Engine question?
/ Engine question? #1
tarheel96
Member
Tn
Yanmar
I just recently bought a tractor that was in the process of replacing a blown head gasket so the head was removed from the block. The tractor was covered and stored with the head removed for quite some time. My question to all you is what should I do to flush any dirt or junk that "could" have got done in the motor? Should I pull the motor apart and clean and reassemble to be on the safe side.What would you guys and gals do? Thanks
/ Engine question? #2
This is like someone asking a the question, "Why won't my tractor start?" without any factual info. The answer you get will be more conjecture that based on solid facts. Having said that, I'll venture an answer.
It depends on what the top of the block deck and the bottom of the cylinder head look like. f they are just dusty, wipe them off with mineral spirits check them for flatness, make sure the valves are good,and if good ,wipe out the bores and put it together. If they have light rust, plug the bores with rags, use a fine emery cloth and polish them, clean off any "rust dust", check for flatness and if good, reassemble. You might want to take the head in and get it checked out.
If you dismantle the whole engine you'll have to check all the bearing clearances, journals, etc and you're liable to get into some real $'s. for a little bit of normal wear and tear.Your dollars, your choice.
/ Engine question?
Thanks for the reply Jerry. My question is not how to clean the head or block of "normal wear and tear" as you put..but to clean the inside of a motor of possible dirt or debris. If I had a bore camera I would know for a fact but I dont. Could just draining the oil get everything out maybe? Thanks
/ Engine question? #4
I'd get the cylinder bores clean - no crud or any rust more than maybe a very light patina. Wipe all that out the best you can. Then take a shop vac with a crevice tool to the bores, especially the slight gap between the pistons and bores. Then blast this same area with compressed air. Finally, coat the bores with a light, solvent-type machine oil like Marvel Mystery oil and let it sit for at least a few minutes. Before you do the next step, be CERTAIN of how any timing marks on the crankshaft pulley and injection pump are aligned!!! And then turn the engine over gently by hand (crankshaft bolt) at least a few full turns. If there's any residual crap in the bores, the rings will push it up to the top of the bore and the oil will hold it there for you wipe out.
Of course, drain the crankcase into a suitable container so that you can inspect for any evidence that water/fuel/trash somehow got past the rings and into the oil/crankcase. If the head gasket went "badly" there may well be coolant that got past the rings and into the crankcase/oil. And there's a good chance that it overheated enough to warp the head, requiring resurfacing. Can the previous owner tell you? Or tell you if there were any other symptoms of crank/bearing problems like low oil pressure? If not, I'd be inclined to leave the bottom end alone.
/ Engine question?
This helps a lot JRobyn. From what the previous owner said was he would get some overheating after running the tractor with a finishing mower after some time of use. It sounded like after he got it good and hot and under a load the tractor would get to hot. He told me he wasnt 100% sure it was the headgasket... He did take the head to a machine shop but didn't get anything done due to the shop not being able to get the injectors out. The machine shop said that they need a special tool to get them out so they could work on the head. That was all he did with the head far as I know. He told me everthing else was running like a top.. I will try what you are talking about with the vac and air compressor in the pistons area. I will also keep my eyes peeled when draining the oil. Got my fingers crossed! Thanks
/ Engine question?
Here is a couple of pics of the top of the block. I am still learning this site so the pics might be wrong format or something.
The Tractor is a YM1900 Yanmar with a 2TR17 engine in it.
Engine Detail:
Yanmar 2TR17
diesel
2-cylinder
liquid-cooled
62.31 ci [1.0 L]
Bore/Stroke: 3.346x3.543 inches [85 x 90 mm]
Power: 20.6 hp [15.4 kW]
Rated RPM: 2400
Idle RPM: 800-2400
Starter volts: 12
/ Engine question? #7
In addition to the good advice you got for cleaning the bores I'd check to make sure nothing fell down the pushrod tunnels or into the water jacket. Any dirt in the pushrod tunnels is going to end up in the oil. Once you get it running consider an oil change soon after just in case there's crud in it.
/ Engine question? #8
Another thing to consider since you say the PO noted overheating while mowing. Check the radiator air side for clogging with dirt and chaff. That's a frequent cause for overheating.
