Chisel plow
/ Chisel plow #1
logangrey
Western NY
LS 3032
Id like to make my own plow . just wondering can i use regular steel or does it need to be special grade material
/ Chisel plow #2
The frame itself is just regular steel. The chisel points are hardened. You can buy them by the piece maybe $10-20 each last time I bought some.
If you hit up some farm auctions you could probably buy an old chisel plow cheaper than you could build one. I bought a 19' chisel plow and cut it in half. Made an 11' unit I use and an 8' unit I sold for what I paid for the whole thing.
There is a ton of farm equipment out there that is too small for modern commercial farmers to use and yet too big for the compact tractor owner. If you are handy with the welder it can be bought cheap and adapted.
/ Chisel plow #4
make sure you enter your zip code and search by miles....
tractorhouse.com
craiglist.com
lots of stuff out there.
normally there is larger auctions, a couple times a year, 1 spring, 1 fall. (depends on area), were there are huge lots of tractors and implements. co-assignment acutions
ebay.com you may find actual points, but not entire implement cheaply.
/ Chisel plow #5
The frame itself is just regular steel. The chisel points are hardened. You can buy them by the piece maybe $10-20 each last time I bought some. If you hit up some farm auctions you could probably buy an old chisel plow cheaper than you could build one. I bought a 19' chisel plow and cut it in half. Made an 11' unit I use and an 8' unit I sold for what I paid for the whole thing. There is a ton of farm equipment out there that is too small for modern commercial farmers to use and yet too big for the compact tractor owner. If you are handy with the welder it can be bought cheap and adapted.
This has been a big thing for guys around here over the last few years, it's really drove the prices up on that size equipment. They buy it, cut it up into compact , " Food Plot " sizes and price it for tree times what it's worth.
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2006 GMC C5500 4X2 BUCKET TRUCK (A59909)
2006 GMC C5500 4X2...
2014 Chevrolet Silverado 3500 Crew Cab Utility Flatbed Truck (A60352)
2014 Chevrolet...
New/Unused Wolverine Mini Skid Steer 3 in 1 Bucket (A61166)
New/Unused...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A61567)
2006 John Deere...
