Loader Pallet Forks
/ Pallet Forks
/ Pallet Forks #14
Thanks, I saw those but I want adjustable forks in order to extend the usefulness of the forks.
I can see where a fella might not need adjustable forks, for example if all you lifted was regular pallets, but personally, I adjust my forks darn near every time I use the things. I move and load logs pretty often. I want my forks at max width for that. Sometimes I use them for digging out buckthorn. I want them all the way together for that. Just my .02.
/ Pallet Forks #16
Bought these: Small Compact Tractor and Mini Skid Steer Pallet Forks:
Small tractors don't have huge loader capacity so I wanted something on the light side. Those are 2200 lb rated and that's more than my loader can lift anyway. They weigh 238 lbs vs 400+.
Too bad they don't fit on the 3 point also:
/ Pallet Forks
/ Pallet Forks #20
That looks great for moving hay but not much else.
I have that same set-up on my 2538. The "forks" actually move. There are about 6 or 8 different holes they will go in. The middle one can be taken out all together if you want to use as pallet forks. Tractor Supply sells the whole set-up for around 500 bucks.
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
13042tx (A55973)
13042tx (A55973)
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
