Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #901
I have a Kubota L4610HSTHC would your 72" Land Planer v.2.0 be the right size for my tractor
/ Everything Attachments #903
72" is fine if you want to stay about the same as your tractor width. Larger will be less maneuverable, but also just as well on the 4610.
Travis
/ Everything Attachments #905
/ Everything Attachments #906
Getting ready to order 3 items with a grapple coming not to far in the future. Any help would be great.
/ Everything Attachments #907
Just talk to me when you order and I'll take care of you as much as possible!!
Plan ahead. We're behind due to much higher than normal demand!
Travis
/ Everything Attachments #909
Travis what is the blade tip speed fpm on your 6ft EA rotary cutter I didn't see it on your website
I really do not have an accurate estimate/calculation.
I can say that I talked to a guy with a new 72" EA Cutter earlier today and he said it's cut had people thinking he used a finish mower!
Travis
/ Everything Attachments #910
Do you know the blade RPM or gear ratio between PTO input and spindle? Calculating angular velocity with that info should be pretty straightforward.
Rob
/ Everything Attachments #912
Rob
And distance from blade tip to center of spindle.
/ Everything Attachments #915
Not available via CAD?
/ Everything Attachments #916
OK, with 1:1.146 that means the blade holder is spinning at 619 RPM. However, when I went to look at the specs of the 72" mower things get a bit odd because the manual says the blade holder is 20.25" and the blades are 17.75". Not sure how that combo gets you to 72" width? Unless this is different than the skidsteer brush mower I've used in the past which had one big holder on a single spindle with 3 swinging blades attached. If this has multiple spindles then we'd have to know the spindle-to-blade-tip length as noted.
Rob
/ Everything Attachments #917
I sent a PM looking for a post hole auger
/ Everything Attachments #918
I am looking for a hydraulic hose diagram for a 1620 backhoe attachment
/ Everything Attachments #919
I just placed my order for the 55" Wicked Root Rake Grapple. Anxiously awaiting the arrival, about 5 weeks out. Can't wait to see what it will do to these gall berry bushes that are all over our property.
Status
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
1076 (A64280)
1076 (A64280)
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
Caterpillar 325/325L/325LN Excavator Service and Parts Manuals (A63117)
Caterpillar...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2021 John Deere S790 Combine (A63111)
2021 John Deere...
