Backhoe Can you do some ditching side on to the ditch
   / Can you do some ditching side on to the ditch #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
In the process of buying a bh92 for my Kubota. When ditching can you position the tractor parallel to the ditch and dig off to the side or will it flip the tractor.
   / Can you do some ditching side on to the ditch #2
With the outriggers down your fine. If you want a finely sculpted ditch, you'll need to reposition every bucket width unless you have a fancy swivel bucket.
thanks. Even if you are position at 90 degrees you have to reposition as well would you not?
   / Can you do some ditching side on to the ditch #4
Yes although easier to reposition if you are parallel. You can raise the stabilizers a bit then use the hoe to scoot the tractor along a foot or two. Without getting off the seat.
   / Can you do some ditching side on to the ditch #6
Yes depending on how fussy you are. I used to try to be about at a 45* for less repositioning. Excavators are wonderful! :D
thanks
   / Can you do some ditching side on to the ditch #8
How wide is the ditch? Could you just straddle it?
Doug
   / Can you do some ditching side on to the ditch #9
Put the loader bucket down also . Much more stable .
   / Can you do some ditching side on to the ditch #10
I had grand backhoe ideas. Purchased A BH92 with a hydraulic thumb.
Having used it a lot, I find it lacking and slow. Trenching is best done with a helper. You dig, then have the helper move the machine forward.
I find it will dig stumps out...but takes a long time.
Mine is on an L5740. I continue to be surprised by the low level of power of my BH92.
Looking back, I wish I had not purchased it. That $11,832.00 would have been many days of rental of a mini-ex. Even better, you can probably find a good man with a track hoe that will work for $800/day.
I know that is not what you asked but I thought I'd offer my experience.
Edited to add: As long as I've had the stabilizer arms and bucket down, I've never had the BH92 even threaten to tip the tractor. I've dug most angles with mine.
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
kohler generator (A56857)
kohler generator...
Husqvarna 42in Riding Mower (A56859)
Husqvarna 42in...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
