaps #22
On my list is also a pair of steel-toe boots. I've been pretty fortunate in that the first (and only time) I had a chainsaw get too close and personal I'd finished a cut and pulled the saw out really quickly and before the chain had completely stopped I'd brushed it against my pants. Cut my pants and removed a sliver of skin. I now, no matter how much I complain (being really hot out esp), put on chaps! A similar event occurred not too long ago, but it was against my foot, my toe. It left about 1/8" gouge in the toe of my boot. Another safety piece for me is that I will not operate a chainsaw unless my wife (or someone else) is near by.
/ Time for Chainsaw Chaps #24
Been wearing chaps for years and never heard that about old ones losing stopping capacity. Cure for hot legs is to cut in cool weather, by far my preference. Around here that's November.
Jim
/ Time for Chainsaw Chaps #26
I'm diabetic and when I use my splitter, many times the pieces drop on the top of my foot. I wear steel toe boots all the time, but that only protects the toes, I bought a pair of boots with metatarsal steel plate and now the wood just bounces off and my foot is protected.
/ Time for Chainsaw Chaps #27
I narrowly escaped serious injury in an incident similar to the OP's two weeks ago. Clearing medium brush for a path and chain made a 6" gash through both heavy canvas layers of my pants at mid-thigh. Incredible how quickly it happened and that there was no contact with my leg.
I got Stihl strap-style chaps the next day and have used them about seven times since that valuable lesson. I bought full safety pants when we started heating exclusively with wood after we moved here 14 years ago. The pants are hot and require removing boots to put them on/off, so I didn't use them. While not providing as complete protection as full pants or wrap-around chaps the convenience of the simpler strap style chaps makes it more likely I'll use them full time.
I've been cutting wood for over 30 years and feel fortunate for the near-miss warning. It also caused me to start using the chain brake when starting the saw, idling the saw, and making significant position changes(which I was doing when I had the near-miss). It has only been a couple of weeks so I only remember to set the brake about half the time. However, I intend to continue until it is habit.
/ Time for Chainsaw Chaps #28
Yikes!! How'd that happen?
Those in the know recommend the labonville chaps. Especially the ones that wrap around the calf.
X2
Been fortunate enough to avoid injury through the years, but came close once with a no-name cheap pair of chaps. :eek: Upgraded to Labonville and decided to get the "Competition" grade which has even more layers of protection. Worth every single penny.
Biggest temptation for me is not to gear up for those "just a couple quick cuts", or its "too hot" out. I combat this urge by trying to cut in fall/winter and to listen to these kind of stories. Sorry it happened to you and hope you heal up.
/ Time for Chainsaw Chaps #29
Never used chaps for years until I noticed a couple pairs of jeans had cuts in them. That day I ordered Labonville full wrap chaps and after a couple years of use recommend them highly. Don't forget a forestry helmet (I like the Rockman more than Labonville). The gear may be hot in the summer but I feel queasy cutting without them. Jim
PS, I also didn't know that oily chaps were not effective. Can they be washed to return their effectiveness?
Thanks to everyone for your kind words and recommendations. It is healing up well and it is a lesson I won't soon forget.
/ Time for Chainsaw Chaps #31
Any chaps are better than no chaps.
/ Time for Chainsaw Chaps #33
Answers to some questions posed here: Washing chaps can make them less effective, (it's detailed in the owner's literature that comes with most brands of chaps), because the safety is in the fibers in the chaps getting caught up in the chain's teeth, and thus stopping the 88 feet /second travel speed of the chain* from doing damage like the op experienced. When washed the fibers tend to mat down vs. being fluffier and the result is less effectiveness. Same with if they get real dirty or greasy/oily.
I noted a number of people in this thread said their accidents or close calls with chainsaw chains occurred when they were tired or too tired.
This is worth paying very close attention to. Using a chain brake when starting, changing location, or position, etc. is a very good, 'best practice' detail that can help prevent serious injuries from chainsaws.
Also, taking frequent breaks in one's work to cool off, drink water to keep hydrated. etc. can keep one's 'situational awareness' at a maximum.
I also try to never work alone with a chainsaw, even for a 'few quick cuts'.
Think about how a chainsaw functions. It is designed to make mincemeat out of wood at a very rapid pace. It turns wood into saw chips instantaneously and thus treats skin and bone the exact same way. It does not discern the difference between wood and flesh.
Because of the type of spacing of chain teeth they cut skin by ripping it to pieces which means that one's chances of bleeding out before making it to the ER are also increased, and that doesn't even take into account the shock factor.
As the OP said, he didn't even know he had cut his knee until he saw the blood.
So, knowing everything one can about how one's saw and it's chain function, knowing best practice handling of the saw, wearing ALL recommended safety gear WHENEVER using a saw, all reduce the likelihood of a catastrophic incident.
