anyone have experience with the Kawasaki Mule Pro?
/ anyone have experience with the Kawasaki Mule Pro? #41
We have the shock preload also on mid notch. I didn't notice bottoming though. I will check it tomorrow by hitting few bumps.
/ anyone have experience with the Kawasaki Mule Pro? #42
Cant say I have ever noticed that on mine - it is fairly smooth throughout the entire range and at slow speeds I never noticed any of the shocks bottoming out. May want to give your preload a turn and see if that helps, if not something has to be wrong.
/ anyone have experience with the Kawasaki Mule Pro? #43
Front shocks rebound question:
My front shocks are bottoming out on rebound after crossing a small bump at maybe 5mph at certain angles.
Now, compression works real smooth. Is this normal for these shocks? It feels like a bump while going up hill with nothing under the front wheel. For reference I also have them set at the halfway notch.
I tried some rougher terrain and bumps yesterday. Didn't notice bottoming on either side of the shock stroke.
/ anyone have experience with the Kawasaki Mule Pro? #44
Another way to duplicate what it's doing is to grab the end of front bumper and pull up quickly. Mine has a very noticeable "thud" when it reaches full extension.
/ anyone have experience with the Kawasaki Mule Pro? #45
I tried this test and no thud. Actually I can't lift hard enough to hit the stop. I haven't moved mine from how it was set up from the factory because the ride is so smooth. Like Redneck, I don't get any bottoming on either stroke. Hope you get it sorted out!
/ anyone have experience with the Kawasaki Mule Pro? #46
I just returned from the garage. Tried to lift the front. I was able to lift it about 8-10" no thud. My guess is there is something lose or flexing making the noise.
/ anyone have experience with the Kawasaki Mule Pro? #47
I'm coming up on my first oil change and I ordered a rubber plug from Kawasaki that will make oil changes much easier. The part cost $8 and the part number is in the attachment. Here's what you need to do to install it.
/ anyone have experience with the Kawasaki Mule Pro? #48
Did the same thing after my last oil change. Worth every dollar!!!!
Double checked the Mule FXT - also can't lift it high enough for a thud so I want out and crossed the driveway ditch at different angles at slower speeds and no issues at all.
/ anyone have experience with the Kawasaki Mule Pro? #49
As someone mentioned already, has the same Chery 812 engine as the Gator. Yep, a Chinese motor but, a very very well-built one. Has forged rods, an enamel painted INSIDE the block, and is absolutely a beast of an 800. Bullet-proof, if you do normal maintenance the same as ANY engine. So what puts this engine above the 800 class engines of say, Polaris or any other manufacturer of Utility sidexsides?...it's a car-engine! It's used in several vehicles around the world, and that's true for a reason. It's advanced in technology and longevity. If every pictures tells a story, then look at this one: Kawasaki has a plethora of house engines to use, yet in a flag-ship model, they chose THAT motor over their own. It's built like a nascar engine! Other side x sides are getting ATV/Lawn-mower engines...your mule is getting a car engine! Should be just about enough to take care of the engine questions, anyway. As far as the rest of the machine...Kawasaki is a great company, so I'd bet it's gonna be great for you.
/ anyone have experience with the Kawasaki Mule Pro? #50
Recall:
I heard the fuel pump has a problem. I really dread taking a new machine back to the dealership for any reason.
/ anyone have experience with the Kawasaki Mule Pro? #51
/ anyone have experience with the Kawasaki Mule Pro? #52
Sprayed my soybeans today using the Mule, handled the weight very well!
/ anyone have experience with the Kawasaki Mule Pro? #53
I'm looking at spray rigs for my Mule Pro FX. I've looked at Enduraplas and F/S so far. If I read the name on your photo correctly it looks like "Demco". What is the model number, tank size, boom width, etc.?
Also, I have not been able to find the oil filter part number in the owner's manual. What filter works?
Thanks, Vic
/ anyone have experience with the Kawasaki Mule Pro? #54
/ anyone have experience with the Kawasaki Mule Pro? #55
I am currently working on a construction site. We have any imaginable side by side here. So far I got ride in Kubota, JD, Kava Mule 500 and one, I think, golf car. Kawa Mule Pro beats them all in comfort ride, controls, shifting gears, lack of rattles and in general handling. I was specifically disappointed by Kubota ATV. It looks way flimsier than the Kawa Mule Pro.
60� Pine Straw Rake (A64047)
60� Pine Straw...
Clark GPX25 Propane Forklift (A64047)
Clark GPX25...
Arrow Quip 10' Corral Panel X 5 (A64047)
Arrow Quip 10'...
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
4R CHISEL RIPPER BEDDER (A63291)
4R CHISEL RIPPER...
2013 Bobcat T650 Compact Track Loader (A64047)
2013 Bobcat T650...
