Ballast 2x2x2 concrete weight box
   / 2x2x2 concrete weight box #12
I've always been told a good ballast weight for 3pt is 2/3rd of what the 3pt can lift. Your 3pt is rated at 1985lbs at 24" (the ends of the links). 2/3rd of that would be a bit over 1322lbs. I think your box will be fine.
   / 2x2x2 concrete weight box #13
Yep, thats a good rule of thumb. As it whatever the loader is rated to lift @ the cutting edge (500mm forward
My L3400 was rated at 860# at the pins. The 3PH was 1500...so 2/3 of that would be 1000#. Guess thats why my 1000# barrel a felt good. Yet 700# was on the edge of not enough.
My MX can lift 2300# @ 24" on the 3PH. The loader is good for 1800#. So 2/3 rule says 1533. The 1000# barrel, not enough. My 1600# bushhog (that has a load center ~30" back, so is more "effective" than weight in close) is perfect. IF I were going to build a compact weight for it, and keep the load in close, I'd be shooting for 1600-1700#
   / 2x2x2 concrete weight box #14
Jeff I have a 1/2 barrel full that weighs in at around 550lbs and that seems just about right for my 35hp kioti I also have Rim guard loaded rear tires.
   / 2x2x2 concrete weight box #15
I am currently building a ballast box, it should come in about 1500 pounds. I hope it is heavy enough.
I think you'll be just fine.
Well thanks for all the replies. I guess I should not expect any as I rarely get involved in many threads but you must know that I do appreciate all your input.
I found the owners manual and it says it can lift 2645# at the end of the arms and 1985# 24" inches back from the pin. I have been thinking for the last couple years that if I mess up when lifting logs I could damage the front end.
You see the only time when I will be using the box is when I saw up my firewood. I have a homemade jaw / clamp on the front bucket and I use it for many things. Mainly though for moving tree length hardwood or softwood wood saw logs. With the firewood I lift the entire tree up to a comfortable height and saw into 16" firewood then when I get close to the bucket I drop the log and re-set and lift it again and saw some more. This way I save my back and all my firewood that has to be split falls to the ground in the same place. Then I move In the splitter , split the pile load the trailer and haul it in with my Ranger. But when I lift a tree length Beach or Yellow Birch 50' long,...and 20" on the stump,... that is very heavy on the front end so I do not want to do that anymore without some rear weight.
The bottom of my box is a 2' x 2' galvanized steel plate 5/16 thick. Then I have 3-2.5 inch diameter pieces of galvanized pipe welded at an angle to the plate in the bottom w/ drain holes that are long enough to extend about an inch above the finished box. I will use these to carry a iron rake in one pipe a spade in another and a crow bar in the last pipe.
I have maybe 30# of misc steel in the box welded to different places to provide support and strength to the concrete. I will also be using a real category 1 draw bar as the lower attachment point for the lower arms and I fabbed up some channel iron for a top link connection. The box will extend 12" beyond the lift arm pins. So whatever I said it weighed in the first post it will weigh,..I can probably add 35 to 50 pounds to it I would guess in the steel inside the box. I think I will leave it as is and pour it full in the future. Jeff
   / 2x2x2 concrete weight box #17
Just how exact are your measurements also?
23" x 23" x 23" is 7 cu ft... 1015#
24" square is 1260#
25" square is 1405#.
So how exact is it when you said a 2' square box? Because as you can see, a little makes a big difference.
   / 2x2x2 concrete weight box #18
24" square is 1260#
Valid argument that a relatively small size difference can make a big weight difference, but might want to check the math.
I'll assume you meant cube and not square. Example: "24" square is 1260#"
Using a density of 145 lbs/cuft
23 x 23 x 23 = 1021 lbs
24 x 24 x 24 = 1160 lbs
25 x 25 x 25 = 1311 lbs
It is somewhat surprising that 1" difference per side can be a result in cubic foot difference in these sizes.
23" cube = 7.041 cubic feet
24" cube = 8.000 cubic feet
25" cube = 9.042 cubic feet
   / 2x2x2 concrete weight box #19
My dealer agrees with this formula for tractors with unloaded rear tires. He recommends 1/2 the loader capacity with filled tires. Although the geometry is slightly different than 3pt ballast, the Rim Guard in the R4 tires on my MX5800 adds almost 1000# of rear weight.
   / 2x2x2 concrete weight box #20
I have 1450# of rimguard in the rear tires and a 1000# rear blade on the 3-point. Its always been enough for any heavy lifting with either my grapple or bucket.
2009 Dodge Ram 3500 Flat bed (A55973)
2009 Dodge Ram...
2 Cubic Yard Dumpster (A55851)
2 Cubic Yard...
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
2006 Caterpillar 305C CR (A53317)
2006 Caterpillar...
J BAR 6' BOOM POLE (A57192)
J BAR 6' BOOM POLE...
BOMAG BW75AD WALK BEHIND SMOOTH DBL DRUM ROLLER (A52707)
BOMAG BW75AD WALK...
