Loader Pallet Forks
/ Pallet Forks
/ Pallet Forks #14
Thanks, I saw those but I want adjustable forks in order to extend the usefulness of the forks.
I can see where a fella might not need adjustable forks, for example if all you lifted was regular pallets, but personally, I adjust my forks darn near every time I use the things. I move and load logs pretty often. I want my forks at max width for that. Sometimes I use them for digging out buckthorn. I want them all the way together for that. Just my .02.
/ Pallet Forks #16
Bought these: Small Compact Tractor and Mini Skid Steer Pallet Forks:
Small tractors don't have huge loader capacity so I wanted something on the light side. Those are 2200 lb rated and that's more than my loader can lift anyway. They weigh 238 lbs vs 400+.
Too bad they don't fit on the 3 point also:
/ Pallet Forks
/ Pallet Forks #20
That looks great for moving hay but not much else.
I have that same set-up on my 2538. The "forks" actually move. There are about 6 or 8 different holes they will go in. The middle one can be taken out all together if you want to use as pallet forks. Tractor Supply sells the whole set-up for around 500 bucks.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
