Loader Pallet Forks
/ Pallet Forks
/ Pallet Forks #14
Thanks, I saw those but I want adjustable forks in order to extend the usefulness of the forks.
I can see where a fella might not need adjustable forks, for example if all you lifted was regular pallets, but personally, I adjust my forks darn near every time I use the things. I move and load logs pretty often. I want my forks at max width for that. Sometimes I use them for digging out buckthorn. I want them all the way together for that. Just my .02.
/ Pallet Forks #16
Bought these: Small Compact Tractor and Mini Skid Steer Pallet Forks:
Small tractors don't have huge loader capacity so I wanted something on the light side. Those are 2200 lb rated and that's more than my loader can lift anyway. They weigh 238 lbs vs 400+.
Too bad they don't fit on the 3 point also:
/ Pallet Forks
/ Pallet Forks #20
That looks great for moving hay but not much else.
I have that same set-up on my 2538. The "forks" actually move. There are about 6 or 8 different holes they will go in. The middle one can be taken out all together if you want to use as pallet forks. Tractor Supply sells the whole set-up for around 500 bucks.
CFG Industrial 680 QA Hydraulic Hummer (A60463)
CFG Industrial 680...
AGT Industrial SSECAG-Y QA Auger w/ Bits (A60463)
AGT Industrial...
2010 John Deere 4720 (A60462)
2010 John Deere...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A60736)
2012 BRUMLEY...
CAT 336E (A58214)
CAT 336E (A58214)
