Chicken door Thoughts
/ Chicken door Thoughts #1
smokinmad
fairmount, il.
ford 1210, yanmar 276D, I.H. Cub Lowboy, Ford 2-N
Have seen plans for Automatic door openers using a retracting car radio antennae. I'm thinking a Coon or Opossum could pry under the door and bend that antennae
My thot is using a 12v electric window track.
What I need is someone GOOD with Electronics/Electricals......we know the window motor reverses, so HOW would i set it up so that at 6 am the door opens and then reverses and closes at 8 pm?
I have 120 volt in the house, so a 12v battery with a trickle charger would work for the motor. BUT how would I set up a TIMER on the 12v motor to know when to reverse to open and close...
And By The Way....I use my TRACTOR to clean out the Chicken House......lol....
This be a good one for you BOGGEN.....I know you'd do everything but build it....but wait, you Do live in Ill Noise...lol...I'm just east of Champaign....
Thanks for your thoughts
Smokin'
/ Chicken door Thoughts #2
You would be better served to put an E-fence around your pen,use a dusk/dawn timer.Works fine for my purposes.
/ Chicken door Thoughts #3
They make automatic doors with a light sensor, there $300 and a few are gear driven.
I just leave my coop open 24/7, thanks to live traps, I don't have a varmint issue
/ Chicken door Thoughts #5
You can probably rig something from a window motor, but if you want dead simple/move on to something else, just buy one of these:
Amazon.com: Add-A-Motor Chicken Coop Automatic Motor (D2): Camera & Photo
Comes with built in stops, field adjustable, and a 'wall wart' to change your 120v to the 12v the motor uses. Add a timer and build your door. I've never had a critter raise the plywood doors I use on my two coops, so I think that isn't an issue.
/ Chicken door Thoughts #6
i bought two motor like that 8 years ago and they still work, put on a 110 digital timer i bought at lowes, i built my own dore with a piece of plexy glass witch slides up and down in a grove then i put a small piece of wood in front of bottom of dore so coon cont pry open dore.
Yea...I'm thinkin that might keep the Grandkids out of the chicken yard also......I like.....
Buying one Would be easier....but no way they should cost that much....Demand for Product....
Thanks Guys...
Smokin'
/ Chicken door Thoughts #8
Thanks Guys...
Smokin'
Dusk/Dawn timer shuts it off during the day,safe for pets/kids/dumb adults. I have about an acre of pheasant pens and used to trap,raccoons,possum ,skunks ect.,the fence is a lot more humane.Use poly weave wire and 6" stand-offs;you should have less than $100 in the whole set-up.Now your only problem will be hawks and owls.
/ Chicken door Thoughts #9
Put RFID tags on the chickens to permit entry and if movement is detected without a tag, something nasty.
/ Chicken door Thoughts #10
Interesting. I never thought of something like that. I have two coops. One is inside my fenced area for my horses and goats. Over time, we've decided just to leave the door open in there. Most of the chickens in that area sleep inside the coop, but maybe a dozen of them sleep inside the goat area. Owls are our only concern and we've lost a couple over the last year to them. But no coyotes or racoons get past the hot wire. Before the hot wire, we lost dozens of birds!!!
Our other pen is behind the garage and it takes less then a minute to walk out and shut the door at night when they are all asleep. Same thing with opening it in the morning when we get up.
/ Chicken door Thoughts #11
Let me just chime in here that with electric running, I don't bother to close my coop doors. I got a charger rated for predators and weeds, and ran my wire low (probably too low) at about 4" above the ground ("nose height").
The only predators that have actually taken ours are red tailed hawks (injured one, broke the neck on another, plus a few scares when they have been out) so we hung deer netting over the pen, which has worked so far.
/ Chicken door Thoughts #13
Check out YouTube. A lot of farmer / Engineers!
/ Chicken door Thoughts #14
I prototyped an automated chicken coop door & pile of sensors (distance to measure food & water height, temp & humidity, etc). Then I decided I didn't have the coding skills to properly secure an Internet connected device. I ended up buying the wife a CoopBoss to integrate with my existing SmartThings deployment. CoopBoss
I'd planned on a linear actuator even before the CoopBoss. They are $60-70 for the cheap ones. The cheap ones are rated to 100-200lbs, plenty to keep critters out. They are slow, but where is the rush in this application. Gives the chickens time to get out of the way anyway. I set mine up as a reverse guillotine after getting annoyed figuring out geometry for a drawbridge style.
Need to go photograph my setup. Apparently I don't have any.
WOW....they sure are proud of the COOPBOSS...$540. Your right tho.....it is a nice unit...depending on how many chickens you raise, it wouldn't take to many "Kills" to pay for it tho. a young laying hen around here sells for $10.
/ Chicken door Thoughts #16
Stick with the radio antenna motor, but mount your door to a pair of drawer slides on top and bottom and let the door slide open and closed sideways. A good set of drawer slides will hold up to any varmint pushing on it and not cause much resistance on the antenna motor...
Another solution is to put your chicken door up off the ground with a small chicken ladder up to it on the inside and outside. Most varmints are not going to walk up a plank 2' off the ground to push on the door (though a few will curiously climb it and check it out).
Additionally, you can leave the ramp on the outside loose so anything standing on it pushing will knock it down. That won't stop your chickens from exiting the following morning.
/ Chicken door Thoughts #17
This is what I used on my wifes two coops. They are actually drapery motors. I find that using a counterweight helps in opening and closing. 8 years plus and still no problems. They are on standard programmable timers.
/ Chicken door Thoughts #19
Just remember to wear a tag yourself when you go out to check on them. :D
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
FORD F-250 (INOPERABLE) (A60736)
FORD F-250...
2006 HONDA RANCHER ATV (A62130)
2006 HONDA RANCHER...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
