stuckmotor
Super Member
- Joined
- Sep 23, 2009
- Messages
- 7,652
- Location
- Lower Up State S.C.
- Tractor
- AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
You might need an attorney for this
I've never heard of PEX being that large. I've only seen it used for indoor water/heating systems (my home) replacing copper. You'd have to check to see if that size is available and suitable for in ground installation.
I know this is going to probably sound crazy, but what are the chances that a plumber can run 1.5 inch 200 psi roll pipe through the existing 2 inch line??? He would need to remove any sections of the pvc had have been repaired, but as long as the od of the 1.5 hdpe is less than the ID of the pvc it should work in theory..... any thoughts?
I say no way... too much friction over that distance. Maybe if you can get a string through via vacuum... then a stronger wire back the other way secure to pipe after smoothing the sharp edge on the poly. If there are any inside seams it will surely hang. Just my :2cents:My bet is , you won't get it inserted very far. If you are the type that has good luck, it will insert all the way. I'm never that lucky
:thumbsup: 100%For me Black Poly is the only thing - with brass fittings. I just replaced my 1200' run that was put in in 1973. The pipe was fine but the nylon fittings were cracking. We went with black poly with brass fittings. that is all they use around here.
Where I grew up in SD we ran water 1.5 miles in black poly pipe 6' deep Dad put it in in the mid 60's and it has never been touched and it has not had a problem. The rural water system they put in about 15 years ago out there was all done with black poly pipe knifed in.
If you do anything on your own the plumber will gladly just bow out. I am a fan of 180# black poly and was thinking about your situation and the fix you suggested. You won't get a roll of poly 1300 feet long and the 3 or 4 connections would not slide through a 2" pipe. It really is up to the builder to fix it right and sadly he may just fix the spot and call it a day, hoping that is all the leaks. Then another month later the warranty is off and you would be screwed big time. I ran black poly to 3 different houses and to barns with distances up to a couple hundred feet and in dirt rock crap soil. No problems in 30 years. In fact the only problem I had with any plumbing is in my current house with CPVC cracking inside the crawl space. If you are below the frost line and sandy soil I would not hesitate to use black poly. I would use a smaller pipe, maybe 1-1/4" and crank the incoming pressure up to 100# approx. and put another regulator at the house end and set to 50# or so. Saves on pipe material and a lot fewer joints, maybe 3 or 4 total. You need 4 full stainless steel clamps on each joint.
Thanks to you and your wife for your ongoing service to our Country.
I want to paint a different picture for you to look at: You hired a builder who built a house for your family, which came with a guarantee meant to protect you from exactly this type of nightmare. Your builder likely has liability insurance which is what he buys to keep him protected if something goes wrong on a job. He hires sub-contractors who may or more likely do not have insurance.
You need to exercise your rights to hold the builder and his subs to the standards set forth in the contract you have with him. If this entails suing him, his company, and his sub(s), then that is your course of remedy. You can worry about 'going nuclear', OR you can start the necessary process for solution to this problem.
Your water company looks to you to pay the bill. You look to your builder to pay the bill AND rectify the cause of the leak, PERMANENTLY.
All the discussion about cause, pipe type, glue being old or new etc. is just distractions from what you need to focus on. Not saying it's not useful, but it's not to the point that the builder needs to stand behind his work and correct the error, REGARDLESS of what it is/was, or who caused it.
Now, the question arises as to what the County you reside in REQUIRES for licenses, inspection(s), pipe type, burial depth, medium in which the pipe is buried, (sand surround), and whatever other specs they have for your type of water main service to your residence. If those requirements weren't met, inspections weren't done, or there aren't records filed with the State/County, as required, this is ammunition for your case with the builder's insurance company.
Always look for deep pockets, and sue until you are done and things are set right. Use your Jag access to get it done. This water bill will either get eaten by your builder's insurance or a settlement between them and the water co. You should not incur any costs related to this situation IF you do what is necessary to hold those responsible, responsible.
As stated, keep records of every call, email, text and whatever your wife can acquire from the builder, the County and State, etc.
Come back here to report progress, ask questions, etc.
Good luck. We're with you.:thumbsup:
The local media is definitely interested in the story. My wife got a text from the builder today - so I called him back. He was upset the he had received a BBB complaint. He is saying that the line will be replaced and that he is working with the utility company. He didn't say he was going to take responsibility for the bill. I told him that I didn't care what him and the utility company work out - I'm not going to get stuck with the bill. He seemed motivated today to get this BBB complaint removed. I guess we will see what he works out over the next few days.In NC, for building of any residential structure, permits need to be pulled. That's simple.
The not so simple part is who is going to cover the 11k and ensure that it doesn't happen again.
From a HVAC standpoint, manufacturers cover their butt per their warranties, as electrical usage is generally not covererd if one substains a increase in electricy with a new HVAC system. The contractors "eat it" per their mistake on a electric bill from my own experience "if" something is done wrong per wiring.
For the OP's case, I personally believe the water company is as much as fault as the builder. Since I'm not on a water line, I'm assuming water bills come monthly? I would respectfully argue that the water company should have software in place to track water useage and that if a residential dwelling shows a substantial increase in usage, it is the water companies responsibility to ask or find out why the usage is so high in comparison to other similar residential usage in the area.
This is where public opinion and media pressure could help resolve the situation rather than resort to the legal process.
Legal process is the very last resort. Have a feeling the insurance carrier may have a cluase about electrical or water usage rates just as HVAC manufacturers do, but don't know that for a fact. People also tend to clam up when legal proceedings are threatened because they won't want to hang themselves by doing anything.
Because I see the water company being as at much fault as the builder for letting the water bill go so high. I do see this as being a "news worthy" story that a paper or TV station would find interesting given the circumstances, and the one thing that no one wants (contractor, ultility company or the state of NC) is bad press. I have the feeling if a news station or paper started asking questions, things could get resolved quickly beind the scenes so the story doesn't make the light of day and the situation is resolved.
Ultimately, it seems the contractor is standing behind the warranty by trying to fix it, again, it comes down to that outstanding 11k bill and who is going to cover it. Then again, if it goes to court, perhaps the insurance company of the contractor will go after the municipal water company. Anyway you cut it, legal proceedings can be long, drawn out, and in the end, could still end up costing you let along the time and aggravation.
What's it take to make a couple of phone calls to the local paper or TV station? They need news to fill up spots, and again, I would consider a 11k water bill pretty newsworthy to the general public (who on water line wants a 11k bill for residential use?).
Nope - through some research this week it looks like the builder dropped in the line before the inspector ever came out. Also pretty sure that it wasn't installed by a licensed plumber. The same guy that did the grading/road install ditched the line and put in the pipe....
This ^^ may also put the county/town "on the hook" for some responsibility if the "inspector" let this slide.
