Branson Front Wheel Axle Failures
/ Branson Front Wheel Axle Failures #61
After a close look at the pics, the axle did not break. It was twisted off.
There are circular marks on the parts.
I have had my 3510 since 2005 when I had 2 acres, I now have 10 acres.
They are great tractors BUT I would not consider it for 125 acres unless it was for minor use with a larger industrial tractor to do the work!
I have picked up logs with my FEL and forks and had the tractor crab walk from so much weight but I babied it when I did.
Hello Stimw, thanks for the post. You are quite correct about the acreage, about 50 acres is in bush, about 75 acres is tillable. I bought the Branson for my garlic operation which is under 10 acres total at this point, also use it for bushhog work, cutting and raking operations and fence line and dead tree cleanups. For the garlic planting I use the cruse control with it set pretty much as slow as I can get it. It is slower than the creep functions on any of the other tractors that I have seen. Works great. For other work have two other tractors both with loaders. For my main field work I use a MF265. I also contract in work as needed. Interesting your observation about the axle twisting in its final failure. Lends support to the notion that the axle was pretty much fractured when it finally failed. The picture was taken within an hour of the failure. If you look at the center area of the hub side of the axle spindle I notice that the very center is a darker rustier colour than the outer areas. This indicates to me that that area (the very center) was probably failed much earlier than the rest of the assembly. If that is true I think the fault may have been there from manufacture which makes me suspect that this axle spindle assy is two piece in construction. It would be nice to have Branson Tractor/Kukje Machinery state that this is a two piece construction or a single piece. I have had some other pictures sent to me in confidence which I will not share but I can say the failures are in exactly the same place and look the same except that there is no evidence of a dark rusty area at the very center of the axle failure point. There is however the same bit of pin material protruding from the center of the fracture plane if you can think it as that. i am working on getting the manufacturer to the table. I know that is a long shot but if I do I will share any pertinent details that come to light and which can be shared.
/ Branson Front Wheel Axle Failures #63
Well,*I just read this entire post, and I would like to weigh in on a few things:
1. Expecting the manufacturer to spell out every scenario on how to operate seems a bit ridiculous. Way to many variables, environments, scenarios, uses, etc. If you are buying a tractor, it is your responsibility to learn how to*operate it, and how to do it safely. They provide you the basics,*you take it from there.
2. Its concerning that*a few people*seem confused on why you would need ballast. If*you need a quick lesson,*remove any 3pt implement from your tractor,*place the tractor in 2WD, then*scoop a full load of material. Well, you probably wont be able to, so shift back into 4WD, get your full load, then shift back to 2WD, and then try to back up, go forward, go up a small incline, etc. You will immediately see what role your front axle plays in moving*the tractor. Now pick up a*heavy implement and do all the above again and see the*difference. When I have my backhoe attached, which is*only about #1200 lbs, I typically don't need 4WD for any loader/forklift work at all. *
3.*Saying that people or dealers need to*dismantle tractors to try and see if any impending failures can be seen is also quite absurd. Until failure occurs, I don't see any sort of inspection (if its not blatantly failing) doing any good.*Do car dealers removes all wheel bearings to try and see if they think they could be*failing? Should they?*Of course not.
4. Again, little research will show that most all of these tractor manufacturers*are on*roughly the same playing field, designs are roughly the same, engineering roughly the same, capabilities roughly the same, expected usage is roughly the same.. All will have their share of failures, and as far*as front axles go, nobody is exempt. The early*Branson tractors were more prone than the newer ones, but as*Dave*said, a lot can be attributed to operator error. I would go as far to assume that the VAST majority are operator error.* It*should also be noted that over the years, they have tracked failures to some degree, because some parts have been upgraded that they deemed inadequate, such as tie rods for the early years. So they*are diligent at correcting their mistakes.
Just my thoughts.
/ Branson Front Wheel Axle Failures #64
In my opinion,, there is only one answer,,, the right machine, with a lot of axle.
If you are gonna do a lot of work,,, get a lot of machine.
I purchased this, with a loader,, it was 15 years old at the time,,, I have used it an additional 20 years.
It is only 60HP,, and has never been used with ballast, on purpose,
The loader gets LOTS of use.
Zero axle failures,, (it seldom needs 4WD),, It cost me $5,000, I paid the asking price.
Now THAT is one fine tractor...I would LOVE to find one of those....very rare id imagine..?
/ Branson Front Wheel Axle Failures #65
I do not know if it is rare,,, it came from Canada.
The P.O. moved it from Canada to Virginia.
He told me that by 1980, that almost no one was buying 2WD loader tractors in Canada.
So,, it might be common up north?? :eek:
/ Branson Front Wheel Axle Failures #67
I've seen a number of 2wd 584's in California, but no 4wd's. Yes it is on my 'list' too. If one shows up on CL I imagine you and I will be competing for it...
/ Branson Front Wheel Axle Failures #68
From what I have seen, most loaders lift the front end somewhat while digging down into the dirt. This movement actually takes pressure off the front axle. For level surface loaders working on concrete and asphalt, there is no need to dig below the surface, just scoop from the finished surface so there is a chance for more pressure and traction on the front end in this case. Barring abuse, the tire should be expendable, not the axle.
If someone feels a product is unsafe or a corporation is selling defective products they should first try and rectify it with the manufacturer and if not successful, report it to a government authority and let the government investigate it. Sometimes companies will not rectify a defect, if applicable, unless they are forced to correct it. Not to mention that when you report something that is unsafe or doesn't wear properly, other informed consumers may perform research prior to their purchase and use this information in making their decision.
