Stuck with a BH92 backhoe I can't use
   / Stuck with a BH92 backhoe I can't use
I can not imagine a Kubota dealer ever just dropping off a BH on someone's front lawn, knowing that it is incomplete and may not be usable. This simply makes no sense. There is more to this story we have not been told.
Yeah I told them to drop it off if they can't get the brackets in this week. After 2 months I am out of patience.
   / Stuck with a BH92 backhoe I can't use #32
That's a really bad move that will make your options even worse. They are contractually obligated to deliver you a fully-working, new tractor and backhoe. Right now they have not met that obligation but the minute you tell them to just unload it at your place in non-working form changes their obligation to you because you took delivery of it knowing it doesn't work.
By the way, I mostly blame myself for even purchasing it before all the parts were together. That was my bad.
I'm definitely re-thinking that since I have been discussing with everyone here, guess I wasn't thinking clearly.
   / Stuck with a BH92 backhoe I can't use #35
By the way, I mostly blame myself for even purchasing it. That was my bad.
This is ridiculous! Blaming yourself for what- ordering a tractor and hoe?!
You didn't answer the question about what paperwork you have on the deal. I'm beginning to smell a trolling effect here....
This story as told so far makes no sense. You, the OP don't want to press the dealer owner, because he's a nice guy, because you don't want to cause a problem?! Again, makes NO SENSE. You're supposedly due a backhoe, that has taken 2 months to not show up and you're willing to just take some pieces of the puzzle?! I don't think so. I think that unless you start telling the real story this one is bogus.
What model tractor? What date of purchase? What model hoe and serial numbers on both pieces of equipment. If you can't produce any of the above, I call bogus BS story.
Ok, forget it I'm done, thanks to the guys for the advice. Geez thats why I hardly ever post.
   / Stuck with a BH92 backhoe I can't use #37
To be clear, you ordered a tractor WITH a backhoe, not a tractor and a standalone bachhoe on maybe another trip to the dealer? I could see them missing ordering the mounts if it was the latter as I suspect they would be different for different tractors. Not excusing their actions but it could help understanding what happened. Stay after them and Kubota and you will get what you need.
   / Stuck with a BH92 backhoe I can't use #38
You need to put your CM filter on when you read what he posts. :D He normally has very good content.
   / Stuck with a BH92 backhoe I can't use #39
Really? It's that easy for you to bail on this thread. That just makes me think I'm on the right track saying the entire story is BS.
Say its not BS. So where is your proof that what you're saying isn't some Kubota bash by a dissatisfied 'customer' or some other lame scenario?
I'm why you hardly ever post here? Right. I'm the problem?:confused2: I gave you a way to solve the supposed situation; to which you gave no response. I've helped lots of people here on TBN over many years with dealer and manufacture issues, and I've called out some real lame trolls who were just bashing whatever for their own purposes. Why fold now? If you have a legitimate case then press it. Otherwise disappear.
I'm betting on you being done.:confused3:
   / Stuck with a BH92 backhoe I can't use #40
CM is right although maybe not PC. I would not take delivery of an expensive piece of equipment missing functional parts and I would not be debating if it was my fault either.
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
ALLMAND 45KW MAXI POWER GENERATOR (A50854)
ALLMAND 45KW MAXI...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
