Adjusting valves
/ Adjusting valves #1
winston1
Super Member
gilmer tx
Bobcat CT235
Curious as to whether any of you have adjusted your valves and if so how did you find the adjustments. The repair manual schedule shows this task at 800 hours. My CT235 has 1714 hours and I have owned it since 12?? hours having no idea what was done to it in prior history. Sort of thinking I may need to do this even though I have no reason to think they are out of adjustment. Comments?
/ Adjusting valves #2
I've had the same question and also note that in 12 years on TBN I've never seen a discussion of valve adjustment. A quick search shows that I've missed a few discussions, about one every year or so, but that basically it just doesn't seem to be an issue. I imagine if an engine is not performing well it would be something to check but other than that why bother....
/ Adjusting valves
I suppose I don't know how to use the search field very well. Several years ago I could use it and find most anything, nowadays I struggle.
/ Adjusting valves #5
Purchased a Case 195 that ran fine when cold as tested at sellers yard, after getting the tractor home and working it for a bit would not restart until it cooled down.
On checking the valve clearances found that the intake was near zero clearance, after making the adjustments the tractor ran fine cold or hot.
The Kohler engine is a PITA having to remove the carburetor to make tappet adjustments.
/ Adjusting valves #6
Hey, IT, do you recall on one of my JD rebuild threads I set the valve lash? Anyway, I know you
saw it, and, as I recall, that engine with maybe 2000 hrs was still nearly within spec. That was
a pleasant discovery.
I seriously doubt the rental yard I bought the tractor from ever did it. My own Kioti is nearing
700 hours, but I do not intend to check lash for quite a while.
/ Adjusting valves #7
Well some times valve stems do wear ergo need adjustment.
I inherited a gas generator that had 0 compression.
Did a tear down and the end results were that the valve stems were worn so bad that the valves never closed.*
A simple adjustment put that gen set back to operating specs.
800 some hours simply plaid havoc on the softer stems. (better than wearing out the cam lobes)
* gen set had over 800 hrs on the tack!
/ Adjusting valves #8
I didn't remember that thread but as noted earlier, my descent into senility is going very smoothly. Did I already mention that?
/ Adjusting valves
That is interesting, mine is a little bumpy as we go along. :D
/ Adjusting valves #10
Diesel engines do not suffer the valve face and seat erosion gasoline engines do, which is the main reason gas engines' valve clearances close up. Back-in-tha-day, when gasoline contained tetraethyl lead, the issue was not as severe, but with the advent of lead free gas, bingo. When manufacturers began using hardened valve seats and the metallurgy of the valves themselves improved, the issue lessened. I suspect the lubricating action of the diesel fuel reduces, if not eliminates the erosion
/ Adjusting valves #11
I'm not so sure that the metallurgy hasn't already caught up. Last time I had a valve job done was in 1977. I've owned at least ten gas powered vehicles since then and kept most until at least 150K miles.
/ Adjusting valves #12
Exactly what I was trying to get across; lead free gas was federally mandated in '75, I believe, and it was then the issue began. The metallurgy didn't catch up for several years. I remember doing engine rebuilds on engines with either hydraulic or mechanical lifters where the seats and valve faces had eroded to the point of needing replacement, not refurbishing, as was not the case with pre-nonleaded fuel. Perhaps we might get some input from diesel mechanics as to the frequency of valve clearance maintenance on tractors, which is after all, what we're discussing
/ Adjusting valves
After pondering everyone's responses I decided to adjust my valves. Was raining this morning so I went at it. Took a few pictures for what it's worth. I removed the hood and later the muffler as I found the cover would not come out without the muffler being removed. A bit difficult reaching some of the bolts and nuts but that all went ok. I found #1 intake @ .008, exhaust @ .012, #2 intake .012, exhaust .015, I did not check #3 but know it was also excessive. Manual calls for .0039, I set all where a .004 would slide under but a .005 would not. Manual states to remove the timing window and set flywheel at TDC. The loader frame covers that window and I wasn't about to take the loader frame off for this operation. Watching the valves I know I was close to TDC when I checked and made my settings.
I don't know how many of you have the repair manual but I can tell you figure 70-80-10 is not correct. It shows exhaust valves closest to the front or gear case. They are just opposite. I am no Bobcat mechanic but have worked on enough engines to know the difference. I even tested it making sure senility had not over taken me. I had the glow plugs out which allows easy turn over using the fan belt. I first opened the front valve, blew air through the glow plug hole and sure nuff, it came out the air filter, I then opened the second valve, did the same and sure nuff, air came out the muffler. I wish I had made a video before and after as I think it ran a little quieter.
Finally, I am glad I did this, they did have much more clearance than I approve of. I did not remove the rocker arm cover gasket. It stuck to the head so I just put the cover right back on top of it and buttoned her up. It is a preformed gasket that probably sticks up 3/8" or so. Rambled long enough.
/ Adjusting valves #14
Thanks for the write up and photos. Does the motor run any differently after adjustment? Had you noticed any difficulty starting etc before doing the adjustment?
/ Adjusting valves
Had not had any difficulties, it has been running fine. I only moved it from my garage into the tractor shed after making the adjustments. I don't expect any difference but as stating earlier I did think it might be a little quieter. If I notice anything different after running with a load for awhile I will report in. I guess the biggest reason I decided to adjust is because of the manual schedule saying 800 hours and I had 1700. Over twice the recommended. I'm glad I did it, now I have peace of mind.
/ Adjusting valves #17
That's interesting. My CK30 manual specs .25 and .30mm for the clearances. Equal to
.0098 and .0118 inches. Your specs are half that, and your tractor seems to be initially
adjusted at the same specs as in my manual.
I am used to seeing about .008" for both on other 3-cyl tractors.
/ Adjusting valves #18
Just found another spec. My engine is the 3A150 and has above specs. There is also an engine
called the TD1300 which has the .1mm clearances (.0039").
/ Adjusting valves
Hmmm! Reckon my manual could be wrong? I would sure hate to burn valves. I have run it hard since making the adjustments and it runs great. Looked back in manual and find the 225 and 235 both show .0039 and the 230 shows .0098 and .0118. I find this interesting. Wondering what would cause the difference in the similar engines.
Back again. Old age seems to cause my brain not to function well. Can you believe I had the rocker arm cover out and in my hand and didn't even notice. I was depending on the manual to be correct. There is a tag on the rocker arm cover with valve lash posted at .25mm intake and .3mm exhaust. Just what dfkrug shows as 0098 and 0118. Would there be consensus to believe the tag and junk the manual specs? Bad when you can't believe what you read. The tag on the engine states 3A165LWH which is what the manual shows. I may call Bobcat in the morning and try to get an explanation.
/ Adjusting valves #20
I would trust the valve cover #s over what's in the manual. Your 3a165 engine is
prob exactly like my 3a150, except for 1.6 liters instead of 1.5.
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
2014 F-150 STX (A56438)
2014 F-150 STX...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2019 Kubota MX5800 HST Tractor (A61166)
2019 Kubota MX5800...
