anyone have experience with the Kawasaki Mule Pro?
   / anyone have experience with the Kawasaki Mule Pro? #41
We have the shock preload also on mid notch. I didn't notice bottoming though. I will check it tomorrow by hitting few bumps.
   / anyone have experience with the Kawasaki Mule Pro? #42
Cant say I have ever noticed that on mine - it is fairly smooth throughout the entire range and at slow speeds I never noticed any of the shocks bottoming out. May want to give your preload a turn and see if that helps, if not something has to be wrong.
   / anyone have experience with the Kawasaki Mule Pro? #43
Front shocks rebound question:
My front shocks are bottoming out on rebound after crossing a small bump at maybe 5mph at certain angles.
Now, compression works real smooth. Is this normal for these shocks? It feels like a bump while going up hill with nothing under the front wheel. For reference I also have them set at the halfway notch.
I tried some rougher terrain and bumps yesterday. Didn't notice bottoming on either side of the shock stroke.
   / anyone have experience with the Kawasaki Mule Pro? #44
Another way to duplicate what it's doing is to grab the end of front bumper and pull up quickly. Mine has a very noticeable "thud" when it reaches full extension.
   / anyone have experience with the Kawasaki Mule Pro? #45
I tried this test and no thud. Actually I can't lift hard enough to hit the stop. I haven't moved mine from how it was set up from the factory because the ride is so smooth. Like Redneck, I don't get any bottoming on either stroke. Hope you get it sorted out!
   / anyone have experience with the Kawasaki Mule Pro? #46
I just returned from the garage. Tried to lift the front. I was able to lift it about 8-10" no thud. My guess is there is something lose or flexing making the noise.
   / anyone have experience with the Kawasaki Mule Pro? #47
I'm coming up on my first oil change and I ordered a rubber plug from Kawasaki that will make oil changes much easier. The part cost $8 and the part number is in the attachment. Here's what you need to do to install it.
   / anyone have experience with the Kawasaki Mule Pro? #48
Did the same thing after my last oil change. Worth every dollar!!!!
Double checked the Mule FXT - also can't lift it high enough for a thud so I want out and crossed the driveway ditch at different angles at slower speeds and no issues at all.
   / anyone have experience with the Kawasaki Mule Pro? #49
As someone mentioned already, has the same Chery 812 engine as the Gator. Yep, a Chinese motor but, a very very well-built one. Has forged rods, an enamel painted INSIDE the block, and is absolutely a beast of an 800. Bullet-proof, if you do normal maintenance the same as ANY engine. So what puts this engine above the 800 class engines of say, Polaris or any other manufacturer of Utility sidexsides?...it's a car-engine! It's used in several vehicles around the world, and that's true for a reason. It's advanced in technology and longevity. If every pictures tells a story, then look at this one: Kawasaki has a plethora of house engines to use, yet in a flag-ship model, they chose THAT motor over their own. It's built like a nascar engine! Other side x sides are getting ATV/Lawn-mower engines...your mule is getting a car engine! Should be just about enough to take care of the engine questions, anyway. As far as the rest of the machine...Kawasaki is a great company, so I'd bet it's gonna be great for you.
   / anyone have experience with the Kawasaki Mule Pro? #50
Recall:
I heard the fuel pump has a problem. I really dread taking a new machine back to the dealership for any reason.
2012 Infiniti QX56 SUV (A55853)
2012 Infiniti QX56...
2019 Dodge Durango AWD SUV (A53424)
2019 Dodge Durango...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
Black Steel Diamond Plate (A55758)
Black Steel...
Mobile toilet with shower (A53424)
Mobile toilet with...
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