CPSC SaferProducts.gov | Report an Unsafe Product
EDIT: I don't need 4wd on hard pavement. I am also not sure if the drive train has any internal clutch to alleviate torque when the wheels are not freely slipping on soil. I have seen this drive train torque cause transfer case failures in several older 4x4's- my rule of thumb is to use 4wd on slippery pavement or off road- when you need it. The rear transaxles on these tractors are probably more robust that the weak link is some other component.
/ Branson Front Wheel Axle Failures #69
If used as a normal loader, I agree that you should get tire spin before axle breakage. But you can force the tractor in some situations to have tremendous traction for the front tires, at the same time having almost no traction to the rear tires (as they are in the air or nearly so). If you then proceed to push and the tires can't spin and the item you are pushing does not move and the clutch does not slip and the motor does not stall....then what? Snap. It is under difficult circumstances that these operator induced breakages occur. MFWA is to be used for traction, but not as the sole motivating force when the front axle is under extreme load. Using it to push into a pile for loading is proper. Just considering the physics of what all is happening can keep a guy out of trouble.
And I agree with you on the rear axles being more robust. A rear axle shaft on a (any brand) compact 4x4 tractor are several times larger than the front axle shafts. Some front axles shafts are only an inch or so, and on that same tractor the rear axle might be 2". Cross sectional area of a 1" shaft is 0.785 sq in. A 2" shaft is 3.14 sq in. 4 times stronger, given that everything else is equal.
/ Branson Front Wheel Axle Failures #70
Ssoooo............. Don't use 4 wheel drive unless you are stuck. And, load the rear tires? B.
/ Branson Front Wheel Axle Failures #71
Bruce, I'd say use 4wd whenever needed. I wouldn't wait until stuck. Yet I don't drive around town all the time with my Jeep in 4wd. I put it in 4wd when needed. Even on forest roads and trails, 2wd until it gets rough or slick. Just use common sense.
/ Branson Front Wheel Axle Failures #72
It's a tractor. NOT a bulldozer or a $200K loader.
Some people get carried away and things break.
/ Branson Front Wheel Axle Failures #73
I twisted my drive shaft "off" once. I was loading wet sand in a sand pit and the road (sand path) out of the hole was at least 30 degrees. 1979 International cab over combination, 35 ft end dump, 25 tons of slush, 800 cu. in. 400 hp Big Cam Cummins.......it can be done with an abusive operator.
/ Branson Front Wheel Axle Failures #74
I twisted my drive shaft "off" once. I was loading wet sand in a sand pit and the road (sand path) out of the hole was at least 30 degrees. 25 tons of slush, .......it can be done with an abusive operator.
Lots of traction + Lots of torque = something's gotta "give"
/ Branson Front Wheel Axle Failures #75
Yesterday I had a second stub axle twist off 8 years from new . Been working with the log winch now for a couple weeks and just dropped off a stick of fire wood maybe a 200 lbs . backed up a few feet and it let go. Drove 4 hrs round trip to get the part and repaired to find out the seal is shot this time too. Last time 1.5 yeras ago was the left front and this time its the right front.
I did buy 2 as it will be needed.
/ Branson Front Wheel Axle Failures #76
I use 4wd almost all the time. When I take it out of 4wd, I start digging holes with the rear tire all to frequently. The only time I take it out of 4wd is when I am working in closed tight areas and turning very sharply. I find I can turn a lot sharper using the left and right brakes when not in 4wd.
/ Branson Front Wheel Axle Failures #77
Yesterday I hauled apart the left side again to check if the crack has started . It has not after 1 . 5 years use. My new maintenance plan is with every front axle oil change both side are coming apart to see if the crack has started. Not going to take all that long with tire removal , 9 bolts out then 2 more inside and the stub axle pulls out for inspection.
The parts place tells me it has something to do with how far the wheels can turn left and right This tractor when turned all the way the wheels are almost 90 deg to the back . They say there needs to be a limit bar install inside the power steering assist tube to set the distance for turning.
As for 4 wd Its almost always on as the tractor doesn't turn in 2 wd . Its only off when traveling on the asphalt .
/ Branson Front Wheel Axle Failures #78
Just a note to those who use their MFWD a lot to enhance turning. Because I have so much use for it I've taken to keeping the backhoe on the tractor almost continuously. All that weight behind the rear axle causes the tractor to be light in the front end. This often causes "snowplowing" where the front wheels are turned but the tractor continues going straight ahead.
A better alternative (IMO) to engaging the MFWD is to split the brakes (at the pedal) and brake the wheel (tractor brakes typically only act on the rear wheels) on the side that you want to turn. For example, if the tractor doesn't want to turn left, split the brake pedal and brake the left wheel. The tractor will pivot on the immobile left wheel and turn left with no problem.
/ Branson Front Wheel Axle Failures #79
My Branson (I'm the second owner) with only 100 hrs on it 5 years ago . Brakes didn't stop anything ever. Dont think they worked from day one. Cruise control didn't work as the switches for the brakes were always on. They are now disconnected so cruise works.
/ Branson Front Wheel Axle Failures #80
The brakes never worked but you disconnected them to allow the cruise control to work?
I hope your land is very flat.
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2005 Chevy 2500 Pickup Truck (A66408)
2005 Chevy 2500...
International S1900 (A63689)
International...
(4) Wheels and Tires for 4-Wheeler (A65579)
(4) Wheels and...
