Ballast 2x2x2 concrete weight box
/ 2x2x2 concrete weight box #12
I've always been told a good ballast weight for 3pt is 2/3rd of what the 3pt can lift. Your 3pt is rated at 1985lbs at 24" (the ends of the links). 2/3rd of that would be a bit over 1322lbs. I think your box will be fine.
/ 2x2x2 concrete weight box #13
Yep, thats a good rule of thumb. As it whatever the loader is rated to lift @ the cutting edge (500mm forward
My L3400 was rated at 860# at the pins. The 3PH was 1500...so 2/3 of that would be 1000#. Guess thats why my 1000# barrel a felt good. Yet 700# was on the edge of not enough.
My MX can lift 2300# @ 24" on the 3PH. The loader is good for 1800#. So 2/3 rule says 1533. The 1000# barrel, not enough. My 1600# bushhog (that has a load center ~30" back, so is more "effective" than weight in close) is perfect. IF I were going to build a compact weight for it, and keep the load in close, I'd be shooting for 1600-1700#
/ 2x2x2 concrete weight box #14
Jeff I have a 1/2 barrel full that weighs in at around 550lbs and that seems just about right for my 35hp kioti I also have Rim guard loaded rear tires.
/ 2x2x2 concrete weight box #15
I am currently building a ballast box, it should come in about 1500 pounds. I hope it is heavy enough.
I think you'll be just fine.
Well thanks for all the replies. I guess I should not expect any as I rarely get involved in many threads but you must know that I do appreciate all your input.
I found the owners manual and it says it can lift 2645# at the end of the arms and 1985# 24" inches back from the pin. I have been thinking for the last couple years that if I mess up when lifting logs I could damage the front end.
You see the only time when I will be using the box is when I saw up my firewood. I have a homemade jaw / clamp on the front bucket and I use it for many things. Mainly though for moving tree length hardwood or softwood wood saw logs. With the firewood I lift the entire tree up to a comfortable height and saw into 16" firewood then when I get close to the bucket I drop the log and re-set and lift it again and saw some more. This way I save my back and all my firewood that has to be split falls to the ground in the same place. Then I move In the splitter , split the pile load the trailer and haul it in with my Ranger. But when I lift a tree length Beach or Yellow Birch 50' long,...and 20" on the stump,... that is very heavy on the front end so I do not want to do that anymore without some rear weight.
The bottom of my box is a 2' x 2' galvanized steel plate 5/16 thick. Then I have 3-2.5 inch diameter pieces of galvanized pipe welded at an angle to the plate in the bottom w/ drain holes that are long enough to extend about an inch above the finished box. I will use these to carry a iron rake in one pipe a spade in another and a crow bar in the last pipe.
I have maybe 30# of misc steel in the box welded to different places to provide support and strength to the concrete. I will also be using a real category 1 draw bar as the lower attachment point for the lower arms and I fabbed up some channel iron for a top link connection. The box will extend 12" beyond the lift arm pins. So whatever I said it weighed in the first post it will weigh,..I can probably add 35 to 50 pounds to it I would guess in the steel inside the box. I think I will leave it as is and pour it full in the future. Jeff
/ 2x2x2 concrete weight box #17
Just how exact are your measurements also?
23" x 23" x 23" is 7 cu ft... 1015#
24" square is 1260#
25" square is 1405#.
So how exact is it when you said a 2' square box? Because as you can see, a little makes a big difference.
/ 2x2x2 concrete weight box #18
24" square is 1260#
Valid argument that a relatively small size difference can make a big weight difference, but might want to check the math.
I'll assume you meant cube and not square. Example: "24" square is 1260#"
Using a density of 145 lbs/cuft
23 x 23 x 23 = 1021 lbs
24 x 24 x 24 = 1160 lbs
25 x 25 x 25 = 1311 lbs
It is somewhat surprising that 1" difference per side can be a result in cubic foot difference in these sizes.
23" cube = 7.041 cubic feet
24" cube = 8.000 cubic feet
25" cube = 9.042 cubic feet
/ 2x2x2 concrete weight box #19
My dealer agrees with this formula for tractors with unloaded rear tires. He recommends 1/2 the loader capacity with filled tires. Although the geometry is slightly different than 3pt ballast, the Rim Guard in the R4 tires on my MX5800 adds almost 1000# of rear weight.
/ 2x2x2 concrete weight box #20
I have 1450# of rimguard in the rear tires and a 1000# rear blade on the 3-point. Its always been enough for any heavy lifting with either my grapple or bucket.
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2016 Yanmar Vio45 (A60462)
2016 Yanmar Vio45...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
