where to purchase multiple chains?
/ where to purchase multiple chains? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
Folks, we use Echo pole saws quite a bit and what we do is quite hard on chains. So I see outfits selling 10 packs of chains which I'd like to purchase but I can't find any of them selling the little ones we use. Below is the chain size info. Does anyone know where we could purchase these in quantity??? Not interested in bulk chain we need to cut and assemble. Thanks!
39 Chain Gauge: 0.050" Chain Pitch: 3/8" File Size: 5/32"
/ where to purchase multiple chains? #3
I'd also check with Left Coast Supplies. Great folks to deal with. Might have to call for accurate shipping info.
Thanks Teachu2, That is a good price, my only hesitation is the last OR chain I bought, had several broken teeth in no time. I've not used any since. Maybe just a bad batch?
/ where to purchase multiple chains? #6
are you coming in at bad angles / cuts, and causing chain to get pinched? putting to much extra pressure on chain, vs letting the chain cut itself down through the trees/limbs under its own weight? is the oiler working, and keeping things oiled? are you pressing the oiler button every so often to help keep chain oiled? are you putting to much tension on the chains?
pinching, and nailing rocks or nails or fence wire here. and watching from buzz buzz, to buzzzzzzzzzzzzzzzzzzz buzzzzzzzzzzzzzzzzzzzzzzz due to missing teeth.
/ where to purchase multiple chains? #7
I've been running Carlton 3/8lp. I think it's called n1 or something like that.. It was cheap and seems very good.
Thanks Guys. I'll check out these retailers and let you know what I find. I'll also ask if our area saw shops can do close to $10 per chain for a volume sale. We like to give them that chance and help keep there doors open........
Thanks for the help!
Our Carqest dealer said he could do $9 per chain. Problem solved! Thanks to all for your help with this.
/ where to purchase multiple chains? #10
What brand and model of chain are they selling?
/ where to purchase multiple chains? #11
Since I've been running saws as a homeowner I've use Stihl chains. (Back in the Forest Service I used whatever they gave me). I recently bought an Echo. The chain that came on it would go dull much quicker than Stihl chains. The cutters are a lot shorter so it wasn't going to last as long. Then some links got stiff so I threw it out. I replaced it with an Oregon and it looks like it'll last like the Stihl chains.
Long way of saying that the chain's quality can make a significant difference in its value. A buck or two more for a chain that lasts significantly longer may make financial sense.
This photo is the box of the most recent chains we picked up. To reiterate, we don't normally break teeth off, but did when we purchased an Oregon one (unknown model) some years ago and it had three teeth broke off asap.. We normally run Stihl chains and have had very good luck with them. I'm not sure we've ever lost a tooth on the Stihl's. Our work is tough on chains and we go into the field with two saw heads, two power units, files and 4 chains. Plus all the usual tools and a regular saw as well. I have the MS260 which is a professional model of there's. Do like that unit.
ericm979, I'm a B sawyer by the NFS.
/ where to purchase multiple chains? #13
Of course we do. We bring a handful of files into the field with us.
We do trail clearing. This involves cutting whole trees, old stumps and brush off, all this is done as low to the ground as possible. This is among the rocks and dirt, so we dull chains rather quickly. Limbing trees is not hard on our chains.
Do you file your chains? Usually the only thing that will hurt a chain is a rock or dirt and you'll have neither pruning limbs.
This is the best sharpener I've come across. Timberline Chainsaw Chain Sharpener | Timberline Filing Guides | Chain Filing Guides | www.baileysonline.com
Consistant results and easy to use and no need to remove the bar & chain. I also use Bailey's chain with good results, although in a chainsaw.
/ where to purchase multiple chains? #15
I've been running some loops of VXL on my little Dolmar. I couldn't quite tell if it's exactly the same as what you're getting, but I've been happy with the VXL I have. Let us know what you think of it.
/ where to purchase multiple chains? #16
I just started using VXL this week, for clearing brush. I'll see how long it lasts but so far it looks like it'll go as long between sharpenings as the Stihl chains I've been using.
My USFS experience included a couple seasons thinning pine trees using Homelite Super XLs (yea it was long ago) with bow bars. That's what fire crew did when not on a fire in Kaibab NF. Not as cool as being a sawyer on fires. Everyone I mention bow bar to gets a funny look on their face but these were set up with guards top and botton and a 'stinger' on the end so you could cut with the tip. I thought they were safer than regular bars and certainly more convenient for the work we were doing. I'd set a saw up like that now if I could find the right bar. Arly do they let you buy local now? We had to get whatever we could from GSA approved vendors.
Gee Eric, what year did you work for the NFS? I don't "work" for them here but do clear a trail on the Ottawa NF and to do that, you must be a certified sawyer. We do get items from the GSA catalog but chains I asked about were purchased locally for myself. To add to the complexity, I clear trails for several organizations and been doing that for well over 20 years. I also do that for my job. I've never seen a "bow saw bar" and think that looks quite interesting.
/ where to purchase multiple chains? #18
I was on the Kaibab in the mid 1980s, then did (non-chainsaw) work including tree climbing for R5 and vegetation studies and airphoto interpretation for a joint USFS/NPS project around Yellowstone before abandoning the USFS for unrelated work.
Here's a pic similar to what we used: http://i89.photobucket.com/albums/k217/xskier/Mobile Uploads/20140425_095606.jpg
I can't get it to embed for some reason.
With the cutting part out on the end the operator doesn't have to bend over as much, which is great when you're cutting hundreds of little trees a day. It's also safer- one time I tripped while backing up and ended up with a running saw in my lap. The guards kept the chain from touching my chaps. The stinger on the end keeps it from kicking back. You can get kick back if you approach the tree wrong but with the long guards you have to work at it. Once cutting it's secure enough that you can take a hand off the saw to push on the tree. Now that I'm fighting nasty brush with poison oak and stinging nettle I kind of miss nice clean monoculture ponderosa pine forests.
We finally got a new Oregon chain out and it rocked! To reiterate, we carry many chains with us and do file them in the field. But the type of work we do is quite hard on them. Will these Oregon chains hold up?
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
Unverferth Assist Wheels (A64127)
Unverferth Assist...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
2011 Blue Bird School Bus (A62613)
2011 Blue Bird...
208735 (A60430)
208735 (A60430)
