Backhoe Can you do some ditching side on to the ditch
/ Can you do some ditching side on to the ditch #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
In the process of buying a bh92 for my Kubota. When ditching can you position the tractor parallel to the ditch and dig off to the side or will it flip the tractor.
/ Can you do some ditching side on to the ditch #2
With the outriggers down your fine. If you want a finely sculpted ditch, you'll need to reposition every bucket width unless you have a fancy swivel bucket.
thanks. Even if you are position at 90 degrees you have to reposition as well would you not?
/ Can you do some ditching side on to the ditch #4
Yes although easier to reposition if you are parallel. You can raise the stabilizers a bit then use the hoe to scoot the tractor along a foot or two. Without getting off the seat.
/ Can you do some ditching side on to the ditch #6
Yes depending on how fussy you are. I used to try to be about at a 45* for less repositioning. Excavators are wonderful! :D
thanks
/ Can you do some ditching side on to the ditch #8
How wide is the ditch? Could you just straddle it?
Doug
/ Can you do some ditching side on to the ditch #9
Put the loader bucket down also . Much more stable .
/ Can you do some ditching side on to the ditch #10
I had grand backhoe ideas. Purchased A BH92 with a hydraulic thumb.
Having used it a lot, I find it lacking and slow. Trenching is best done with a helper. You dig, then have the helper move the machine forward.
I find it will dig stumps out...but takes a long time.
Mine is on an L5740. I continue to be surprised by the low level of power of my BH92.
Looking back, I wish I had not purchased it. That $11,832.00 would have been many days of rental of a mini-ex. Even better, you can probably find a good man with a track hoe that will work for $800/day.
I know that is not what you asked but I thought I'd offer my experience.
Edited to add: As long as I've had the stabilizer arms and bucket down, I've never had the BH92 even threaten to tip the tractor. I've dug most angles with mine.
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Case SV280B (A60462)
14C SCRAPER (A58214)
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
