BX23S - Should i keep the fuel filter
   / BX23S - Should i keep the fuel filter #21
My BX plugged the rear filter 2 or 3 times, always in the winter. It didn't reallly looked gelled, I'd cut them open and they looked OK, but would be almost 100% plugged. I installed a Racor but the kit posted above looks nice. I spent a lot of time getting mine hooked up and mounted. Protecting the engine? A BX is probably pretty forgiving, indirect injection, lower pressures, so not a huge deal but the plugged filters suck.
   / BX23S - Should i keep the fuel filter #22
For a jelled fuel filter just warm it up. The jell disappears. (Don't even have to remove it. Heat gun in place)
   / BX23S - Should i keep the fuel filter #23
Yeah, we do that a lot here in Ky.:laughing::laughing::laughing:
   / BX23S - Should i keep the fuel filter #24
There's no PC in saying it makes sense, at least to most people to spell a brand's name correctly, but if you're heii bent on doing it against the grain, then go for it.:confused3:
As far as damage or potential damage from gelled filters, yes it would be inconvenient, but the larger issue is what is getting to/through the IP? With ULSD there's less lubrication of critical parts than with previous higher sulfur content fuel. So if you don't particularly care about how you IP and for that matter injectors function, or get lubrication, or in this case lack adequate lubrication then a 2 to 20 micron filter kit would be wasted on your tractors.
Now granted, a stopped engine due to gelled fuel isn't exactly breaking news on land, but in the marine field the same result can mean serious consequences.
Egon is correct in saying one can heat up the filter in place to melt gel conditions. We used to do just that when Mercedes diesels would come down off the mountains near my shop frozen solid after travelling up from down country where the fuel wasn't 'cut' for winter conditions.
My SOP was to take the car off the flatbed, put it on the lift, drain the oil and filters,(if warranted by mileage) including the fuel filters, then raise it up to the ceiling and let my waste oil burner at 80 degrees room temp melt any gelled fuel in the lines. AND we'd add Red Line Diesel Catalyst, the only approved at the time, additive Mercedes would allow without warranty issues, in their engines.
Thanks customers for the oil to burn to heat my shop, too!:thumbsup:
Here's something else to consider for those whose filters gel/freeze in cold climates, especially if the tractor rests outside.
A heat strip, (12 volt to run off the tractor's battery, or similar setup).
Dew Not 3" Dew Heater Strip - DN4
   / BX23S - Should i keep the fuel filter #25
Ron,
your right, your dealer has no idea because i bought the complete kit off from ebay for $175 (ebay name: botasandy)
The folks i bought the kit from actually build the kit... The filter assembly itself is genuine kabota item and the dealer can get them.
The filter assembly is actually made for the M5700 kabota tractor #15521-43015 (costs around $50 to $60 just for the filter assembly)
These folks make up all the correct hoses`s & brass fitting`s to do the complete install. Their work is absolutely stunning.
They send VERY detailed instructions on how to install it. It also comes WITH the special built mount to install it on the BX tractors.
I will try to post it in here where i bought the kit.
Kubota BX Fuel Filter relocation kit BX237,BX24,BX25D,BX23S FEL L24,L243,L34 | eBay
View attachment 513329.
Looked at the web site; where this is mounted I would rip it off in a heart beat working in the woods. I am trying to find a system I can mount inside the frame where I can install a guard or above the aftermarket skid plates.
Ron
   / BX23S - Should i keep the fuel filter #26
You can get the same filter housing for about $55, I mounted the $40 B series filter on my BX2230 and G2160 using a part of a flat bracket, I bent in a vise and it is mounted on side of engine by the injection pump, with the fuel in, out and bleed return lines hooked up so it self bleeds. No brush can get to it and is easy to drop bowl and dump water out.
Cost was less then $60 each and even used Gates Barrier fuel line. Left inline filter before electric pump but as everyone knows they can pass water and that is where the B series filter traps all the water in the bowl.
David
   / BX23S - Should i keep the fuel filter #27
Ron
I checked it too... no more presently available. I have done most all of my woods work. Probably could fab a shield if you think it necessary. Having had to replace the lower filter twice in 200hrs, I like the idea. Probably time to replace the lower one again!
Ron
Ron,
No rules apply to mounting it, as you can put it where ever you like, as long as it sits lower than the fuel tank.
You could make a shield to protect it too if your handy. I work in and around big rocks and dirt everyday,
havent had an issue, and i dont even have a protective shield around the fuel filter assembly.
   / BX23S - Should i keep the fuel filter #29
Or just trade the tractor!!! :D:laughing::cool2:
Dragoneggs,
They`ll have more kits very soon. I personally know these people that make the kits, you`ll get an outstanding kit from them. I do know they are on vacation for a couple weeks right now, so check back with their ebay auction. I know once you see their kit, you`ll be VERY impressed. Super nice people too, they stand behind their BOTA products. If you ever need help or have a question, they are right there to help you in a heartbeat, but i doubt you`ll need to ask for their help because the kit and the instructions are excellent. They have excellent pictures and arrows (with captions) pointing to everything within the installation instructions.
Though the kit is expensive, the hard work is already done for you. No hunting down parts, no running around wasting time to figure out what you need. I will always gladly pay extra so that i dont have to fry my brain to figure out what i need, not to mention all the running around. The kit came to my door in 2 days from NC to NY.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
NEW Thiessen Track Closer Disk (A56438)
NEW Thiessen Track...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
