SCUT FEL lifting force
/ SCUT FEL lifting force #1
Alesandro
Boise
Misubishi MT 372 D
Hey guys, just a quick question. For you guys with a SCUT and FEL, how much do you think you can lift? I'm estimating I should be able to lift 5-600#'s once I get my hydraulic issue fixed on my Mitsubishi MT 372 D. My FEL is 40" wide and I'm hoping I can lift a bucket full of dirt, safely of course, does that sound about right?
Thanks for the help.
/ SCUT FEL lifting force #2
What make and model loader does it have on it?
/ SCUT FEL lifting force #3
Do you have ample Three Point Hitch counterbalance to the potential FEL load?
I am not sure what model it is. It says Quick- On on one side then 72 on the other but I can't find anything online for it.
So I don't currently have an actual ballast but I use a 72" blade or a 40" tiller.
Does anyone have a 38" wide bucket or around that, if so how much approximately can you lift? Right now I have hydraulic issues and I'm trying to figure once I get it figured out what u should be able to do.
Thanks for the help
/ SCUT FEL lifting force #6
What it will lift depends on the diameter of the cylinders and the pressure on them.
The limiting factor is the load rating of the front axle.
My Kwik-Way loader bucket is 42" wide, TORO front axle rating is 1800 pounds.
No problem lifting dry dirt:
640 ponds of concrete mix on the brush fork:
xfaxman;
Wow, I really need to figure out my hydraulic issue because I can't come close to that! I how do I find out what the spec on my front axle is? I've looked on-line for specs but that is one that doesn't pop up. It's a 4x4 so the housing is more substantial than just a spindle.
/ SCUT FEL lifting force #8
I don't know. The TORO uses a Spicer axle, the load rating was listed in the service manual or some other brochures that I have.
After looking at the axle it looks pretty beefy, I am pretty sure it wouldn't have a problem lift a bucket full of dirt or a shy of a bucket full or rocks. If I need to lift something flat like a pallet I would the 3point hitch.
I am pretty sure I have the bucket lift issue figured out so now I just need to fix it and start using the bucket more. Thanks for the help.
/ SCUT FEL lifting force #10
XFAXMAN: I enjoy your pictures of that thing, even if looking makes me temporarily cross-eyed. Reminds me tractors are a big world and to keep an open mind.
/ SCUT FEL lifting force #11
The front axle should be rated to handle whatever the loader is able to lift.
/ SCUT FEL lifting force #12
Thanks.
It has worked out better than I expected. Put it together in 2005. Here is a brush pile from June 2006, piled a little at a time, with the 2' long forks.
And the fireplace rake on the forks.
Holy smokes people, does this thing move some dirt now! Before I would only be able to sink my FEL in a couple inches then I wouldn't be able to lift my bucket. So I would only skim the top as best as I could until I hopefully got enough dirt worth while to move. And if I did get enough dirt worth while to move I wouldn't be able to lift it.
I still have to skim since I don't have a big tractor but I can skim deeper and lift my bucket when needed and get a bucket full of dirt. It's a lot easier to manipulate the bucket in the dirt when needed to get more dirt. I can lift the bucket full of dirt over the dirt pile now as well.
Thanks for all your help on the issue being "bypass"! I never knew what it was and I never would have suspected it either since my bucket lift pistons didn't leak.
You guys rock, I hope I can contribute to others as well.
/ SCUT FEL lifting force #14
My neighbor built his own loader that he put on an Old Bolens yard tractor...He has NO problems moving rock or what ever, it's a lil' working machine. It looks a lot like your machine....You will learn real fast what you Can and Can Not do, with it.
Smokin'
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
Unverferth Assist Wheels (A64127)
Unverferth Assist...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
