My new Bro-Tech Ripper Tooth
/ My new Bro-Tech Ripper Tooth #1
check
Elite Member
Dorset (cottage country) and Toronto, Ontario, Can
2009 Kubota BX25
OK, so I got a chance to try out my Bro-Tek Ripper Tooth, digging a ditch for my water line. Worked great! Notice all the surface roots it ripped up, with nary a hesitation.
I also got the Bro-Tek QA so I can quickly switch back and forth with my 12" Kubota OEM bucket. The second last photo shows an optional attachment to the Ripper Tooth in case you want a wider ditch. I have it leaned up against the BH bucket for comparison.
Can't wait to try digging out a stump!
/ My new Bro-Tech Ripper Tooth #2
I've been singing the praises of the Bro-Tech ripper tooth on this forum for a long time. I've had one for several years, and I love it. It works great for busting through lateral roots on trees and shrubs.
We have thick, black, gummy clay soils here, and it just fills up a bucket and sticks to it. So I use the ripper tooth a lot more than a bucket.
I just used mine recently for digging up some chain link fence posts that were concreted in. Worked like a charm and didn't tear up the yard near as much as a bucket would.
/ My new Bro-Tech Ripper Tooth #3
What is the depth of the trench you are easily getting? I need to run a couple hundred feet of poly pipe for a few frost free hydrants around our property.
I was only digging down maybe 2 ft max, because I will still be draining this water line in the winter. (I just needed to get it off the surface so I could drive over that area with my tractor.)
As you know, the BX25 can dig down some 6 feet, but I wouldn't go that far with just the tooth unless it was hard clay. I would attach the bigger trencher piece if I was to go down even to 4 feet. Or use the 12" EOM bucket. BUT, my soil at that spot was fairly sandy with no rocks at all. If there had been rocks I would have had to use the 12" bucket.
/ My new Bro-Tech Ripper Tooth #5
Thanks James, I was just wondering how deep that ripper tooth would go. I was guessing it would bottom out when the BH attachment point hit the ground surface level due to it being wider than the ripper? Or does it go deeper? I only need to go 18 to 24in for my watering lines that I want to put in but the soil is full of lots of rocks up to 4in or sometimes bigger.
Skid steer Fork Bracket  (A62679)
Skid steer Fork...
Panorama Hayrake (A66408)
Panorama Hayrake...
2016 Chevrolet Silverado 3500 Flatbed Truck, VIN # 1GB4KYC8XGF238980 (A65563)
2016 Chevrolet...
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
