Loader Pallet Forks
/ Pallet Forks
You are funny, which is why I prod you occasionally for a reaction. If you get down this way, we will take care of you on a set of forks.
I know but I do like prodding back. It's always more fun if it's a two way street. There are so many thin skins around these days it's hard to have much fun anymore.
/ Pallet Forks #34
Hahaha I hope your using nerf forks, but I bet a bale spear could get someone's attention like maybe the one who wrote the manuals
/ Pallet Forks #36
what do yall think of hydraulically adjustable forks? ..kinda heavy at 436 LBS but maybe for the larger utility tractors?
Prowler Heavy Duty 48 Inch Hydraulic Sliding Pallet Forks - 4 Lbs, Attachment | eBay
oh, and expensive :eek:
Those are very cool. I think the handiest thing for a forklift to have is side-shift, second handiest is fork positioners. These options are so valuable on a real forklift. On a tractor, most guys aren't doing precise positioning like loading out a truck with pallets, so side-shift isn't as needed. The fork positioners would be pretty handy for some applications like moving logs, rocks and other odd shape non-pallet loads.
As you note, they are heavy. I would think a skid-steer wouldn't notice the extra weight, but any tractor with a capacity under 1500 lbs might not appreciate the loss of lifting capacity.
/ Pallet Forks #37
I can see where a fella might not need adjustable forks, for example if all you lifted was regular pallets, but personally, I adjust my forks darn near every time I use the things. I move and load logs pretty often. I want my forks at max width for that. Sometimes I use them for digging out buckthorn. I want them all the way together for that. Just my .02.
That's my thinking as well. I'm looking to buy forks now, and the fixed width (only 21" between forks) will make it pretty tough to pick up and carry logs longer than 8-10 feet I imagine. If a log or other long load isn't perfectly centered over those two forks, it's gonna tip one way or the other. I'll likely never be lifting more than 1000 lb, which is why I'm looking at Titan's clamp on forks. I really can't justify spending the big dollar on the dedicated fork attachment with adjustable width forks.
/ Pallet Forks #38
Clamp on forks have have a lot of limitations. They will move easy if you bump something. But moving logs might be a challenge. Not saying it can’t be done. A lot of people buy clamp on forks, only to later buy a set of real forks due to this.
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
500BBL WHEELED...