Technically, the chainsaw chain should come to a rapid halt on it's own within a few seconds of the trigger being released. If it does not, or continues to run around the bar, then the saw is out of adjustment and needs to be serviced before further use.
One way to stop the chain even faster, aside from applying the chain brake, is to purposefully touch the bar/chain to a piece of wood within easy reach of the saw, using all the necessary precautions against kickback/rollback, etc.
Here's the facts Jack:
From Google inquiry as to speed of a chainsaw's chain~
"The piston ring speed on the average chainsaw travels 2,500 surface feet per minute. A chain slides across the surface of the sawbar rail at around 5000 feet per minute. The chain is moving at 55 to 60 m.p.h. or a mile per minute ( 88 feet per second* ).
One last thing; anyone considering the cost of chaps should seriously consider the cost of a visit to the ER to triage their torn knee, leg, calf, etc. Essentially NO comparison, IMHO.
Here's to the OP~ Sorry for your unfortunate loss to your saw's chain. Thankfully it wasn't worse. Get well soon and be safe in future.:thumbsup:
/ Time for Chainsaw Chaps #34
I know what you're saying, but chaps and other protective garments to sometimes require cleaning. As you mention, oil will reduce the fluffiness of the protective layers and make them less effective. I'm not saying you should wash them every weekend, but if they're dirty, wash them. Stihl says their chaps are machine washable (with limitations): Checklist: Washing instructions for personal protective equipment | STIHL Blog
Labonville and the USFS have a different method:Chap Specifications & Care
/ Time for Chainsaw Chaps #35
Ah, yes AND NO! They're outdoor work protective gear and as such better to have them somewhat 'dirty' than less effective.
More importantly, careful when you say to those here to 'wash them'. I mention this because what you linked to, in particular, the Labonville care and use statement, highlights in RED INK to:
NEVER MACHINE WASH OR DRY ANY Kevlar or nylon based safety clothing. AND to NEVER use any CHLORINE BASED BLEACH.
/ Time for Chainsaw Chaps #36
I've cut firewood and cleared brush for over 30 years and have never had an accident but I finally wised up and bought some Labonville chaps and a Husqvarna helmet with a fine mesh face screen a few months ago.
The chaps are hot but I try to avoid running the saw when it's hot anyway. Too much poison ivy slapping at me when it's in full summer foliage.
"Are there chaps that are cooler in hot weather?"
With chaps, I find I can wear shorts and still feel safe.
Some may say shorts and chainsaws aren't a good mix, but beats wearing pants without chaps. Though pants may help with briars, ticks, & sawdust, they provide a false sense of security.
..if you're still too hot, you can wear a**-less chaps like they do in the Gay Pride Parades. :laughing:
Hahaha. That hit as funny as he**.
/ Time for Chainsaw Chaps #37
Well, between building a log cabin in Alaska and cutting firewood - I've been lucky for over 40 some years. I had my CS grab the front of my Deluth Trading canvas pants once - balled up and stopped the saw. Only a slight scratch on my leg - maybe I've been VERY lucky.
I'm done cutting, thinning & chipping for the year - so I guess I should look into getting a pair chaps. I don't cut firewood any more and all my thinning is done in the spring and in the early morning, at that. I'm always done by 10 AM - back cleaning up and drinking ice tea. Fortunately, no neighbors to hear me if I start up at 6 AM. I tried working in shorts one day - the underbrush scratches the snot out of my legs. I always wear long pants and a long sleeved shirt.
/ Time for Chainsaw Chaps #38
My respect for the saw grows over time. When I was in my 20's I cut wood with ear muffs and safety glasses. In my 30's I started using chaps. In my 40's I started using steel toe boots. Five years ago (50's) I purchased helmet with face shield, and first pair of kevlar gloves. This year, following an accident where a friend lost a finger to a table saw (she was alone -- could have been worse), I am considering a two-way radio in case my cutting partner/wife is out of shouting range. (Chest holster for radio???) Maybe my increasing awareness will offset my slower reaction time/ lower strength as I age?
Question, now that I'm almost healed re; chaps. I am looking at the Forester wrap around style chap, but they have 3 styles. One has the straps on the back, another wraps around and they use Velcro and the last one has a zipper and velcro over that.
I kind of like the zipper with the velcro overlay. What are your thought's? Forester Chain saw Chaps - Apron, Wrap Around, Zip Chaps - Chainsaw Pants
207270 (A52708)
207270 (A52708)
2014 Freightliner Bucket Truck (A61307)
2014 Freightliner...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
2007 International 4300 Altec DM47 TR 47ft Insulated Digger Derrick Truck (A60352)
2007 International...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