/ Engine question? #9
^^Yes. The symptoms actually sound more like poor cooling air or water (or both) flow. This could be due to radiator/thermostat/water pump problems and not the head gasket. Or even just a loose fan/water pump belt! Since it is disassembled to this degree now, would probably be wise to pull out the radiator for a thorough inside and outside cleaning. If you can still find a "radiator shop" in your area! The thermostat may have been hanging partly closed. A replacement thermostat is cheap and good insurance. There's a chance that the water pump impeller is degraded just due to age or poor cooling system maintenance. This can usually be verified just by pulling the water pump and only the cost of a new gasket is involved if it is ok.
So the previous overheating MAY have not been severe enough to warp the head. I have no idea how prone 2-cyl Yanmar heads are to warpage. Some heads are really tough, others not so much. But since it's off anyway, no good reason NOT to have it checked and resurfaced if necessary.
If a machine shop doesn't have tooling to remove diesel injectors, you definitely DON'T want to use that machine shop!
/ Engine question?
Good thinking Jerry I will have some time this weekend to do a little work on the trator I hope. If I do I will take more pics so you guys can see the condition of the other parts. Thanks for your help!
/ Engine question?
I will pull the radiator and water pump and see how things look. And also look at the air filter and hoses to make sure we are getting all the air we need too. I will do some digging and see if there is a good shop to take a look at the head and radiator if possible. At some point I have to put a battery in the tractor to do some wiring/electrical trouble shooting to make sure everything is working right. Thanks for all your help!
/ Engine question? #13
Another thought. Do you have the correct pressure cap? Is it working properly? If the pressure cap has a lower pressure rating than spec or is damaged, the coolant will boil at a lower temperature and cause an overheating condition.
/ Engine question?
I didn't have much time to work on the tractor this weekend but here is some pics of some of the parts. The radiator fins is packed with dirt and grass from cutting grass it looks like. The air filter is packed all the way around the filter as well. I would say that this tractor was having some problems with air flow..it is hard to cool properly with all those fins packed tight too..
/ Engine question?
I am not sure on the pressure cap.. I have never tried to check one before. Does anyone know a good way to check the cap? Thanks for your help
/ Engine question? #17
Repair shops have testers and so does NAPA stores, O'Reily's, etc. Alternately, you can just buy a new cap. Just make sure it's the right pressure rating.
It looks like you found the cause however. Clogged air side of the radiator. What's the coolant side look like. If the PO used hard water, they can lime up an clog. Clogged air filter is also a culprit.
Probably never needed to come apart!
/ Engine question? #18
Fancy coolant overflow bottle you have there!
In my experience with broken / damaged tractors and motorcycles, a person is usually money ahead to buy a working machine. Even when I buy something that seems great, there is usually something wrong with it that requires attention. When I buy something I know is broken, there is usually a LOT wrong with it that I didn't foresee.
I wish you luck in your endeavor. Please document the process. I hope you will prove my bias is incorrect.
/ Engine question? #19
WOW- Can't believe the PO didn't clean or replace the rad before ripping into the engine...
That rad looks badly plugged and almost like Mud in between some of the cooling fins. Can't see how it could do a decent job of cooling the engine.
( If- it were mine) I would check the head and block for straight, check the oil that is in the oil pan and if not milky do as was posted above with the cylinder bores to make sure no crap is lodged above the piston rings .
If- the head/ block passes the straight test,
Take the head and fill the intake exhaust ports with a bit of diesel and wait about 2 minutes -if diesel is not drooling out between valve and head seats... buy a head gasket reassemble the engine. (after cleaning the head /block surfaces) Making sure to follow torque down sequence and torque specs.
clean as best you can the radiator flush some water thru it and re install, use new oil and filter and see if she will run.
If- It will run without billowing smoke , excessive Knocking , and no bubbles running thru the coolant/water in the radiator either have a rad shop go thru it or if not to pricey replace it and the thermostat.
This is just how I would approach it , but am CHEAP by nature, this way you are only out the price of a head gasket oil and filter and some RTV sealant and will know pretty quick whether the engine is basically sound or not. If the engine oil in the pan is Milky, I would not reassemble the engine as is.
/ Engine question? #20
Flush out your oil passages with diesel fuel, uses clean water in the coolant passages and call it done. Change the oil filter after about 10 hr x2 and run it.
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2016 International WorkStar 7500 (A64194)
2016 International...
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
