SCUT FEL lifting force
   / SCUT FEL lifting force #1
Alesandro
Boise
Misubishi MT 372 D
Hey guys, just a quick question. For you guys with a SCUT and FEL, how much do you think you can lift? I'm estimating I should be able to lift 5-600#'s once I get my hydraulic issue fixed on my Mitsubishi MT 372 D. My FEL is 40" wide and I'm hoping I can lift a bucket full of dirt, safely of course, does that sound about right?
Thanks for the help.
   / SCUT FEL lifting force #2
What make and model loader does it have on it?
   / SCUT FEL lifting force #3
Do you have ample Three Point Hitch counterbalance to the potential FEL load?
I am not sure what model it is. It says Quick- On on one side then 72 on the other but I can't find anything online for it.
So I don't currently have an actual ballast but I use a 72" blade or a 40" tiller.
Does anyone have a 38" wide bucket or around that, if so how much approximately can you lift? Right now I have hydraulic issues and I'm trying to figure once I get it figured out what u should be able to do.
Thanks for the help
   / SCUT FEL lifting force #6
What it will lift depends on the diameter of the cylinders and the pressure on them.
The limiting factor is the load rating of the front axle.
My Kwik-Way loader bucket is 42" wide, TORO front axle rating is 1800 pounds.
No problem lifting dry dirt:
640 ponds of concrete mix on the brush fork:
xfaxman;
Wow, I really need to figure out my hydraulic issue because I can't come close to that! I how do I find out what the spec on my front axle is? I've looked on-line for specs but that is one that doesn't pop up. It's a 4x4 so the housing is more substantial than just a spindle.
   / SCUT FEL lifting force #8
I don't know. The TORO uses a Spicer axle, the load rating was listed in the service manual or some other brochures that I have.
After looking at the axle it looks pretty beefy, I am pretty sure it wouldn't have a problem lift a bucket full of dirt or a shy of a bucket full or rocks. If I need to lift something flat like a pallet I would the 3point hitch.
I am pretty sure I have the bucket lift issue figured out so now I just need to fix it and start using the bucket more. Thanks for the help.
   / SCUT FEL lifting force #10
XFAXMAN: I enjoy your pictures of that thing, even if looking makes me temporarily cross-eyed. Reminds me tractors are a big world and to keep an open mind.
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
Wolverine Quick Attach Concrete Mixing Bucket (A50514)
Wolverine Quick...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
